Old January 13th, 2009, 08:49 PM   #1
K&N Drop In Filter Available for 08/09 Bikes
If you have been waiting for a drop in K&N filter for your stock airbox, they have finally arrived.
http://www.knfilters.com/air_filter/...50r_ninja.aspx
Old January 13th, 2009, 09:20 PM   #2
c_anglada
c_anglada's Avatar
hey do you know if the KA-2586 for the 2007 ninja fit the 08?
c_anglada is offline   Reply With Quote
Old January 13th, 2009, 09:27 PM   #3
LuckyDog
LuckyDog's Avatar
Motorcycle(s): Ninja 250r
Sweeeeeeeeeeeet. It shall be mine come payday.
LuckyDog is offline   Reply With Quote
Old January 13th, 2009, 09:35 PM   #4
kazam58
Sarcasm: Yea that'll work
kazam58's Avatar
Motorcycle(s): '08 Ninja 250R
Finally, I was waiting for this for a while. I didn't want to go with the pod route, but I didn't want the stock filter either.
kazam58 is offline   Reply With Quote
Old January 13th, 2009, 09:36 PM   #5
I would think it's different otherwise K&N wouldn't have made a new one for the 08/09s, but I'm guessing.
Old January 13th, 2009, 09:51 PM   #6
VeX
That's me!
VeX's Avatar
Motorcycle(s): 2008 Ninja 250r (Tis blue), 2008 CBR600RR
I don't know what is going to be different between the stock foam and the K&N filter. If the stock filter was a paper filter then I'd find the benefit, but honestly a properly oiled stock filter should filter ++ and should flow very well. It's the box that's the restriction.
VeX is offline   Reply With Quote
Old January 13th, 2009, 09:55 PM   #7
That would depend on the foam they use for the stock filter. Without any comparative testing, you can't say one way or the other.
Old January 13th, 2009, 09:57 PM   #8
kazam58
kazam58's Avatar
We've always used K&N Stock replacement filters on all our cars, and there seems to be a slight benefit, though hardly noticeable, at first. I just really enjoy the thought of never having to clean an air filter.
Old January 13th, 2009, 10:02 PM   #9
VeX
That's me!
VeX's Avatar
I'm just pointing out that paper-element filters are excellent filters as far as filtration goes, but they are restrictive. That's why cloth filters such as K&N are handy
A) They're washable and oilable (creating good filtration assuming the filter is oiled
B) They're durable
C) They flow well
Seeing as foam filters do just as well as cloth filters... With a 300hp car you might gain 5hp if you replace a FILTHY paper air filter with a cloth one, on a 30hp (I'm being optimistic) motorcycle thats .5 HP? But then again the factory filter isn't paper... So the gains should be significantly less
Old January 13th, 2009, 10:09 PM   #10
kazam58
kazam58's Avatar
lol, I understand. I don't plan on arguing over how beneficial it is, especially with a mechanic
Even if this new filter lets in just a little bit more air with a stock bike i'm afraid it might push it even further past it's already lean setting, so I'll be getting this with a jet kit. So, sadly, I won't be able to report any hp gains solely to the credit of the filter.
Old January 13th, 2009, 10:12 PM   #11
TnNinjaGirl
Ms. Personality
TnNinjaGirl's Avatar
I took my filter out and the foam seems a little dense. More dense than any other filter I've seen before. Good for filtration. ??? for airflow. I'm curious to see how the K&N would do.
Old January 13th, 2009, 10:14 PM   #12
And even in cars, different brand of foam filters will yield different hp results. Why? because of the foam density they chose to use for the particular filter they produce.
I'm not advocating that the K&N is "better" than a stock filter, only that it's finally available. You are the one saying that it won't produce any more power than the stock foam filter. While that may be true, you can't say that until it's been tested, which it hasn't.
lol... there are some that feel that pod/separate filters don't produce any more power than running with an airbox. I haven't seen any dyno tests, but I know for sure which is true.
