Old September 23rd, 2013, 11:31 AM   #1
parox91
Name: Not Applicable
Motorcycle(s): 2007 Blue Ninja 250
Tight Controls on the pre-gen
My gf has a 2004 pregen and I have a 2007, her ninja's controls are harder to use than mine (i.e. more effort in compressing the clutch), anyway to remedy this? Just spray a lot of wd40 through the lines?
parox91 is offline   Reply With Quote
Old September 23rd, 2013, 11:53 AM   #2
Chicagobob
Chicagobob's Avatar
Motorcycle(s): '06 Ninja 250, 2018 Honda GL1800B
Not WD40. First, check the clutch cable for kinks, dents or wear. If it looks good, lube it with aerosol cable cable lubricant and a cable lubricating tool. They are available from Amazon and other sellers.
Even if you replace the cable, you should have the lubricant for future use (works on throttle cables, too).
Chicagobob is offline   Reply With Quote
Old September 23rd, 2013, 01:58 PM   #3
Lychee
sail away
Lychee's Avatar
Also, lubricate the pivot bolt and areas of contact between the lever and the perch. The pivot bolt should only be snug, not super tight. The locking nut will hold it on.
Old September 23rd, 2013, 02:02 PM   #4
parox91
Thanks for your help guys, I will do this after I work on her CCT... heard a ticking from her engine
Old September 23rd, 2013, 04:54 PM   #5
Lychee
sail away
Lychee's Avatar
http://faq.ninja250.org/wiki/Cam_cha...sioner_removal
Don't fix it unless you're sure it is broken... It would cause timinig problems. Symptoms for chain timing problems would include hard starting, combustion into the air box, or after fire. The ticking sound could simply be loose valve train noise. If the engine runs smooth, the CCT is unlikely to be broken. At least, that is my opinion.
Why not fix her suspension instead- that comes broken from the factory!
Old September 23rd, 2013, 06:20 PM   #6
parox91
I've reset it on both bikes before, and her bike has had an aftermarket lowering kit installed so the suspension is now even worse off than from the factory haha. The CCT actually gets stuck on her bike for some reason. I had a bad ticking noise on mine because that was stuck but hers happens more often... Everything on her bike is a little bit more "sticky" than mine... must be cause it's an '04 or something.
I've had dreams where I've dipped her entire bike into WD-40 lol
New-gen engine in Pre-gen frame. Oil leak under exhaust ports. AFazakerley 2008 - 2012 Ninja 250R Tech Talk 11 June 5th, 2016 02:03 PM
Fitting a new gen front wheel on a pre gen? thumper64 1986 - 2007 Ninja 250R Tech Talk 13 November 6th, 2013 02:44 PM
Left handlebar controls on new gen? IF13 2008 - 2012 Ninja 250R Tech Talk 17 August 22nd, 2013 03:52 PM
Pre-gen (2007 and older) and "new pre-gen" (2008-2012) frames kjohng General Motorcycling Discussion 5 February 27th, 2013 10:03 AM
FS/ part out new gen and pre gen 250r ninja carlos Motorcycle-related 3 May 14th, 2012 10:25 PM
