January 4th, 2012, 10:59 PM | #321 |
Now that's confidence... promote that man to general.
January 5th, 2012, 12:13 AM | #322 |
@flynjay Looks like a fantastic plan. If it goes according to plan I bet there are members that would pay you to do the conversion for them. I will follow you're exact plan. Using open-loop running first and then including the sensors is a great idea and perfect location to split the 2 days. I'm going with the 650 cables so that rerouting might take a little more creativity.
2009 Ninja 250R SE Green Sport Touring Style: ZG ST; Symtec heated grips; RAM GPS w/ mUSB; DIY reshaped seat; DIY Givi E21 Sidecases; 15T sprocket |
January 5th, 2012, 09:20 AM | #323 | ||
Join Date: Oct 2010 Motorcycle(s): 2006 Ninja 250R, 2007 EFI Ninja 250R Posts: A lot.
However, another guy that converted his bike with the ecotrons kit said this: Quote:
In another post he said that re-using the 250 cables did not work well and left the throttle partially open. I'm wondering if the 650 throttle body will work? Its the same thing as the 250 only bigger. Also, k12 subsequently lowsided and said the conversion was a factor in that it seemed to have more torque than he was used to. Since he used the OEM TB, the pulley size was the same. So my hat is off to anyone that can do the conversion in two days without using the OEM throttle body. But if you do, please remember to post plenty of photos and videos to help the rest of us slugs figure it out.
My Ninja Blog Proud member of ABATE.My NYC Road Rage documentary - CENSORED! |
January 5th, 2012, 10:13 AM | #324 | |||||
Join Date: Nov 2011 Motorcycle(s): 2007 Ninja 250 (sold), '06 Ninja 650R Posts: 455
January 5th, 2012, 10:16 AM | #325 |
One question I do have is where to mount the ecotrons ecu?
I am thinking either behind the battery, or where the stock CDI is. @greg737 any ideas since you have the pregen? |
January 5th, 2012, 10:19 AM | #326 | |
Join Date: Dec 2011 Motorcycle(s): Ninja ex250 1990 Posts: 761
1990 250F. ex300 motor swap, 15/42 gearing, flush side markers, newgen intergrated front fairing, rear integrated turn signals, DB Touring Bubble, zx600 rear shock, Custom DanMoto Exhaust |
January 5th, 2012, 10:34 AM | #327 | |
good luck EMSRacer we are all counting on you! Do you have a new-gen or pre-gen? Have you thought about cable routing? I'm thinking of routing the engine temperature sensor and o2 sensors up through the backbone along the stock harness. I would like the LED for the kit to be up in the instrument cluster, but I think that will be a further modificaiton to the kit. I will probably end up cutting it off, extending the cables to reach the instrument cluster and using a connector for final install. |
January 5th, 2012, 11:03 AM | #328 | |
Where is everyone going to install their ECUs at?
January 5th, 2012, 11:31 AM | #329 |
K12 had an OEM throttle body so his throttle pulley had the same diameter as the stock carbs. So the throttle twist is the same. The ecotrons pulley is a little smaller. So that means more torque with less twist. We should all take that as a warning when we go out for that first ride.
As far as the ECU, as long as it isn't too big, I plan to mount it in place of the CDI. Supposedly it just bolts in anyway. Not much discussion so far about the new ECU and how big it is. I got a tracking number, but it says that mine hasn't shipped yet.
January 5th, 2012, 01:23 PM | #330 |
my status says it was just recieved so its priority so might be friday or sat depending.
And i guess where the old CDI would be a good spot.
January 5th, 2012, 01:37 PM | #331 |
I'm thinking either of the two locations below:
1. Where the stock CDI is (will probably have to remove the tabs). 2. Behind the battery attached to the wheel cover. |
January 5th, 2012, 01:47 PM | #332 |
Guys,
It's been too busy for me as the beginnning of the year. Sorry if I missed any questions. Here is a suggestion to the pre-gen owners: Buy a pair of new-gen carb boots (Ebay) to replace the pre-gen carb boots. Below is a picture, you can see the pre-gen boots are longer. It may affect your high-end performance (theoretically). For now, we included 2 sets of rubber tubes, one long, one short, as the adaptors for 3 pre-gen owners. So you can try both. |
January 5th, 2012, 02:08 PM | #333 | |
I have my Microsquirt ECU located in the tail section of the bike. There's a nice bit of room in the tail fairing enclosure just behind the end of the seat and in front of (or behind, it depends on how you look at it) the taillights. If you look over at my avatar picture the Microsquirt ECU is right under where the passenger grab-handle sticks up. If you go to the video of my installation and go to 11:00 minutes into it you'll see my location and wire routing.
