May 24th, 2011, 02:14 PM | #1 |
Join Date: Jun 2010 Motorcycle(s): '09 Ninja 250r Posts: 63
Throttle Response Problem Please Help
So I took my ninja out of winterization about a week ago, and upon inspecting it, I noticed that the throttle response is horrible, so bad that if you floor it quickly, the engine dies. Even if it doesn't die, the rpm's drop for 1-3 seconds and then they kick up like they are supposed to. What could be the issue here? Thanks for any help.
P.S there is old gas in the tank with seafoam in it. |
May 24th, 2011, 02:57 PM | #2 |
Your carb is gunked up. Seafoam is crap for leaving in the tank for extended time because it attracts moisture.
May 24th, 2011, 04:04 PM | #3 |
May 24th, 2011, 09:37 PM | #4 |
as mentioned. needs a tune up. fresh gas. clean the carbs.
Full throttle kills bike, throttle lag response. | Diegone | 2008 - 2012 Ninja 250R Tech Talk | 10 | April 30th, 2014 03:25 AM |
throttle response | kslane | 1986 - 2007 Ninja 250R Tech Talk | 1 | August 5th, 2013 07:58 PM |
Lost Throttle Response | Corona | 2008 - 2012 Ninja 250R Tech Talk | 4 | January 30th, 2013 11:42 AM |
Delayed throttle response | Greyfox | 2008 - 2012 Ninja 250R Tech Talk | 5 | February 23rd, 2012 07:35 AM |