Old January 13th, 2009, 10:18 PM   #13
kazam58
kazam58's Avatar
I am sure that pods will produce a lot more power. But once again they are going to be a whole lot more expensive, and the jetting will take a little longer to get right. Not to mention I'm sure you're getting slightly worse mileage with a bike that rich, something that I still enjoy about my stock ninjette
Also, more out of curiosity than anything, because i never saw a straight answer, do you have to worry about water with pods? sorry if it's a noob question, but I don't know the background behind this...
Old January 13th, 2009, 10:23 PM   #14
My feeling is that the only time you need to worry about water with the pods is if the water level reaches as high as the pods are on the bike. If you're riding in water that deep, you've got other things to worry about.
You could drop the bike and submerge the pods, but you would have the same problem with the stock airbox, too.
Old January 13th, 2009, 10:25 PM   #15
kazam58
kazam58's Avatar
haha, i feel like we had a similar conversation before, but concerning the snorkel removal.
Old January 13th, 2009, 10:30 PM   #16
VeX
That's me!
VeX's Avatar
I don't think the peak gains with pods is that great actually (lordy here we go ) It helps the bike rev faster and react better from me butt dyno. On my ride last weekend it seemed on turns Kuro and myself would both peg the throttle into the turn and I would instantly start catching up to him. If we were in an all out 'drag race' I doubt there would've been a difference. Snorkel removal is good because it's aiding the restrictive air box breath
Old January 13th, 2009, 10:42 PM   #17
So, did you try a drag race?? That would have been interesting as I know Kuro's bike only has been desnorkeled and the QC.
Old January 13th, 2009, 10:59 PM   #18
VeX
That's me!
VeX's Avatar
haha lordy this topic has derailed
He might have a slight advantage. He weighs like 95 lbs
Old January 13th, 2009, 11:04 PM   #19
and you weigh?
Old January 14th, 2009, 01:33 AM   #20
Kurosaki
Akai Suisei - 赤い彗星
Kurosaki's Avatar
Motorcycle(s): 08 Kurosaki 250, 09 Honda 600RawrRawr
I never pinned the throttle on that mountain. gtfo
Kurosaki is offline   Reply With Quote
Old January 14th, 2009, 01:37 AM   #21
next time you guys get together, try a drag race to compare bikes.
Old January 14th, 2009, 06:04 AM   #22
HKr1
IC2(SW)
HKr1's Avatar
40 or 50mph in 6th, then roll it on! That would be a good comparison
Old January 14th, 2009, 10:51 AM   #23
Sound Wave
Ramen Rider
Sound Wave's Avatar
so has anyone run an aftermarket filter without jetting? any noticeable problems? i understand the possible potential for running lean.
also, does anyone have a pic of the pod style filter installed on the 250? can't quite picture what it looks like installed....
Old January 14th, 2009, 12:51 PM   #24
"pod" type filter installed after the airbox has been removed.
You definitely need to rejet (or shim) with a pod filter setup.
With a replacement drop in filter you should at least shim the needles... which I feel should be done even on a stock bike.
Old January 14th, 2009, 01:48 PM   #25
Sound Wave
Ramen Rider
Sound Wave's Avatar
thanks! i understand now.
Old January 14th, 2009, 07:25 PM   #26
noche_caliente
noche_caliente's Avatar
Motorcycle(s): '08 250
http://www.google.com/products?q=KA-...-8&sa=N&tab=wf
$60! That's awfully expensive when I can get the pod-style for $35ish and a jet kit for around $60.....
Old January 14th, 2009, 08:03 PM   #27
lol...and spend a week tearing out that &)(*&^*$ airbox!!
This filter just slides right in.... and I'm sure you could find it for less than $60 if you hunt around.
Old January 14th, 2009, 08:11 PM   #28
kazam58
kazam58's Avatar
oh damn, i hadn't realized it was $60...i really hope other places have it cheaper than that...
