Old October 23rd, 2023, 06:45 PM   #1
Alexis_07ninja
Motorcycle(s): 2007 ninja 250
Clutch noise
On my 2007 ninja 250 someone pointed out that my clutch was rather noisy when the bike is idling in neutral and the clutch is engaged (lever out). We thought this was due to the hub nut being loose but after some searching I realized it was the rubber “bumpers” inside the clutch basket. I found the rubber remains of these bumpers in my oil screen about 5 months ago, not knowing what it was until now. My question is: will the absence of these bumpers do any real damage, or are they usually just replaced because of the annoying noise? Replacing the entire clutch basket is fairly expensive new, but I’m not guaranteed that the bumpers will be intact on a used basket. So far I haven’t noticed any damage in these last few months and actually don’t know how long the bumpers had been bad, since it was my first time checking the oil screen.
Alexis_07ninja is offline   Reply With Quote
Old October 25th, 2023, 02:32 PM   #2
Mohawk
Mohawk's Avatar
Motorcycle(s): ZZR250, VFR800
If its a 2007 pre-gen then its a known fault that the clutch dampers get brittle then break up. Then the clutch gets noisy & it sounds like bad big end bearings. I replaced the complete clutch on mine with a 2008+ model one which has buffer springs like most clutches, there is a thread on hear about it.
I don't believe the failed buffers cause any short term damage, but long term the lash may cause premature wear on the clutch basket due to the unbuffered knocking it gets.
Banging noise - Clutch? PJW 1986 - 2007 Ninja 250R Tech Talk 7 May 20th, 2021 09:40 AM
Noise with Clutch Out Kennylxix 1986 - 2007 Ninja 250R Tech Talk 27 November 9th, 2018 07:51 PM
Clacking Noise While Riding | Clutch Now Disengaged tunatrout General Motorcycling Discussion 7 September 27th, 2018 02:52 PM
Growling noise while going slow with clutch in Sarge1992 1986 - 2007 Ninja 250R Tech Talk 17 December 28th, 2015 07:52 PM
Weird noise transmission/clutch? help Choter 2008 - 2012 Ninja 250R Tech Talk 2 January 11th, 2011 07:52 PM
