Old October 3rd, 2009, 07:31 PM   #1
komohana
komohana's Avatar
Red face Speedo Came Off!
Speedo CABLE that is
went for a short evening ride and had actually traveled about a mile thru residential area until i noticed...no speedo reading..odometer and trip meter no werkie...
got to gas station and noted the speedo cable from forks to front wheel hub was hang'in kinda low...upon further review, i realized it wasnt connected at the top! thought it was broken at first but saw the threaded connector and understood that it had worked itself loose over time as i have done no maintenance anywhere near that stuff.
(speedo cable is circled #3 in diagram)
(..and my bike didnt have that 'clamp' at headlight)
made sure it was secure for the ride home, and once in the garage, before looking anything up i saw where it went to and tried to reconnect. isnt quite reachable from the bottom up, so had to work between instrument cluster, handle bars and forks from the top-down...and still couldn't connect it.
THEN i looked at the manual and saw the positioning of that bend in the metal piece fitted at the top end of cable. routing the cable and aligning that metal section from the bottom was easiest, then tightened connector up top.
reconnected!
ops check good!
thinking about it later, i did have some clue the cable was working itself loose. the last time i refueled and reset the trip meter it didn't work for the first mile or two...speedo was fine but for some reason trip meter didnt turn. just an afterthought...
wanted to fyi my adventure...
friday nights just are NOT what they used to be
aloha
Remember when sex was safe
Old October 3rd, 2009, 11:32 PM   #2
ASecretNinja
ATGATT Squid Killer
ASecretNinja's Avatar
Motorcycle(s): '06 CBR600
This is actually a fairly common problem with with both the EX250s and the EX500s. If you didn't do it this time, I HIGHLY recommend Locktite on the threads when you put the cable back on. The same thing happened to me one night, so I googled it and found that others have had the same problem.
ASecretNinja is offline   Reply With Quote
Old October 3rd, 2009, 11:35 PM   #3
komohana
komohana's Avatar
thanx chad... didn't have any at the time but definately worth the doing...
and dang...did other's have theirs fail at night too??
Old October 4th, 2009, 08:16 AM   #4
nate-bama
North Alabama Mtn. ryder
nate-bama's Avatar
Motorcycle(s): 2006
Aloha Steve, Your not alone I've had mine back off from both ends, you don't need lock tite just use some slip joint pliers, get it hand tight and give it a little extra tourqe. hav't had it happen again
QTRltrPWR
nate-bama is offline   Reply With Quote
Old October 4th, 2009, 09:29 AM   #5
ninjabrewer
dirty old man
ninjabrewer's Avatar
Motorcycle(s): Blue '08 Ninja 250
Whew, for a minute there, that was a visual I didn't really want to see.
nb
Death tugs at my ear and says, "Live, I am coming." -Oliver Wendell Holmes, Sr., poet, novelist, essayist, and physician (1809-1894)
www.friendsofsanonofre.org
ninjabrewer is offline   Reply With Quote
Old October 4th, 2009, 09:35 AM   #6
addy126
Motorcycle(s): '09 Kawasaki N-250 + '09 Vulcan 900 Classic Lt
Same thing happened to my 2007 N-250. Just vibrates itself off. Screwed it back on up under the dash tightly and it behaved itself from then on. But its hell to get the angle when you are in a hurry. (doesn't it seem some things just end up seeming pornographic when you work on a bike)
addy126 is offline   Reply With Quote
Old October 4th, 2009, 12:45 PM   #7
Grn99Kawi
Grn99Kawi's Avatar
Motorcycle(s): 2000 Honda CBR600F4 (sold) 1999 Ninja 250 (sold)
Happened to me too a few months ago... got home, put it back on.. all good.. but apparently it is common!
2000 Honda CBR600F4 Silver and Red
1999 Kawi Racing Green Ninja 250 sold
Grn99Kawi is offline   Reply With Quote
Old May 29th, 2011, 03:34 AM   #8
Turtle
Turtle's Avatar
Motorcycle(s): 2002 Kaw Ninja 250/05 yama RSTD/03yama 1100 Classic
yupyup Happened to my wife yesterday. A pain to get to as well but I got it and a pair of needle nose latter had it back on and TIGHT this time I hope. Can always do the Loc-tite later if it happens again.
Turtle is offline   Reply With Quote
Old May 29th, 2011, 01:55 PM   #9
CZroe
CZroe's Avatar
Speedo Came Off!
GAH! My eyes! Didn't notice this thread the first time around.
Speedo Drd, Speedometer and Odometer Accuracy-Speedo Healer/drd Klondike1020 General Motorcycling Discussion 8 August 17th, 2014 12:23 AM
My speedo is way out! Damo990 2013 - 2017 Ninja 300 Tech Talk 14 March 5th, 2014 06:54 AM
Aftermarket speedo lowandslowcabby 1986 - 2007 Ninja 250R Farkles 5 May 25th, 2013 08:03 AM
Speedo Problem Ninja28 2008 - 2012 Ninja 250R Tech Talk 8 October 9th, 2011 05:16 PM
My speedo is off??? Kitdog 2008 - 2012 Ninja 250R Tech Talk 3 June 28th, 2010 03:24 PM