January 5th, 2012, 02:12 PM | #334 |
ECU location: anywhere you can find, because the harness is long enough.
One location is the rear of the bike, just below the rear seat. I think Greg used that location. |
January 5th, 2012, 02:21 PM | #335 |
Great write-up @greg737.
I did not know the tool kit went behind the battery. Does it just sit in there or is there something holding it in? I have been just stuffing it in the rear compartment. I agree that the CDI location seems like the best. It allows for the serial and performance switch to route to the rear compartment as well as access to the front of the bike for the rest of the harness. Probably will have to remove one or both of the original tabs. I planned on drilling through the fender and mounting with standoffs. Or I could do like you did and just velcro it on. The industrial strength velcro has some serious holding power. |
January 5th, 2012, 02:30 PM | #336 | |
January 5th, 2012, 05:07 PM | #337 | |
January 5th, 2012, 05:34 PM | #338 |
The picture of all the tools laid out in a nice little row makes me laugh.
The reason is the philips head screwdriver (down at the very bottom). It's supposed to have a black plastic handle on it but the plastic is so cheap and brittle it crumbles in your hand the first time you try to turn a screw with it. So whenever you see a set of Ninja tools the philips head screwdriver is always missing its handle. When mine self-destructed during a bit of remote, roadside emergency maintenance I just grabbed the small pliers from the kit and used them to turn the screwdriver shaft. |
January 5th, 2012, 05:38 PM | #339 |
That's a stock image. Mine still has the handle and pliers.
I just ordered the newgen boots. I think it will give more room for the other stuff that has to go in there. PS - My kit has now been shipped according to the tracking info.
January 5th, 2012, 06:16 PM | #340 |
I don't have that plastic tray.
I think I will be using the longer boots. My theory is that it will give a little more space for the throttle cable. |
January 5th, 2012, 07:00 PM | #341 |
Fuel Pump
The tray in the photo is for sale on ebay.
Regarding the fuel pump, does anybody know where the power to run it comes from? Is it supplied by the ECU or does it go straight to the battery? It would make sense to have the ECU power it because it would need to turn it off if the bike is laid down or if the bike isn't started immediately after the ignition is switched on. On the Honda CBR250 the fuel pump comes on for about 2 seconds after the key is turned on and stays off until the engine is started. Unfortunately, I am not familiar with how other bikes do it.
January 5th, 2012, 10:17 PM | #342 | |
Yes, Ecotrons fuel pump will come on for 2-4s after key on. It is actually calibratable depending on your total volume of high pressure fuel hose. Don't worry, we have you covered for these details, you just need to make sure the system is installed right. |
January 5th, 2012, 11:14 PM | #343 |
Join Date: Nov 2011 Motorcycle(s): 2010 Ninja 250 Posts: 14
hey guys i decided not to EFI my ninja, i got my kit from ecotrons. Anyone interested in it? PM me.
btw I have a 2010 |
January 6th, 2012, 05:57 AM | #344 |
What was your reason for not doing the conversion?
January 6th, 2012, 07:59 AM | #345 |
January 6th, 2012, 10:37 AM | #346 |
well the whole discussion from ^^^^^ is all about using the 650 cables and turning it right side up. Either way the install looks like cake. Its really just install TBs and hook everything up and plug things in. Ur choice though
January 6th, 2012, 11:16 AM | #347 |
It all really depends on what "alot of work" means to you.
