Old March 18th, 2012, 04:44 PM   #1
greenaero
Motorcycle Hypermiler
greenaero's Avatar
Motorcycle(s): 1999 & 2005 Kawasaki Ninja 250R's
Airbox installation
I decided to clean and adjust my carburetors as my bike came with 23K miles on it and as far as I know its never been done. Removing the carbs was pretty after removing the stock airbox. I took the carbs apart and they actually looked pretty good. After putting them back together I hit the hard part of this job: re-installing the airbox. I'd get one boot seated and started to align the other one when the first one would slip off. Grrrr! I finally fixed by using a heat gun to warm up the airbox boots so that they were soft and pliable. I had had a friend help push the airbox forward while I manipulated the carbs. Success at last.
I had a fuel leak from a carb bowl so I had take the carbss off again to fix the leak. gun on them. After I adjusted the idle mixture the bike ran much better. This time I was able to re-install the airbox without assistance after using the heat I still need to synch the carbs but I want to install some tees in the vacuum lines so that it will be easier to do for the future.
greenaero is offline   Reply With Quote
Old March 18th, 2012, 04:55 PM   #2
Old March 18th, 2012, 07:38 PM   #3
I linked you to a DIY for separating your airbox from your battery box in the "what did you do to your ninjette today?" thread. It's really useful. I highly recommend it for making the carbs easier to work on
Old March 18th, 2012, 09:51 PM   #4
greenaero
greenaero's Avatar
Thanks Chris, I had seen this before and I did do this after I pulled the airbox the first time. It made it much easier when I had to remove the carbs the second time to fix the a leaking bowl.
What Do I Need To Do? Installation Help ilovejesus 2008 - 2012 Ninja 250R Tech Talk 5 May 7th, 2018 09:08 AM
Battery installation iSpeed 2008 - 2012 Ninja 250R Tech Talk 4 June 27th, 2012 07:44 PM
'08+ Airbox Countersteer Motorcycle-related 0 June 10th, 2012 12:50 PM
Spool Installation NHrider19 Videos 1 June 6th, 2012 08:27 PM
For those with hardluggage, do you ever take them off after installation? setasai Cargo Space 3 March 18th, 2011 08:01 AM