Old January 16th, 2009, 08:58 AM   #29
HKr1
IC2(SW)
HKr1's Avatar
Pipercross mentioned they should have one out in the spring. < For those that have no love for K&N
Old March 21st, 2009, 12:49 AM   #30
Sound Wave
Ramen Rider
Sound Wave's Avatar
i decided to go for it and i purchased the drop-in filter. went for a 10 mile or so ride tonight to test it out.
first thing i noticed was that the bike sounds meaner now. at idle it sounded about the same, but other than that, it sounded more powerful... nothing really drastic, but noticable.
feels a bit quicker, but that might be psychological. i can say that it is DEFINITELY smoother now. not saying that the bike ran rough before... but as i am accelerating, it is really smooth.
i am very happy with this mod. it makes riding the bike more enjoyable. i was afraid that i was going to have to add another shim, but it isn't necessary.
just a note, i removed my snorkel and added two washers. still got the stock exhaust since someone else won my area p. :P
is the filter worth the money? to me it is.
Old March 21st, 2009, 02:52 AM   #31
Viper-Byte
Viper-Byte's Avatar
Motorcycle(s): 08 Ninja 250R in Green! (Sold) Now 2011 Triumph Daytona 675 SE
Thanks for that info Gary, I too am considering getting one of these.
2008 GREEN Kawasaki Ninja 250R.
AreaP Quiet Core Carbon Fibre : 8000k HIDs : Dynojet Jet kit : Double Bubble Windscreen
Viper-Byte is offline   Reply With Quote
Old March 21st, 2009, 05:17 AM   #32
Kurosaki
Akai Suisei - 赤い彗星
Kurosaki's Avatar
Did you do the filter at the same time as the snorkel and washers?
Old March 21st, 2009, 06:17 AM   #33
M-Oorb
M-Oorb's Avatar
Motorcycle(s): 2008 250r (Fastest Color)
Hmm I can't see just replacing the slide in filter having an affect on what the bike sounds like. Could you possibly be confusing that meaner sound with the sound produced by air induction from removing the snorkel.
Posted via Mobile Device
M-Oorb is offline   Reply With Quote
Old March 21st, 2009, 07:40 AM   #34
Snake
Snake's Avatar
You do not have to worry about water due to the fact that the oil impregnated in the filter repels water.
Old March 21st, 2009, 11:16 AM   #35
Sound Wave
Ramen Rider
Sound Wave's Avatar
no. i did the snorkel and washers a while ago. actually, i removed the snorkel first. the bike sounded good, but ran like crap at about the 6-8k range.... sort of hesitating... once i got above that range, the bike ran ok again. a week after that, i added 2 washers and the bike ran well. among other things, i was able to start off from a stop easier. the lurching at slow speeds were greatly reduced and it seemed to have a bit more pull in the lower rev range. when i put the drop-in filter last night, the bike ran even better. it ran smoother through the entire rev range and while maintaining freeway speeds. the induction note also changed more.
when i removed the snorkel a while ago, it did make the bike louder. when i changed out the air filter last night, it made it sound even better. a bit louder, but the main thing is that it changed the note.
disclaimer: i am not saying to buy it. i am just saying that i did and i am satisfied with the results. there isn't a HUGE difference, but it is definitely noticable.
Ninja 300 K&N Air Filter How To Install Tutorial & Quick Review Video SON1C 2013 - 2017 Ninja 300 Tech Talk 12 June 27th, 2014 07:15 PM
question drop in filter or shimming vmax 2008 - 2012 Ninja 250R Tech Talk 1 August 22nd, 2013 07:14 AM
08-12 Ninja 250 K&N drop in filter drunyon Motorcycle-related 4 December 17th, 2012 06:35 PM
K&N drop in air filter Zyconic17 Motorcycle-related 1 October 2nd, 2012 12:21 PM
k&n drop in filter question greatwhiteninja 2008 - 2012 Ninja 250R Tech Talk 14 June 8th, 2011 11:52 PM
