May 8th, 2014, 09:15 PM | #1 |
Kawasaki Sith Lord
Name: Alex P. Keaton
Join Date: Mar 2014 Motorcycle(s): 2009 Ninja 250R Posts: 62
Yoshi TRC Slip-On..
Does anyone have the Yoshimura TRC slip-on?
I've seen many a youtube vid on it but was hoping for some first-hand accounts. I'm looking for a loud exhaust, tired of the stainless steel stock silencer. |
May 8th, 2014, 11:48 PM | #2 |
Join Date: Jan 2012 Motorcycle(s): 2012 ninja 250r se Posts: 435
I have a Yoshimura TRS slip-on exhaust
Same but different end. Shimmed the carbs with 3 washers, Kn filter, restrictor until i brought a jet kit. little lean Yoshi stage 2 jetkit, Kn filter, restrictor with recommended 98 jet and 2.5 turns out. rich Removed exhaust restrictor, snorkel removed, picked up mid range throttle response. Close to perfect. A little loud. BUT i LIKE IT Annoyed that i didn't go with Yoshi TRS full exhaust right from the start, due to pulling most of the fairings off to remove the carbs for the jet kit install. |
May 19th, 2014, 08:25 PM | #3 |
Join Date: Mar 2014 Motorcycle(s): Currently own: 98 Honda VTR1000, 02 Suzuki's DR200 & DR650, 04 & 08 BUSA's, 05 Ducati SS1000, 12 Ninja 250R SE Posts: 59
I have the TRC full system with carbon fiber canister installed on my 2012 Ninja 250. Huge improvement in sound quality! A little on the loud side. A dB killer insert is provided to reduce the sound level if so desired -
May 19th, 2014, 08:50 PM | #4 |
Join Date: May 2013 Motorcycle(s): '75 CB550:.'82 XV920:.'00 KLR650:.'00 EX250:.'08 Ninja 250 Posts: A lot.
MOTM - June '15
My bike came with the yoshimura CF slip on,I like the way it sounds
'82 XV920: Soon to be tracker--'00 KLR685:adv --'04 DRZ400E--'12 Super Tenere --'13 Versys Ride more, worry less. |
May 22nd, 2014, 03:45 PM | #5 |
Kawasaki Sith Lord
I wonder does the full exhaust sound any better than the slip on exhaust?
May 22nd, 2014, 05:56 PM | #6 |
Ninjette Jockey
Join Date: Oct 2010 Motorcycle(s): Ninja 250R, Harley Davidson Heritage Softail, 2 Honda Monkeys, Polini & GRC mini GP Posts: A lot.
I bought the Yoshi slip-on, then soon after bought the Yoshi full system. I can't tell the difference in sound between them. Yoshi mufflers have a noise reducer that slips in. Without it, you can wake the dead. With the insert in place, it sounds louder than stock, but not annoying. The slip-on gives you more noise, the full system gives you more power!
For what shall it profit a man, if he shall gain the whole world, and lose his own soul?. |
May 24th, 2014, 07:05 PM | #7 |
Kawasaki Sith Lord
did u rejett or get anything done in addition with the full yoshi exhaust? or does the full exhaust just by itself give more power?
May 24th, 2014, 08:09 PM | #8 |
Slip-on,
depends on what altitude you live at you "COULD" get away without. May get away with shimming the needles with 2 washers. Full system, you have too the bike will go lean and destroy a head or engine. Jet kit definitely needed. dyno-jet stage 2 2193 and stage 3 2393 http://www.dynojet.com/jetkits/motorcycle/kawasaki.aspx |
May 25th, 2014, 09:45 PM | #9 |
Join Date: Jul 2012 Motorcycle(s): 2010 Ninja 250 2009 Ninja 250 Posts: 730
I have both. One bike with a full system and one with just a slip on.
Most people would say they can't tell. I can tell/ hear a difference. Trying to explain it online isn't soo easy.
2010 Red Ninja 250 2009 Black Ninja 250 -If you ride like lightning,you're gonna crash like thunder- |
May 27th, 2014, 02:40 PM | #10 |
Kawasaki Sith Lord
Well you would be the person to ask the next question.. Id like to do a full system but by the time I add up the exhaust, the jet kit, and pay someone to tune it right I don't know if its worth the price for the hp gain. I can just put a slip on for minimal cost and at least have a good sound.
