Old October 5th, 2020, 05:15 AM   #1
ssrsupermoto
Motorcycle(s): 2004 Ninja 250
Offset keyway ignition advance question
Anyone done the ignition advance offset key way on a 88-07 ninja 250 from Factory Pro? I am reading the instructions and it says the offset needs to be to the right. I believe the motor spins counter clock wise, so wouldn't having the offset to the right of the key way slot be retarding the timing? Any help is appreciated I only have one generator cover gasket and want it on correct the first time.
Last futzed with by ssrsupermoto; October 5th, 2020 at 07:08 AM.
ssrsupermoto is offline   Reply With Quote
Old October 5th, 2020, 05:42 AM   #2
Originally Posted by ssrsupermoto View Post
Anyone done the ignition advance offset key way on a 88-07 ninja 250?
Are you talking about using an offset key, or cutting the keyway on the flywheel wider? Anything that doesn't let the engine turn as far before the spark happens will advance the timing, so if you cut the keyway in the flywheel "to the right", it will be rotated on the crankshaft counterclockwise from stock, causing more advanced timing. Then if you cut the keyway wider you'd have to either use a key with a wide half, or trust friction to keep the flywheel in the right place.
Of course if you remove the flywheel and look at the keyway, that "to the right" becomes "to the left".
Old October 5th, 2020, 07:08 AM   #3
ssrsupermoto
Using the kit purchased from Factory Pro using the offset key way.
Old October 5th, 2020, 07:38 AM   #4
I'm not familiar with that kit, but as long as you position the flywheel more counterclockwise relative to the crankshaft than stock, the spark timing will be more advanced.
Old October 5th, 2020, 07:52 AM   #5
ssrsupermoto
Do these engines spin clockwise or counter clockwise
Old October 5th, 2020, 09:00 AM   #6
They follow the standard of turning the same way as the wheels.
Old October 5th, 2020, 10:06 AM   #7
ssrsupermoto
So counter clockwise. Wouldn't putting the key way offset to the right moving the flywheel according to the instructions be retarding the timing?
Old October 5th, 2020, 10:41 AM   #8
Yes, want key to left to advance timing.
Factory Pro messes up A LOT. Such as sending pre-gen needles with their new-gen jet kits, wrong-sized jets, etc.
Old October 5th, 2020, 10:54 AM   #9
Why do you think they call dyslexia "the silent killer"?
Old October 5th, 2020, 01:24 PM   #10
yeah, I have lexdysia too! Sometimes I get lost and end up riding in circles... for hours!
Old October 23rd, 2020, 08:47 AM   #11
SibSerge
I will remember this "disorder" name when I need to find an excuse for my wife on why I was away riding for so long.
07 ninja 250 ignition switch question. NewtoNinjettes 1986 - 2007 Ninja 250R Tech Talk 26 October 9th, 2019 08:06 PM
07 ninja 250 ignition switch Ninja 500 Ignition switch question. NewtoNinjettes 1986 - 2007 Ninja 250R Tech Talk 0 September 30th, 2019 01:31 PM
2012 ninja 250R ignition coil question webfoot 2008 - 2012 Ninja 250R Tech Talk 5 June 22nd, 2014 10:18 PM
woodruff offset key for timing advance? Lucagst 2008 - 2012 Ninja 250R Tech Talk 4 February 13th, 2013 08:25 PM
Milwaukee Offset Screwdriver THE BIG SITT Items Wanted 9 January 8th, 2012 03:35 PM
