Old October 9th, 2019, 09:00 PM   #1
NewtoNinjettes
Motorcycle(s): 2007 250r
Engine slow to fall the last 2000k rpm before idle.
So long story short. Just picked up an all stock 2007 pregen. It had no key, so I was just able to try to start it today when I received the correct Ignition switch. Cleaned the carbs, airbox, petcock and flushed the fuel tank with fresh fuel, before trying to start it. Airfilter foam had crumbled into breadcrumbs so that had to be removed and cleaned.
Upon starting the bike for the first time it ran at 5k rpm with the coke on, and wouldn't dip below 3k rpm with the choke off. Checked choke to make sure it was fully disengaging. Added a make shift air filter foam and lowered the idle speed and it runs great except on free rev decel the rpm drop is slow from 2500 rpm to 1200 rpm where it idles nicely. It's not a big problem but would prefer for it to function correctly. Any ideas?
NewtoNinjettes is offline   Reply With Quote
Old October 9th, 2019, 09:12 PM   #2
BoBO
BoBO's Avatar
Motorcycle(s): 08 ninja 250R
The carburetor might be out of sync assuming that your carbs are clean and your valves are in spec. Also, you might want to check for vacuum leaks by spraying water after the engine is warmed up. Could be the hoses or around the air box. Hopefully you find out what it is and let us know.
08 Ninja 250 track-prepared
04 BMW Z4 2.5 M Package
01 R170 AMG Sport Package
Old October 10th, 2019, 07:21 AM   #3
Motorcycle(s): '06 SV650n, '00 SV650n project, '00 Derbi GPR, '64 CA77 Dream 305, '70 CL450 Scrambler, numerous dirt bikes
I agree - sounds typical of a vacuum leak.
Old October 10th, 2019, 06:30 PM   #4
Motorcycle(s): '95 DUCATI 900SS/SP '98 HONDA VFR800 '07 DUCATI SS800 '19 HONDA CBR650R
I've found the 2 vac hoses between the carbs, or 3 hose points at top of decel valve can be loose and prone to leakage when hot....check those specific areas.
Gordon
Old October 10th, 2019, 07:07 PM   #5
Motorcycle(s): CB125T, Ninja250R racer, Ninja250R street bike, EX250F#1, EX250F#2, EX250E, VF500F, CBR600RR
Yeah, I zip-tie those little hose-ends onto carbs to keep them from opening-up and leaking when warmed up.
Old October 16th, 2019, 03:08 PM   #6
NewtoNinjettes
Ok going over all of the hoses with a fine tooth comb now. First odd thing I noticed is that of the three hoses exiting the back of fuel tank, blue, black and red, the red one which is attched the furthest to the shifter side of the bike and running to the inlet on the 4 way connection to the evap cannister labeled "tank" had a significant amount of water drip out of it when I took it off. Is this a water drain line for the area around the fuel cap? If so why is it connected into the vacuum system that leads to the carbs? Sounds like a bad combo to me, or is it hook to the wrong tank outlet? Is water normal in that line?
Old October 18th, 2019, 06:44 PM   #7
NewtoNinjettes
Appears I had it hooked up correctly according to the diagrams I found. Also I guess I have a Cali bike because it has an evap cannister system which I guess maybe was unique to the California model? Anyways went over all the lines. Can't find a Vacuum leak and still having the slow rev down issue, even tried bypassing the evap/vapor recovery system to see if it was somewhere in there. No change. Now I'm back to thinking carb issues. No sure what to do next.
Old October 19th, 2019, 12:14 AM   #8
59096
59096's Avatar
Try replacing the o rings on the mixture screws under the carbs at the Botton of the float bowls. That was where my was leaking.
Perpetua Culpa Alterna Vagus
Old October 19th, 2019, 12:57 AM   #9
Also make sure needle jets aren't backwards.
slow rpm fall and bike doesnt want to go. 7oxSin 1986 - 2007 Ninja 250R Tech Talk 16 October 12th, 2013 08:02 AM
Slow throttle response and slow return to idle help Crriiissss 1986 - 2007 Ninja 250R Tech Talk 22 August 7th, 2013 12:26 AM
Raising Idle RPM Archerzz 1986 - 2007 Ninja 250R Tech Talk 4 June 14th, 2011 12:51 PM
High Idle RPM... wayanlam 2008 - 2012 Ninja 250R Tech Talk 4 July 20th, 2010 09:59 PM
remote server monitor
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Except where otherwise noted, all site contents are Copyright 2019 ninjette.org, All rights reserved.
