August 27th, 2014, 02:28 PM | #41 |
Join Date: Jan 2013 Motorcycle(s): 2009 Ninja 250R Posts: 206
August 27th, 2014, 02:33 PM | #42 |
Rojo is running an R6 front wheel with custom spacers to allow him to use the stock forks. But this means he can run a 120 super sticky SS tire up front. So essentially, yes it's been done.
These bikes don't have the guts to spin up the rear, so a little harder/longer wearing tire is a great idea in the back. But the front does more work because the bike has no guts, so a sticky one up there is a good thing. I say go for it! |
August 27th, 2014, 02:34 PM | #43 |
Fast-Guy wannabe
MOTM - Jan '13
Does anyone even read my posts
August 27th, 2014, 02:41 PM | #44 |
Certified looney toon
MOTM Jul '13, Jul '14
Any word on if the Michelin's are back? I've got about 1-2k left on my rear before I'll be in the market again.
August 27th, 2014, 03:24 PM | #45 |
Join Date: Aug 2013 Motorcycle(s): 2012 Ninja 250 Posts: 450
If i recall seeing on one site they are looking between early sept. on the front and mid sept. on the rear.
I'll probably pick another rear tire once they get back in stock for this winter when i'll need to change it. |
August 27th, 2014, 04:24 PM | #46 | |
Private Joker
MOTM - Mar '14
I think I'll be switching to the pirelli for the front when the time comes though but the front tire isn't showing much wear on my 300
August 27th, 2014, 04:26 PM | #47 |
Private Joker
MOTM - Mar '14
I sowwy, I read it when you posted it but forgot some of the important details over time. Was focused more on the tire life than the front end setup.
Though I suppose I should start getting more interested in the front end setup as well since I'm considering re-doing the front suspension on my N250 over the winter and possibly switching up to 17" tire sizes
September 12th, 2014, 02:09 PM | #48 |
Front and rear are in stock at Revzilla.
FRACK! I just had to buy new tires last weekend!! Anyone want some slightly used Rosso IIs? Kidding
September 12th, 2014, 03:43 PM | #49 |
Private Joker
MOTM - Mar '14
I'd totally rock those as some track tires
September 12th, 2014, 03:47 PM | #50 |
If I could figure out a way to buy the Michelins and get the Rossos to you without digging myself into too deep of a financial hole, you'd have a deal. Alas, you're across the country.
September 13th, 2014, 11:45 AM | #51 |
MOTM - Sep '14
3k on mine, still look new.
I bout a second rear just in case they are not available again when I do need it. 3.2k from August 2nd
Keep calm and ride on -Motofool Never quit on a rainy day -ally99 |
September 13th, 2014, 12:11 PM | #52 | |
Private Joker
MOTM - Mar '14
I'm looking at somewhere around 5-6k on my michelins. The front looks to be experiencing an odd wear pattern (the wear on each side of the crevices is different, the front part of it is wearing a lot slower but because it's so uneven now is starting to break up to make up for it...I'll get a pic when it's not raining) and the rear is about half life or so, solid wear with a slight flat spot because the primary use is commuting and I hop on the beltway to get to where most of my friends live. The rear unlike the front is wearing predictably without any oddities.
September 13th, 2014, 03:40 PM | #53 |
So the front is scalloping or cupping? I had that issue with the front BT45 when I was using that. Similar tread pattern IIRC
September 13th, 2014, 07:46 PM | #54 |
Fast-Guy wannabe
MOTM - Jan '13
As I was sitting on the asphalt in front of my bike changing my socks, yeah I know random right? I noticed my tread depth on my front tire(Pirelli race tire) is almost completly gone. Strangely enough the depth is almost universally even all around so I hadn't noticed. The front still has a good aggressive profile vs my rear which is heading toward squaresville. Looks like I'll be needing to grab both front and rear this time around but after this many miles I can't even begin to complain.
I guess ill order a new rear and start asking around at the track for another decent takeoff for the front. |
September 13th, 2014, 08:29 PM | #55 |
Private Joker
MOTM - Mar '14
pretty much, it's very consistent. Every time there is a gap for rain tread the tire is lower on the side that comes into contact with the road last...that is to say the side that is higher when sitting has a noticeable amount less rubber than the side that is lower when sitting
September 13th, 2014, 11:01 PM | #56 |
MOTM - Jan '18, Sep '13
I might get this for the rear eventually. Definitely sounds like a good option. I wanted to try out having both front and rear PR4's to see how that is first, but that might be a while from now because I'm not riding enough.
October 9th, 2014, 11:06 AM | #57 |
Fast-Guy wannabe
MOTM - Jan '13
Just got a new rear in the mail today from amazon free shipping and I only ordered it yesterday.
October 9th, 2014, 11:14 AM | #58 | |
MOTM - Sep '14
October 9th, 2014, 12:08 PM | #59 |
MOTM - Sep '14
power street front w/5k
and back
October 9th, 2014, 12:15 PM | #60 |
Jason, what mileage do you have on the rear?
