May 25th, 2013, 07:17 PM | #1 |
Hello Moto
Join Date: Mar 2013 Motorcycle(s): 1975 RD350; 2001 KX125; 2003 Z1000; 2003 KDX50; 2009 ZX6R; 2011 Ninja 250R; 2014 KX250F Posts: 352
Forks from 08-12 250 fit a 300?
I understand the internals are different but are the dimensions the same? It is much easier to find a set from a new gen 250.
May 25th, 2013, 07:30 PM | #2 |
Join Date: Nov 2012 Motorcycle(s): Ninja 300, KTM EXC610SMR Posts: 913
Should bolt right on.
May 27th, 2013, 06:30 PM | #3 |
the left fork bottom on the 250 is different. because of the speedo mount. but its pretty close.
May 27th, 2013, 06:57 PM | #4 |
I missed that, but they should bolt up to the 300 without issue, just use the 300's wheel spacers.
May 27th, 2013, 07:42 PM | #5 |
Join Date: Feb 2011 Motorcycle(s): Green 2013 ZX-6R Posts: 723
They do, I've done it.
http://www.simplysurrealphotography....es/peanut2.png |
May 27th, 2013, 07:55 PM | #6 |
Hello Moto
I have two 250s and now a 300 side by side in my garage...as well as a few others and they look like the same with some aesthetic changes and the lack of a speedometer.
Glad to hear it bolts up. I just got this 300 and its pretty trashed. I am debating whether or not to rebuild it or part it out. |
May 28th, 2013, 07:26 AM | #7 |
Crashed thrashed?
May 28th, 2013, 07:38 AM | #8 |
Hello Moto
May 28th, 2013, 09:03 AM | #9 |
I meant is it thrashed because it was violently crashed...
Or did someone find the time in the last 7 months to beat the living snot out of one? |
May 28th, 2013, 09:12 AM | #10 | |
Hello Moto
Within the first 200 miles the PO was mid turn when hitting a sand patch caused a low side crash at about 40mph. When the bike went from pavement to the grass median it flipped a few times utterly destroying the front end. I have never seen a crash cause the ignition switch to break. |
May 28th, 2013, 11:02 AM | #11 |
Sounds like a good time to swap on a better front end. Nothing too fancy, a Ninja 650 front end would be dramatically better IMO.
With the fragility of the plastics I bet it showered shards for an hour post accident! |
250 Pistons fit in 300? | sprinter | 2013 - 2017 Ninja 300 Tech Talk | 4 | August 6th, 2013 08:40 AM |
zzr 250 forks | agent of orange | 1986 - 2007 Ninja 250R Tech Talk | 9 | June 29th, 2013 01:15 PM |
ZZR-250 Forks? | htdub | 1986 - 2007 Ninja 250R Tech Talk | 3 | June 21st, 2012 12:20 PM |
