Old August 12th, 2014, 08:21 PM   #1
DanteCoal
DanteCoal's Avatar
Motorcycle(s): 2016 Ninja 300 ABS, R.I.P 1986 Ninja EX250
1986 EX250 Fork Tube replacement?
Found out that the fork tubes on my '86 EX250-E are bent (Only slightly, but enough to mess with my suspension if they aren't alligned -JUST- right).
I don't really know much about forks, so I'm wondering what I can get as replacement fork tubes, just the shiny chrome looking part. I looked around a bit and OEM parts would cost an arm and a leg, so I'm looking at whatever aftermarket variant will work on my bike.
DanteCoal is offline   Reply With Quote
Old August 13th, 2014, 06:07 AM   #2
ninja2007
Motorcycle(s): 2007 Ninja
A good used set is the cheapest way to go.
Look on ebay, and find a set that don't have vertical streaks above the dust seals. Low mile bike, and if they are bent they wear and put streaks on.
I got a pair last week for $110 shipped, complete forks. Slide them in the clamp and go...
It is a lot more expensive to buy new fork tubes, which I did on my last bike... She had a pit that would eat fork seals, so I bit the bullet. I don't think you can do new fork tubes, seals, and bushings for less than $350. Then you'll also want an air impact to get the bottom bolt broken free.
Zach
ninja2007 is offline   Reply With Quote
Old August 13th, 2014, 07:28 AM   #3
cuong-nutz
cuong-nutz's Avatar
A machine shop may be able to bend:roll it straight but eBay may be you best bet.
HalfFast Racing Team
Old August 22nd, 2014, 12:39 PM   #4
Zach
His forks are different.
Old August 22nd, 2014, 12:56 PM   #5
if it isn't twisted or kinked, a press and vblocks and a skilled hand can get it straight pretty easily
Old August 22nd, 2014, 08:22 PM   #6
DanteCoal
DanteCoal's Avatar
They seem to both be bent, and both just slightly. No crease or anything, but enough that if they aren't aligned just right, then my suspension vanishes and/or my bike tries to drift to one side. Finding a used set for my bike that's the right length and diameter seems difficult, as most that are the correct diameter are quite a bit too long for my bike. =/
Old August 25th, 2014, 06:21 AM   #7
ninja2007
Is the steerer the same length as the later model pre-gens?
If it is, it might still be cheaper to swap triple tree's and forks off of some of the more common sized ones than find the parts to rebuild.
Zach
Old August 25th, 2014, 06:52 AM   #8
DanteCoal
DanteCoal's Avatar
That is an idea that I hadn't really thought of. Not really sure if it's the same length or not, though. I'll look into that and see if I can make that a viable option. Thanks for the idea!
right fork tube seems to be leaking.. NinjaBoyEddy 2008 - 2012 Ninja 250R Tech Talk 1 November 18th, 2013 04:36 PM
Throttle Tube Replacement/Mod Jred 2008 - 2012 Ninja 250R Tech Talk 8 July 13th, 2013 12:31 PM
Straighten Fork Tube? Jono 1986 - 2007 Ninja 250R Tech Talk 44 January 27th, 2013 03:11 PM
fork tube size for clip on richierich781 2008 - 2012 Ninja 250R Tech Talk 1 July 22nd, 2009 09:23 PM
How much fork tube above triple? ROADandTRACK 2008 - 2012 Ninja 250R Tech Talk 4 June 5th, 2009 06:00 PM
