#1 |
Join Date: Oct 2013 Motorcycle(s): 2009 Kawasaki Ninja 250R Posts: 219
Quick question
When initially turning the key to on before starting the bike, the temperature warning light should illuminate correct? I cant remember if it should, but if I remember correctly, I think it should.
Since changing my dash bulbs to leds this weekend, I noticed the temperature warning light no longer turns on when turning the key to on. Prior to the change to LEDs, i believe the temperature warning light did illuminate when turning the key to on. I think I put the led bulb in backwards, so I will need to switch it around next chance I get. |
#2 |
I can't say for sure in your case, but typically all of the "idiot lights" illuminate on most vehicles when you turn the key to the ON position to tell you that they are all working and not burned out.
#3 |
Join Date: Sep 2013 Motorcycle(s): 2012 Ninja 250R Posts: 12
Yes... The temp light does come on when the key gets turned to the on position...
#4 |
i'll have to take the black tape off of the lights on my dash and see if they come on when i first start it.
#5 |
#6 | |
Question answered. Thanks guys |
quick question | Electronic M | 2013 - 2017 Ninja 300 Tech Talk | 57 | March 17th, 2015 04:41 AM |
Quick Question | PsHYk | 2008 - 2012 Ninja 250R Tech Talk | 3 | June 10th, 2012 02:58 PM |
Just a quick question | zooman | 2008 - 2012 Ninja 250R Tech Talk | 12 | May 18th, 2012 10:52 PM |
Quick Question! | shiftdrift06 | 1986 - 2007 Ninja 250R Tech Talk | 4 | March 1st, 2012 08:31 PM |
some quick brake question | reaperw | 2008 - 2012 Ninja 250R Tech Talk | 1 | June 21st, 2011 08:42 PM |
