Old August 13th, 2012, 10:04 AM   #1
Old Lemon
Lays er down
Old Lemon's Avatar
Motorcycle(s): 2008 Lime green Ninja 250R
need help with koso gauge
I installed everything and everything works except the speedo. It says im going 90 out of my drive way. I changed the circumference setting with the sensor point setting to 2 (which i still have no idea what it does). i changed the piston setting to 4 cylinder 2 stroke. i have the plug and play kit and directly attached the speedo cable to the adapter and its plugged into the 3 pin connector.
So do i need to install the magnet on my wheel if i have the adapter for the existing speedo cable?
Old Lemon is offline   Reply With Quote
Old August 13th, 2012, 12:37 PM   #2
k-os
You want the 4 Stroke, 2 Cylinder setting.
Old August 13th, 2012, 12:40 PM   #3
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
I want a 2 stroke 4cyl 250
AFM #676
Supersports are for n00bs
Old August 13th, 2012, 12:40 PM   #4
dubojr1
dubojr1's Avatar
and you should have used 6 magnets. The setting should be set to 6 and not 2. Also re-measure your circumference and check that setting as well.
Old August 13th, 2012, 12:41 PM   #5
dubojr1
dubojr1's Avatar
You can't handle one...
Old August 13th, 2012, 12:50 PM   #6
Jiggles
Jiggles's Avatar
MOTM - Apr '13
Your face can't handle one!
AFM #676
Old August 13th, 2012, 12:51 PM   #7
k-os
The sensor point setting tells the gauge how many times it should check for a signal during one rotation of the tire. Therefore if you have it set to 2, then there should be two magnets on your rotor and they should be 180 degrees from each other.
Old August 13th, 2012, 12:59 PM   #8
ninjagaiden09
ninjagaiden09's Avatar
Motorcycle(s): 2011 Ninja 250r
If you are using the plug and play wiring for the 250 and using the adapter that comes within that goes to the speedo cable then you don't have to use the magnet.
here is the settings
I have the same set up and it's accurate I compared it to my GPS.
Hope this helps.
ninjagaiden09 is offline   Reply With Quote
Old August 13th, 2012, 01:04 PM   #9
Old Lemon
Lays er down
Old Lemon's Avatar
Hope this helps.
Yea I read the post before anyone replied to this thread, and I got reasonable readings after that. My buddy is gonna follow me in his car with a gps accurate speedo and see how it compares. Thanks guy and yea I had it set to 4 stroke 2 cyl, typo
How long have you had your Koso gauge? CThunder-blue 2008 - 2012 Ninja 250R Farkles 8 July 10th, 2012 01:40 PM
GB Koso Gauge Brackets gt_turbo Motorcycle-related 26 June 15th, 2012 11:54 PM
Koso gauge and clipons randomwalk101 2008 - 2012 Ninja 250R Tech Talk 0 November 7th, 2010 08:00 AM
Koso gauge randomwalk101 Motorcycle-related 7 November 5th, 2010 07:28 PM
Koso gauge kit GB wellcraft Motorcycle-related 56 April 29th, 2010 07:31 PM
