Old April 27th, 2011, 10:11 PM   #1
Yasko
Texas Newbie
Yasko's Avatar
Motorcycle(s): 07 Ninja EX250, 07 FZ6
11,000rpm+
I now have around 2500 miles under my belt, and I'm just now running the bike over 9,000rpm... What a blast it is to ride up in the 11,000+ rpm range...
The lil ninja is very stable on the highway when you lay on the tank at 90mph(gps speed)...
Great bike to learn how to ride.. Thank God I only have 25hp...
Yasko is offline   Reply With Quote
Old April 27th, 2011, 10:12 PM   #2
no kidding.
Old April 27th, 2011, 11:44 PM   #3
Cab305
Cab305's Avatar
Motorcycle(s): Blue 10 250r
You have to try it at the track, it's even more fun, when you turn!
Cab305 is offline   Reply With Quote
Old April 28th, 2011, 07:48 AM   #4
JeffM
Mr. 988
JeffM's Avatar
Motorcycle(s): One
Just wait till you suprise yourself by bouncing off the rpm limiter
Jeff
"I'm the one that's got to die when it's time for me to die, so let me live my life, the way I want to" - Jimi Hendrix
Cancer
JeffM is offline   Reply With Quote
Old April 28th, 2011, 08:00 AM   #5
LoneRonin
LoneRonin's Avatar
Motorcycle(s): 09 Ninja 250r
Jeff
now thats a certain way of knowing you're ready for an upgrade...when you're going through the twisty sections full throttle bouncing off the limiter, in every gear. If you can't ride like that, no need to upgrade.
LoneRonin is offline   Reply With Quote
Old April 28th, 2011, 08:06 AM   #6
rockNroll
rockNroll's Avatar
Motorcycle(s): black
Wow, you waited a long time!
Old April 28th, 2011, 09:46 AM   #7
Yasko
Texas Newbie
Yasko's Avatar
I don't want to ride over my head... I never thought I'd own a motorcycle, so I have to be careful...
It's more fun to ride a small bike hard, than to ride a big bike slow...
Old April 28th, 2011, 09:47 AM   #8
onizthegnome
certified newbie
onizthegnome's Avatar
Motorcycle(s): 08 ninja 250r blue
what happens when you bounce off the rev limiter?
locktite ALL the things!!!
onizthegnome is offline   Reply With Quote
Old April 28th, 2011, 12:53 PM   #9
bdavison
Wartown, USA
bdavison's Avatar
It goes rwentwaateetwaaatwaaaa...and it wont go any faster.
Old April 28th, 2011, 01:15 PM   #10
rockNroll
rockNroll's Avatar
exactly this
Old April 28th, 2011, 01:15 PM   #11
bluepoof
bluepoof's Avatar
Motorcycle(s): 2007 Ninja 250, 2002 Yamaha XT225
I keep thinking I'm running out of gas or something only to look down and, nope, just hit the limiter again.
www.bluepoof.com
bluepoof is offline   Reply With Quote
Old April 28th, 2011, 02:04 PM   #12
cuong-nutz
cuong-nutz's Avatar
I didn't do your typical break-in and rode it like I stole it. This bike loves the high revs
HalfFast Racing Team
Old April 28th, 2011, 02:48 PM   #13
Bols
Norwegian dude
Motorcycle(s): Ducati 748
Indeed, these engines loves revs! The break-in suggested in the manual seems way too modest rpm-wise, and too long. Seems to me they just print the same numbers on everything from choppers and offroad bikes to racingbikes. In my manual, it said 4k rpm in the beginning. And the highway home from the bike shop is 80km/h, which means there is no way to keep the bike under 4k rpm, i mean the bike doesn't even pull below 5-6k rpm! But using abit common sense is good, not going all out on a cold engine.
Bols is offline   Reply With Quote
Old April 28th, 2011, 03:17 PM   #14
Green Streak
Ninjette Owner
Green Streak's Avatar
Motorcycle(s): 2009 Ninja 250R SE, a puddle of Ninja ZX6
Yeah, the break-in RPM is rediculous, if you have to go on any highways at all you have to go over the recommended RPMs. You could stick to just secondary roads, but that is just not very realistic.
