#1 |
Join Date: Jan 2014 Motorcycle(s): Had a 2008 Ninja 250, til some low-life stole it. Now riding a 2013 red cbr250. Posts: 274
Speedo cable only works when it's warm??
Last summer I noticed my speedo cable came loose from where it connects to the head/speedometer panel. I just screwed it back in and all was well, for a while.
Now I notice that on cold days, it won't work at all. The odometer and tach work just fine, but the speed doesn't. If it's a warm day, however, (60's or above), it will start working again and give me the speed. Usually it doesn't work in the morning (cold), but in the afternoon it does (warm). What gives? Also, is it okay to put locktite on the speedo cable to keep it in? |
#2 |
If the odometer is working, the cable is transmitting the rotation, as intended.
The speedometer works on electrical induction, which is not a solid linkage. Being that way, it may not be able to overcome the viscosity of any grease in the mechanism. Proper torque should be enough to keep that nut in place; I wouldn't use Loctite.
Motofool ![]() .................................Never ride faster than your guardian angel can fly "Mankind is composed of two sorts of men — those who love and create, and those who hate and destroy. Love is the bond between men, the way to teach and the center of the world." - José Martí |
#3 |
Board Member
no loctite
#4 |
#5 |
#6 |
#7 |
#8 |
Yes, lube everywhere you can reach.
I was talking about the factory grease that goes inside the mechanism, where you cannot reach. No, I did mean the speedometer. ![]() http://www.explainthatstuff.com/how-...ter-works.html
Speedo Drd, Speedometer and Odometer Accuracy-Speedo Healer/drd | Klondike1020 | General Motorcycling Discussion | 8 | August 17th, 2014 12:23 AM |
Speedo Cable connector missing? Koso. | MrHungryMonkey | 2008 - 2012 Ninja 250R Tech Talk | 7 | January 12th, 2014 08:33 PM |
Anyone know why my speedo cable won't screw in? | Stingray1000 | 1986 - 2007 Ninja 250R Tech Talk | 11 | November 18th, 2012 10:04 PM |