To me "alot of work" is complete engine rebuild (if you had to do a rebore). To some people an oil change or a valve adjust is "alot of work". |
January 6th, 2012, 11:50 AM | #348 | |
My FI conversion project was lots of fun. |
January 6th, 2012, 12:12 PM | #349 |
Heh I'm excited too! I'm still pondering about the 650R throttle cables. It doesnt have the adjustment nuts on the throttlebody side. Only that plastic adjustment which already cracked on my 250. Why plastic kawasaki... why plastic... sigh.
January 6th, 2012, 12:13 PM | #350 |
January 6th, 2012, 12:43 PM | #351 | |
BTW, I got a quote for re-chroming the exhaust manifolds and its $250. I think I'll just cheap out and use hi-temp paint. I have to do something because the previous owner mistreated the bike and made it stay outside in the rain. Hence the manifold is rusted on the left side. (How can anybody do that to their kids? ) If I plate the thing myself, its still a huge amount of chemicals to buy due to the odd shape of the thing. And most of all I'm worried that the process will take too long and I'll go into withdrawal. Yes, my name is n4mwd and I'm a riding addict. If my bike is unridable, it means I have to take the car.
January 6th, 2012, 02:33 PM | #352 | |
January 6th, 2012, 03:15 PM | #353 |
How did you do the welding without the bungs? Did your kit come already? Mine says its stuck on Romulus.
January 6th, 2012, 03:46 PM | #354 |
The 250r is my wifes bike
Join Date: Nov 2008 Motorcycle(s): 2002 Drz440 DS/SM - 2008 250R Ninja (Got it for the wife but i ride it too) Posts: 23
Lol this thred just cracks me up. I love it.
List of work to do to the wife's bike New parts EFI kit Area P race exhaust Pod filters Fuel gage sender unit Chain and gears Maybe cables but won't make a desition eater way till I can se the TB on the bike Work Install all parts do a valve check since its not much more work with the bike all apart and weld her bungs on Should be a fun day once all the parts are here. Maybe end of next week
My Resto Mods |
January 6th, 2012, 08:15 PM | #355 |
Join Date: Jan 2012 Motorcycle(s): 02 zx-12r, 13 zx-10r abs Posts: 245
did i miss this group buy? im about to pick up a 250r to replace my tw200, need a new around town toy bike
January 6th, 2012, 10:46 PM | #356 |
Jigglin' your Jiglets
MOTM - Apr '13
You need another bike man, as do I
January 7th, 2012, 06:31 AM | #357 |
January 7th, 2012, 07:14 AM | #358 |
What about deathproof? Could you ride it while your main bike is down? I have actually been looking at another Ninja and I went to the dealer and he let me sit on a ZX-10. The ZX series are supersports and have an uncomfortable riding posture. I think if I go to a bigger bike its going to be a 650 which has similar riding posture to the newgen. I emailed a guy selling a pregen cheap but he hasn't replied so either its sold or he's an idiot. Maybe both.
The tracking info says that my EFI kit has left Romulus and is now back on Earth and should be delivered today.
January 7th, 2012, 11:51 AM | #359 |
Join Date: Mar 2010 Motorcycle(s): 2009 Ninja 250r Posts: 93
Got something in the mail today
January 7th, 2012, 12:02 PM | #360 |
Mine should be here any minute. That new ECU looks huge. Looks like 5"x7" not counting the dog ears. Mounting may be more of a problem that I thought. The only problem I see in the photo is the clear fuel line. It doesn't look like its the alcohol resistant kind. Does it say anything on it about being alcohol resistant? Given that fuel down here is 10% ethanol, it would be a good thing if it was.
OEM Fuel Injection Kit and other 250 race mods | Shadowwolf1117 | Motorcycle-related | 0 | April 3rd, 2015 10:51 PM |
Ecotrons EFI (Fuel Injection) kit Group Buy: June 2013 | n4mwd | Motorcycle-related | 94 | October 12th, 2014 08:36 PM |
Ecotrons EFI Group Buy: March 2013 | n4mwd | Motorcycle-related | 124 | May 20th, 2013 10:15 PM |
Ecotrons EFI for ninja 250 (GROUP BUY) | ninja_thresh_hold | Motorcycle-related | 101 | March 4th, 2013 05:45 PM |
DWG Waterproof audio kit group buy. | Buffalony | Motorcycle-related | 0 | March 1st, 2009 11:57 AM |