Green Streak is offline   Reply With Quote
Old April 28th, 2011, 04:40 PM   #15
aristurtle
aristurtle's Avatar
Motorcycle(s): 2002 Ninja 250
My bike seems to burn oil once I start going above 10,000. Not that that stops me! But keep an eye on it and top it off as needed, especially if you start smelling burning oil every time you slow down.
aristurtle is offline   Reply With Quote
Old April 28th, 2011, 09:44 PM   #16
Yasko
Texas Newbie
Yasko's Avatar
Wow, by the end of summer I'll be at that point...
Old May 10th, 2011, 05:19 PM   #17
GeorgiaHooligan
GeorgiaHooligan's Avatar
You know every kawasaki is redlined during testing before its released for sales and shipped.
GeorgiaHooligan is offline   Reply With Quote
Old May 10th, 2011, 05:35 PM   #18
proof?
Old May 10th, 2011, 06:18 PM   #19
bdavison
Wartown, USA
bdavison's Avatar
Its true, the first thing kawasaki does after it rolls off the assembly line is to ride it right into a dyno at the end of the assembly line, and redline the shiz out of it. They do it with every bike from the 250R all the way up to the 14's.
They also record the results with the VIN number for every bike. So if the bike ever comes back for some reason, they can pull up what it did on the dyno at assembly, and it gives them data to either fix design,mechanical, or engineering problems.
Old May 10th, 2011, 06:42 PM   #20
Live2ride
Live2ride's Avatar
Motorcycle(s): 06 yzf r6r previously: 09 ninja 250r, black 07 zx6r
proof?
I actually watched a documentary on this. They showed how they make a few of the bikes from start to finish; It was interesting to watch. They showed clips of the people taking them straight off the end of the assembly line and they rode it over to the dyno, then they rode the shiz out of it. You could hear it rather clearly and the commentator even stated that they test the full extent of every gear before approving it. That enough proof for'ya?
Live2ride is offline   Reply With Quote
Old May 10th, 2011, 07:05 PM   #21
were they Kawasakis or some exotic, exclusive type bikes?
Old May 10th, 2011, 07:06 PM   #22
not that I doubt you, but exactly how do you know this?
Old May 10th, 2011, 07:19 PM   #23
bdavison
Wartown, USA
bdavison's Avatar
The easiest way to verify what we are saying is to watch the "twist of the wrist" documentary specifically about kawasaki. They show it at the end of the show, and talk about it.
I even tryed contacting kawasaki to get the dyno results from my bike, but they said they dont release them, they are only for internal use by the engineers and designers.
Each bike starts with a barcoded label that specifies the specific bike being built. They scan this barcode at every step of construction to ensure the right parts make it onto the bike, and that the right tools are used. At the end of the assembly line, special kawasaki employees start the bike, warm it up, ride it into the dyno, scan the barcode which loads up the dyno program for that specific bike, and then runs it through the dyno program.
The kawasaki rep told me they use it for a couple of reasons. It ensures consistancy across the bikes leaving the factory, they all have to be within specs or they pull the bike to find out what went wrong. Also they store the data so they can pull it up later if needed.
Old May 10th, 2011, 07:20 PM   #24
Live2ride
Live2ride's Avatar
It was a documentary on Kawasaki's history of their bikes, how they have evolved over the years and how they are/were made. I just found this video, but my internet is too slow for me to watch much of it, I'm not sure if this is the same documentary I watched.
Old May 10th, 2011, 07:48 PM   #25
lol... well, what do you know? they don't say they ride the shiz out of them... they simply warm up the bikes and dyno them according to the model. regardless, I didn't know they actually did that and stored the data. thanks for the link to the show.
really funny thing is, I said the exact thing about what they do on another forum years ago, just making stuff up off the top of my head, bs'ing about how they tested and stored the data of each new bike they built and kept records of it in a secret vault. who the hell know it was true!
guess this proves they put the strongest motors in the green bikes!
thanks... I learned something.
Old May 10th, 2011, 09:04 PM   #26
Yasko
Texas Newbie
Yasko's Avatar
Good info...
Old May 10th, 2011, 09:24 PM   #27
Live2ride
Live2ride's Avatar
Well, If that's the same documentary that I watched a few months back then I'm wrong. There...I admit it . Wishful thinking I guess . But I thought it was cool about the whole data thing, it makes a lot of sense too.
Old May 12th, 2011, 06:18 PM   #28
ock1
That Twist of the Wrist documentary also said every Kawasaki was made in the Japan factory, when the 250's are actually built in Thailand.
ock1 is offline   Reply With Quote
Old May 12th, 2011, 06:47 PM   #29
Yeah, but I'm sure mother Kawasaki dictates build and test procedures even though it's assembled in another country to retain quality control.
