Old January 18th, 2012, 05:30 AM   #1
jarred6644
Motorcycle(s): '01 ninja 250
Electrical
I replaced the solenoid and right handle bar cluster and my bike has power but when I try to start it the bike won't turn over but all the lights turn on when I turn the key any help would be appreciated
jarred6644 is offline   Reply With Quote
Old January 18th, 2012, 08:36 AM   #2
dubojr1
dubojr1's Avatar
What year 250?
Let's also be clear. The issue you are having is the bike won't turn over? I'm sure you've checked the obvious like the kill switch is "ON" and that the bike is in neutral. Will it turn over if you pull the clutch in? Have you checked the battery to make sure it is fully charged?
Old January 18th, 2012, 12:15 PM   #3
jarred6644
Yes bike is in neutral and all components are coming on so battery is charged and I've switched the kill switch both ways I have also tried with clutch in kick stand down...etc the issue is the bike wont turn over the bike is a 2001 250ex
Old January 18th, 2012, 12:23 PM   #4
dubojr1
dubojr1's Avatar
Keep in mind now that just because all the lights are coming on means nothing. Entertain yourself and just hook a set of cables to it a see if jumping it with another battery helps any.
Old January 18th, 2012, 01:08 PM   #5
Skippii
Milkshake Drinker
Skippii's Avatar
Checked the fuses?
Posted via Mobile Device
Old January 18th, 2012, 01:09 PM   #6
Skippii
Milkshake Drinker
Skippii's Avatar
Why did you replace the solenoid? And are you sure everything is reconnected correctly on the right hand bar?
Old January 18th, 2012, 02:02 PM   #7
jarred6644
Fuses have been checked. And because it was bad. And I tried to hot wire it directly also so if the buttons were bad it would have started that way but thanks f
Old January 18th, 2012, 02:02 PM   #8
jarred6644
Or the input
Old January 18th, 2012, 04:17 PM   #9
do you hear a click from the relay when you try to start it?
Old January 18th, 2012, 04:46 PM   #10
Skippii
Milkshake Drinker
Skippii's Avatar
Have you tried bypassing the solenoid by connecting the two high-current terminals together with pliers? That will crank the engine regardsless of anything else (don't even need the key in the bike) so should be one of the first steps in diagnosing. Work backwards from there (next, run power through the coil of the solenoid and see if that cranks it, keep moving back until you find where the problem is.)
Old February 2nd, 2012, 03:46 AM   #11
Apex
Livin' the Minimoto Life
Apex's Avatar
Neutral/clutch switch issues possibly?
need some electrical help bhalv 1986 - 2007 Ninja 250R Tech Talk 6 November 26th, 2017 03:31 AM
I got a little electrical problem. infinitewhiskey 1986 - 2007 Ninja 250R Tech Talk 3 August 8th, 2013 10:36 AM
Will I be asking too much of my electrical system? headshrink 2008 - 2012 Ninja 250R Tech Talk 4 June 2nd, 2013 07:16 AM
Electrical gurus cuong-nutz Off-Topic 14 December 18th, 2011 06:42 AM
[motorcyclistonline] - New Permatex® Liquid Electrical Tape Keeps Electrical Connect Ninjette Newsbot Motorcycling News 0 February 26th, 2011 01:20 AM