October 9th, 2014, 12:19 PM | #61 | |
Fast-Guy wannabe
MOTM - Jan '13
How's this for cupping? Yes it's there, no it doesn't make a difference I still can't break traction or feel anything mid corner. Here's Ed Sorbo's response when I posted the picture earlier this week. |
October 9th, 2014, 12:25 PM | #62 |
Fast-Guy wannabe
MOTM - Jan '13
13,500 miles so far and I've still got about .040-.050" to the top of the wear bars and probably a full .100" till they're slicks. My race front tire is way passed the wear bars and most of the tread pattern is gone completely(look like a slick). I may toss on an old used front just to kill the rest of this rear before going with a new front and rear.
October 9th, 2014, 12:31 PM | #63 |
Excellent. Saw the Pilot Streets at a local shop on sale (sales creature said they sell them at $1 over cost to try to stay competitive with online shops) so they are definitely going on next go round. I'd love to get 13k out of a rear!
Thanks for keeping us updated on these, really helps out!
October 9th, 2014, 12:35 PM | #64 | |
MOTM - Sep '14
I'm going to get 20k+
October 9th, 2014, 03:08 PM | #65 |
Private Joker
MOTM - Mar '14
Thank's @rojoracing53 that's exactly what my tires look like
October 9th, 2014, 03:11 PM | #66 |
Private Joker
MOTM - Mar '14
yea, your tires have less wear than mine at similar mileage too
October 9th, 2014, 03:14 PM | #67 | |
Fast-Guy wannabe
MOTM - Jan '13
October 28th, 2014, 11:53 AM | #68 |
Join Date: Aug 2014 Motorcycle(s): 2007 Ninjette Posts: 809
@rojoracing53, do you have a suggestion for a tire similar to the Michelin PS Radial for pre-gens? The Commander is the only tire Michelin even offers in 130/90-16, at least in new stock.
"That's what" -she |
October 28th, 2014, 02:57 PM | #69 |
Some info here:
https://www.ninjette.org/wiki/Tire_options_-_pregens The most recently released tire for the pre-gens was the Pirelli Scooter Diablo; it still seems to get positive reviews.
October 28th, 2014, 03:00 PM | #70 | |
Fast-Guy wannabe
MOTM - Jan '13
October 28th, 2014, 03:03 PM | #71 |
Fast-Guy wannabe
MOTM - Jan '13
it would be hard for me to attach anything with the word scooter on the side to my motorcycle
October 28th, 2014, 04:45 PM | #72 |
Private Joker
MOTM - Mar '14
I'm running the diablo scooter tires on my pregen at the track, I'm a bit underwhelmed by them but accept that they're the best I can get for 16" wheels. My michelins have more grip and wear better. I'm looking forward to doing a 17" wheel conversion on my pregen to get proper tires on there
March 21st, 2015, 09:30 PM | #73 |
Noticed I'm a couple hundred shy of 10k today so snapped pictures of my tires. Moderate riding style, mainly highways, about 30% curves.
Front: Rear:
March 23rd, 2015, 06:57 AM | #74 |
Fighting Texas Aggie '05
how squared is the front? Looks pretty good either way.
March 23rd, 2015, 07:29 AM | #75 |
Awesome wear (or lack of) at 10k miles!
March 23rd, 2015, 08:58 AM | #76 |
I'm not seeing any noticeable flat parts on the front, but I can get a more angled pictute if you want. I can just barely see the flat center on the rear. I tried feeling for the crest between the edge and center on the rear with my hand and couldn't find the edge.
Neither are as flat as my Pirelli or Bridgestone tires got after only 5k. Very impressed with this tire!
March 23rd, 2015, 09:59 AM | #77 |
I passed on the Pilot Streets and maybe now am not so happy I did lol. I picked up a set of 110/140 Stones, the new S20 Evo. With the tire sale and rebate I paid literally $160 for a set.
March 23rd, 2015, 05:45 PM | #78 |
I spent $235 on my set but when you factor in the distance your getting out of a set you save a ton of money by not having to buy more sets of tires.
March 23rd, 2015, 06:18 PM | #79 |
chaos theory
Join Date: Jul 2014 Motorcycle(s): 2012 Ninja 250r SE ; 2007 ZZR600 Posts: 123
My 250 is having it's 7500 mile service at the dealer and I'm having a Michelin Pilot Road II front tire put on while it's there. I currently have the pilot road II 150/60 ZR 17 on the rear. Rides fantastic.
March 25th, 2015, 02:01 PM | #80 | |
http://www.motorcyclenews.com/new-ri...-mystery-line/ |
Pilot Street Radial from Michelin - Review | afelotreyu | 2008 - 2012 Ninja 250R Tech Talk | 22 | September 5th, 2016 05:18 PM |
[sportrider - latest stories] - Michelin Pilot Power 3 and Supersport Tire Review | Ninjette Newsbot | Motorcycling News | 0 | October 7th, 2013 02:30 PM |
Michelin Pilot Power mixed with Stock IRC front? BAD because Bias w/Radial? | kkel19 | 2008 - 2012 Ninja 250R Tech Talk | 7 | May 6th, 2013 10:23 PM |
[motorcycle-usa.com] - Michelin Pilot Power 3 Tire Review | Ninjette Newsbot | Motorcycling News | 0 | April 18th, 2013 12:30 AM |
[topix.net] - Michelin Pilot Road 3 Sport-Touring Radial Tires | Ninjette Newsbot | Motorcycling News | 0 | August 9th, 2011 01:51 AM |