May 27th, 2014, 03:31 PM | #11 |
I will say I absolutely love the sound of my full system. Just like what you stated above , that's why the other bike got the exact kind of slip-on.
Wether or not you need to shim needles or etc... That's up to you As far as sound goes , yes , it's great. Performance , I don't know. My full system "feels" stronger
May 28th, 2014, 08:28 PM | #12 |
Join Date: Oct 2013 Motorcycle(s): 2009 Kawasaki Ninja 250R Posts: 219
how can you tell if you have the full system or just the slip on?
when i purchased my bike it had the TRC on it already, but I never thought until now if I had the full or just slip on... image of my bike below for visual help |
May 28th, 2014, 08:37 PM | #13 |
Look at your header. Is it chrome?
May 28th, 2014, 09:04 PM | #14 |
just to confirm, the header is the pipes leading from the engine to the beginning of the exhaust?
here is an image that you should be able to tell. looks like it was possibly chrome at one point, but has a bit of dirt/rust on it now... hard to tell |
May 29th, 2014, 05:32 PM | #15 |
Kawasaki Sith Lord
Correct me if I'm wrong but I believe the pipes (they curve along the bottom from the front) on a FULL exhaust are larger than the stock. Of course how can you know if you have nothing to compare it to.
May 31st, 2014, 10:17 AM | #16 |
exactly lol. i have no idea if mine are the stock pipes or part of the set. not a clue
May 31st, 2014, 05:42 PM | #17 |
I just installed the dB killer insert. It reduces the sound level considerably.
Restrictive but easier on the ears. Still sounds awesome! |
May 31st, 2014, 08:18 PM | #18 |
Nice !
Sooo where did ya get it and how do you install it?
May 31st, 2014, 08:40 PM | #19 |
The dB killer insert is included with the Yoshimura TRC full system exhaust. It took a bit of persuading to get it in the end of the canister and lined up with the hole for the 6mm hex head screw that's provided to hold it in place.
I used a 6mm bolt instead. |
May 31st, 2014, 08:51 PM | #20 |
Ahh ok. Yup. Don't have that part lol
May 31st, 2014, 08:55 PM | #21 |
I thought it should be included with just the TRC canister also.
Maybe it's available from Yoshimura?? The sound is quite subdued with it installed. I like it! |
May 31st, 2014, 09:04 PM | #22 |
Hmm Maybe I should make a WTB thread in the market section. Hopefully somone has an extra one laying around they would like to sell
Thanks!
June 2nd, 2014, 07:36 AM | #23 |
Any way you can make a video with the new sound? This may be something I am interested in getting. At times, I dont like the loudness of my exhaust. Especially when I am on the back country roads where it is nice and quite.
June 2nd, 2014, 05:56 PM | #24 |
The cool exhaust note is the same with the insert, but the sound intensity is way less.
Inserts are available from Yoshimura - http://www.yoshimura-rd.com/prodcat/...nt-inserts.asp |
June 2nd, 2014, 08:19 PM | #25 | |
In for sound clips
June 4th, 2014, 08:56 PM | #26 |
Kawasaki Sith Lord
Yeah I'd love to get a full system but between that, the re-jett, and the install price I'd be at like $600-$700..
FS/FT: 08+ Yoshimura TRC Carbon Fiber Slip-On | radi4fun | Motorcycle-related | 7 | July 5th, 2013 02:30 PM |
Yoshi TRC slip on | IconChris | 2008 - 2012 Ninja 250R Tech Talk | 7 | April 17th, 2013 06:02 PM |
Yoshimura TRC Slip-On for Ninja 250 | Bones85 | Motorcycle-related | 2 | February 9th, 2013 12:21 AM |
Yoshi TRC Cf full exhaust ninja 250 08 | wellcraft | 2008 - 2012 Ninja 250R Tech Talk | 8 | August 3rd, 2010 09:10 PM |
Yoshi TRC Cf full exhaust ninja 250R | wellcraft | General Motorcycling Discussion | 7 | January 23rd, 2010 06:40 AM |
