Old June 5th, 2011, 04:46 PM   #1
bikertrash2001
Motorcycle(s): 1992 EX250, 2002 Yamaha Roadstar Warrior, 1973 Honda 450 Cafe
Are Ignition Boxes a Common Problem
Hey All,
New to the forum here, but personally an old fart. I got a 92 250 that my father-in-law had big aspirations for but never got around too. It's been pretty neglected, but for the most part, the innards of the motor look pretty good.
Anyway, when I finally got the carbs and tank degunked and set the valves, I got good fire on the left cylinder but a very erratic spark on the right. I could hook my timing light up to the wires and see it was pretty shaky. It would only run on full choke and then it was the left cylinder just dragging the right against it's will. I swapped the coils from side to side with no change. I took the wire from the ignition box (green) out and ran a straight wire from the box to the coil with no help either.
I don't see a lot of posts on here about ignition boxes being bad. And also by the fact that you can buy them on ebay pretty cheap speaks volumes. Usually if it's a common bad part, the prices are crazy.
Thanks!
bikertrash2001 is offline   Reply With Quote
Old June 5th, 2011, 06:02 PM   #2
The CDI is often flaky on the new-gens (2008+). Seemed to be more reliable in the older generation ninjettes. But any part can certainly fail, and perhaps it did here as well.
Tricky Ignition Problem smp 2008 - 2012 Ninja 250R Tech Talk 5 March 16th, 2015 03:07 PM
Fixing the common EX250F (pregen) tank leaking problem: Anyone in ATL wanna try w/me? CZroe Motorcycle-related 3 October 15th, 2012 08:02 PM
My Tach is still dead, common problem.. JoeLansing 2008 - 2012 Ninja 250R Tech Talk 10 August 4th, 2011 09:10 PM
problem with ignition? onizthegnome 2008 - 2012 Ninja 250R Tech Talk 8 May 5th, 2011 06:10 PM
Ignition problem nilo 2008 - 2012 Ninja 250R Tech Talk 8 January 9th, 2011 04:23 PM
