Old December 13th, 2014, 03:25 PM   #1
Jason5885
Jason5885's Avatar
Motorcycle(s): 2010 Kawasaki Ninja 250r FI
Angry Can't get front sprocket cover off
Cleaned and lubed my chain today, and thought I'd give the sprocket a clean.
I unscrewed the 3 bolts and also took the gear lever off.
From the videos I've watched the cover should then easily slip off, but the damn thing seems welded on!
The top half will budge a cm or 2 when I wiggle it but the bottom half is stuck flush.
Please help
Thanks guys.
In other news, I fitted my power commander 5, k&n air filter and found the source of my solid turn signal problem.
Jason5885 is offline   Reply With Quote
Old December 13th, 2014, 03:34 PM   #2
NevadaWolf
Certified looney toon
NevadaWolf's Avatar
MOTM Jul '13, Jul '14
Don't believe the videos! Sucker is epoxies on there from all the gunk.
My trick is to stick a long screwdriver between cover and the frame and gently rock it back and forth to loosen the cover. Eventually it gets loose enough to pull straight out.
<-- Linky
Old December 13th, 2014, 03:38 PM   #3
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
nah man, it's hard as hell to remove the first time. After that it's easy, just make sure the pressure you're applying is even and straight out
Old December 13th, 2014, 05:00 PM   #4
Persistent WD-40 or ATF on location pins and shifter shaft, then rubber hammer.
Old December 13th, 2014, 08:50 PM   #5
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
brake clean and a rubber mallet should do the trick.
TEAM ALFALFA
www.apexassassins.com
Old December 15th, 2014, 07:08 AM   #6
Jason5885
Jason5885's Avatar
WIll try again later in December when i can get time off work again. Thanks guys. Hitting the gear shaft with a rubber hammer/metal covered in a towel shouldnt damage the gears should it?
Old December 15th, 2014, 08:34 AM   #7
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
you shouldn't be hitting any moving parts, you should be tapping the cover.
TEAM ALFALFA
Old December 15th, 2014, 10:12 AM   #8
Jason5885
Jason5885's Avatar
I got you. Thanks
Old April 4th, 2021, 04:33 PM   #9
JayVapes
JayVapes's Avatar
Motorcycle(s): Ninja EX250
Im encountering this problem at the moment, im going to use some pb blaster and pry it off.
RIDE IT UNTIL THE WHEELS FALL OFF, THEN BUY NEW WHEELS
JayVapes is offline   Reply With Quote
Sprocket Cover Inspiration ninjakuma Pictures 5 July 27th, 2014 01:41 PM
Sprocket cover removal 675Raisinator Ninjettes At Speed 3 January 24th, 2012 12:58 PM
Front sprocket, help!! cbowman78 2008 - 2012 Ninja 250R Tech Talk 34 November 14th, 2010 10:52 AM
Sprocket cover demp 2008 - 2012 Ninja 250R Tech Talk 4 September 10th, 2010 06:36 PM
