February 1st, 2015, 11:43 PM | #1 |
Join Date: Feb 2015 Motorcycle(s): 2006 Kawasaki ninja ex250 Posts: 4
Low oil--->Killed engine--->What happened?
Previous owner took a 2006 kawasaki ninja ex250 on a long road trip and it died along the way. Just stopped working. One cup of oil was left I when they drained it.
I'm not too familiar with motorcycles but I managed to take apart some of the engine and I have a couple ideas what happened. This screw looks like it popped out and got wedged beneath the piston. I can't get anything to spin. I really want to fix it. What do you think I can do? |
February 1st, 2015, 11:45 PM | #2 |
This is what I found when i took the top end off.
February 1st, 2015, 11:46 PM | #3 |
Anddd this
February 2nd, 2015, 12:06 AM | #4 |
crash 250, get supersport
Join Date: Apr 2010 Motorcycle(s): 2010 250R SE (Sold 6/9/14), 2009 ZX-6R (Sold 6/25/14), Subaru BRZ Posts: A lot.
Mother of god.
February 2nd, 2015, 12:20 AM | #5 |
Ambrosia.
Join Date: Aug 2011 Motorcycle(s): 1974 Honda CB550K0 W.I.P. Posts: A lot.
Chuck it in the trash can and hope the trash guy doesn't question you when it sounds like a bomb went off in the truck.
Then get a replacement engine.
Life's better on the Mountain. |
February 2nd, 2015, 12:50 AM | #6 |
Join Date: Jan 2014 Motorcycle(s): SC28 Fireblade Posts: 463
Just by another used engine. I think the 250's go for $500 or less on ebay or cycle salvage.
94 900RR 04 BMW Z4 2.5 M Package 01 R170 AMG Sport Package |
February 2nd, 2015, 03:39 AM | #7 |
Thanks for the advice. Still have a question though.
What happened to it and how do you fix it? From the responses, it's obviously not worth to keep it but I'm still curious what happened and how people fix this problem. |
February 2nd, 2015, 06:27 AM | #8 |
OK, at a guess:
Connecting rod bolt falls out (how that happens in the first place is anyone's guess) Bolt starts getting kicked around the the crankshaft, doing major damage to the inside of the crankcase At some point bolt gets wedged somewhere it doesn't belong. Irresistible force meets immovable object. Stuff breaks (liners and piston). More shrapnel. How do you fix it? Well, that depends on what damage got done. The block itself may be damaged beyond repair. Ditto the crank, rods, bearings... you name it. The cylinder sleeve itself is destroyed. I don't even know if it's possible to replace that. This engine is toast, IMHO.
February 2nd, 2015, 08:46 AM | #9 |
Nicely done, now that's a blown engine, and your in the market for a used engine for sure.
February 2nd, 2015, 08:59 AM | #10 |
Lostcause enthusiast
Join Date: Jan 2015 Motorcycle(s): 2000 EX250F Posts: 178
WOW
that thing is smoked. yeah you'd probably end up replacing more parts in that than the parts you keep... a new engine is in order. Still, don't throw it out, part whats left out, people on the forums are always looking for odds and ends screws, ya never know. You can probably get enough money out of selling the head, carbs and generator/flywheel to pay for a whole new engine. |
February 2nd, 2015, 11:00 AM | #11 |
Inline 4!!!
How many miles were on the engine? That is crazy. Ninja 250's are cheap as hell in working order, never mind a replacement engine. Just cut your losses and buy a used engine and throw that sucker in.
February 2nd, 2015, 11:05 AM | #12 | |
what happened? a bolt came out and destroyed everything. what caused the bolt to come out? this is a big question that none of us will probably ever know the answer to. maybe a bad service, maybe a manufacturing flaw. who knows. it dun broke and most of the rotating assembly is probably compromised.
February 2nd, 2015, 01:43 PM | #13 |
Participant
I've seen and heard it happen in a couple of cars. Someone likely had been in the bottom end in the past (but why?).
Sound-wise, it starts with a metallic rapping at high RPMs. Then it gets worse and occurs at lower RPMs, too. Then, BANG. Instant lock-up. Toast. |
February 2nd, 2015, 01:50 PM | #14 |
I'm crazy,your excuse is?
if the bottom end starved for oil so did the cam and cam journals so those are likely toast as well. Do a WTB thread here, a member will surely hook you up with a good runner.
February 2nd, 2015, 05:31 PM | #15 |
Most likely a connecting rod bolt snapped and caused hell on the bottom end of the engine.
Something like this happens when you let the oil levels get too low and starve the engine of lubrication, something had to give and it ended up being a connecting rod bolt. |
February 2nd, 2015, 06:10 PM | #16 |
Join Date: Nov 2014 Motorcycle(s): EX250, Suzuki Savage, 76 Goldwing restoration project, 71 CB350, 73 Yamaha GT1, Posts: 73
Louis,
If you were going to fix it, that engine is basically trash,as has been said, you'll need a complete tear-down. Check all bearings (low oil, they probably are bad), if the crank looks ok, have it checked for true then checked for hidden cracks, check the bearing journals, they probably are toast with no oil. While it's apart, check out all the transmission gears, sliders, and bearings. You'll probably find a gear or two with teeth missing since that shrapnel went to the trans too. Check the block for cracks, especially around where you found broken bits. If all is ok in there. You might be able to get away with rods, rod bearings, crank bearings, pistons, rings, cylinders, new timing chain, new guides(might as well since you are in that deep). If the cams, journals, lobes, and followers all are ok, check the head for warp. If flat, reinstall. Just the parts you know you'll have to get will probably cost as much or more than a running bike. I could be fixed...it's just not economically sensible to attemp to do it. If the block is good everything in it can be replaced if needed. It'd just cost more than the new price of the bike to build the engine from spare parts. Like everyone else said, find a different engine. It will be easier and less expensive in the long run. |
February 2nd, 2015, 06:52 PM | #17 |
Ambrosia.
My guess is that it seized up from no oil, and put enough stress on the rod to pull out a bolt. When it did go, it snapped the piston up and cracked the sleeve.
February 3rd, 2015, 02:50 AM | #18 |
Down Under
Join Date: Jun 2014 Motorcycle(s): Kawasaki ZXR250C Ninja Posts: 296
That engine is kaput - source a second hand one
February 6th, 2015, 12:23 PM | #19 |
Join Date: Sep 2013 Motorcycle(s): 2006 Ninja 250 Posts: 47
Interesting how the liner got eaten but the pistons look good other than the one that is missing a big chunk of the skirt. Start fishing in the bottom end for the pieces and lay them out. I'm interested in what you find. Usually, it would look a lot worst than that, like a 12ga was pumped into each piston, especially for an engine that cruises at like 7k RPMs. How do the rods look?
what should i expect... (low/no oil) | sixer | 2008 - 2012 Ninja 250R Tech Talk | 21 | March 8th, 2012 07:34 PM |
Oil level -- how low is too low? | adouglas | 2008 - 2012 Ninja 250R Tech Talk | 8 | October 18th, 2011 06:51 PM |
Problem - low oil? | ninjaman | 2008 - 2012 Ninja 250R Tech Talk | 18 | September 29th, 2011 06:33 AM |
Oil and Temp light on after low side | dznuts | 2008 - 2012 Ninja 250R Tech Talk | 2 | May 2nd, 2011 05:57 AM |
Low oil pressure during braking | Guinss | 2008 - 2012 Ninja 250R Tech Talk | 11 | May 29th, 2010 08:47 AM |