Old May 12th, 2011, 07:28 PM   #30
LoneRonin
LoneRonin's Avatar
at the time it was filmed I don't even think the new 250r was rolling off the assembly line. Can anyone verify where the pregens were built?
Old May 17th, 2011, 03:23 PM   #31
coondog
coondog's Avatar
Motorcycle(s): 2005 ninja 250 street fighter, 2008 street fighter ninja 500, 2001 nsr 125
Change to Thailand is recent, twist of wrist is classic already. My pre-gen has a 14k redline. Originally the tachs. were marked as such and then one year 13k showed up with absolutely no variatons in bike fleets set-up. 11k rpm is just getting to where the bike wants to be all the time.
coondog is offline   Reply With Quote
Old May 17th, 2011, 08:28 PM   #32
Yasko
Texas Newbie
Yasko's Avatar
Yea the bike is very stable at 11k+ when you lay on the tank...
This lil bike is a Big surprise to me... I have friends that got bigger bikes and they're still crawling around afraid of the power... They're tripping out that I can run 90mph+ already... They're afraid to even get on the highway, and we got our bikes a few weeks apart...
The lil Ninja is a great teacher...
Old May 17th, 2011, 09:39 PM   #33
vkuchhal
vkuchhal's Avatar
Motorcycle(s): ninja 250r -2010
I tried yesterday to rev the baby to 14.5 k rpm and the rev limiter did not set in..
any comments on that?
vkuchhal is offline   Reply With Quote
Old May 17th, 2011, 10:32 PM   #34
bluesinorbit
bluesinorbit's Avatar
Engine damage much?
bluesinorbit is offline   Reply With Quote
Old May 18th, 2011, 08:31 AM   #35
vkuchhal
vkuchhal's Avatar
Originally Posted by bluesinorbit View Post
Engine damage much?
Not sure about it... but why didn't the rev limiter set in..?
Old May 18th, 2011, 08:46 AM   #36
almost40
ninjette.org Monkey Spank
almost40's Avatar
Was the motor hot? Was the outside temp hot? I would say that the tach reading is inaccurate by 1000 to 1500 rpm. Its a common problem on the new gens. Theres a few threads about the issue.
Black 250R
Full Area P QC
Old May 18th, 2011, 08:48 AM   #37
bluepoof
bluepoof's Avatar
What do you mean by "did not set in"? The needle stayed at 14.5 but the engine kept pulling past that?
www.bluepoof.com
Old May 18th, 2011, 08:53 AM   #38
coondog
coondog's Avatar
A GREAT teacher AND keeper. 11k is pretty much where most people I know (online) run her when possible, I thinks it maintains 80mph? there. And yeah, the dreaded head buffeting comes along. This dude Duke on ninja250.org developed a much higher screen years back, don't know what came of it. Do know double bubble came out after and the flocks went to them, never been behind either.
Make sure you don't forget how you were riding previously, continue varying your girls rpms, rpm shift points up and down, high speed runs and breaks, really work her up into a lather and then pull over into some shade or be home so she can cool down. Plus you'll be learning her braking patterns and your throttle pressures (for slowing or braking). I said one day I didn't do much of that and realized I'm doing it all the time, just on automatic from 6 years on my 05. Glad all is progressing, safely.
Old May 18th, 2011, 09:46 PM   #39
Yasko
Texas Newbie
Yasko's Avatar
I think if I sold her I'd have such remorse... I'm just getting to find her g-spot. When I do, I'm gonna stroke her, and stroke her over, and over again...
Oh, and 65mpg...
Old May 19th, 2011, 01:34 PM   #40
Mizono
Mizono's Avatar
Motorcycle(s): 2010 Red Ninja 250R
Oh, and 65mpg...
TMI ALERT TMI ALERT......wait you meant your bike!!!!! in that case carry on!!!
but seriously im learning mine too and boy the higher the RPM's the happier she is!!!
Mizono is offline   Reply With Quote
Losing power, top speed is ~70 at 9,000rpm, WHAT'S GOING ON??? Ninjettepgh 1986 - 2007 Ninja 250R Tech Talk 49 July 7th, 2012 09:54 AM
[visordown.com] - BMW S1000RR to be limited at 9,000rpm until first service Ninjette Newsbot Motorcycling News 0 March 4th, 2010 12:30 PM
