Old June 10th, 2015, 11:56 AM   #1
kris5495
kris5495's Avatar
Motorcycle(s): 2008 ninja ex250r
Unhappy Bike is dead!
I drove a ll day today and when i stopped at my recruiting station to talk i came back out and it wouldn't start the lights don't come on the horn doesn't work nothing i already checked the battery and all the fuses under the seat i also heard a *ca-chic* noise when i turned the key from off to on
the most powerful ass is the one behind you.
kris5495 is offline   Reply With Quote
Old June 10th, 2015, 12:00 PM   #2
DEFY
ᗧ•••ᗣ•ᗣᗣ•••ᗣ
DEFY's Avatar
When you turn the key to start does the red led (oil light) or green(if in neutral) on the front dash come on?
Spoiler for topic:
It might just be the [you] tag
Old June 10th, 2015, 12:03 PM   #3
How did you check it?
Chances are it's the battery, but you need a volt meter to check it. You need to check it as you put a load on it - turning on the ignition or hitting the starter button. A battery can read full charge while not under load, then drop-off completely as soon as a load is applied.
You may want to look closer at the fuses also.
Old June 10th, 2015, 12:28 PM   #4
kris5495
kris5495's Avatar
no they dont
Old June 10th, 2015, 12:28 PM   #5
kris5495
kris5495's Avatar
i checked it with a volt meter and it was 13.2 volts
Old June 10th, 2015, 12:31 PM   #6
DEFY
ᗧ•••ᗣ•ᗣᗣ•••ᗣ
DEFY's Avatar
Battery, go to advanced/auto zone. They can load test it, however it can't even draw enough current to turn on an led so All that voltage but no current to draw. Unless it is disconnected.
Spoiler for topic:
Old June 10th, 2015, 12:38 PM   #7
kris5495
kris5495's Avatar
Okay i will try that when i get done with pt today
Old June 10th, 2015, 02:58 PM   #8
Battery. Confirm the connections to it are snug, and then it comes down to the condition of the battery itself.
Old June 10th, 2015, 03:04 PM   #9
Mountain Dew
Ambrosia.
Mountain Dew's Avatar
Motorcycle(s): 1974 Honda CB550K0 W.I.P.
Sounds like one of the battery cables is loose. The ca-chic noise may be a solenoid or relay clicking because it doesn't have a solid connection.
Same thing happened with my truck, both when the battery cable clamps were worn out (not clamping enough to make a good connection) and when the bolts were loose.
I'd recommend actually getting a wrench on the bolt and verifying it's tight. Just trying to wiggle it may not show any movement.
Also check for loose grounds, wherever they may be.
Life's better on the Mountain.
Mountain Dew is offline   Reply With Quote
Old June 10th, 2015, 03:11 PM   #10
Was that with the ignition in the "ON" position?
If so, it would seem to be a connection problem.
Old June 10th, 2015, 05:04 PM   #11
kris5495
kris5495's Avatar
Well i switched out the battery and whippdy dippdy do it works time to go ride! thanks for all of your help!!!!
Old June 10th, 2015, 06:26 PM   #12
xorbe
xorbe's Avatar
Was the battery old and dead, or is the charging circuit kaput?
Old June 10th, 2015, 07:22 PM   #13
kris5495
kris5495's Avatar
old and dead
[SPOILER] The Walking Dead - New Bike akima Pictures 13 April 9th, 2015 03:40 PM
dead bike smrr1 1986 - 2007 Ninja 250R Tech Talk 16 December 1st, 2012 06:22 PM
[urgent] my bike is dead. Very dead. Now what? arnoldc6 Riding Skills 15 September 8th, 2012 08:04 AM
New Ninja owner, my bike may be dead :( Ikoniak 1986 - 2007 Ninja 250R Tech Talk 10 October 8th, 2011 08:02 PM
15 miles on new bike = dead tach JoeLansing 2008 - 2012 Ninja 250R Tech Talk 7 June 12th, 2011 03:31 PM
