Old April 30th, 2018, 12:30 PM   #1
basspunk1001
Motorcycle(s): Ninja 250r
Erratic Idle
Hi all, I'm trying to track down a cause for a strange issue I'm having on my '05 250r. During cold startup my idle will vary wildly between 1200 RPM and 4500 RPM when on choke. It seems to hunt and peck for a consistent RPM but never seems to level out. I've also been unable to achieve a consistent idle at warm, but it's a slightly different issue. Each time I come to a stop the engine will idle at a different RPM, typically somewhere between 1200 and 2500 RPM, but it will hold at that RPM. Any clue what the heck is going on?
basspunk1001 is offline   Reply With Quote
Old April 30th, 2018, 01:09 PM   #2
Hi and welcome!
Hmmm, could be multiple issues:
- sticky slides
- vacuum leak
- leaking vacuum hoses
- clogged fuel circuits
- clogged jets
- incorrect pilot-screw settings
Old April 30th, 2018, 01:59 PM   #3
basspunk1001
I've checked both the boots and hoses for vacuum leaks and didn't find any, I guess it's probably time to pull the carbs and take a peak inside.
Old May 1st, 2018, 06:28 AM   #4
How old is the gas? Has it been sitting with a low level of fuel?
Bad gas or condensation in the tank can cause what you described.
Adjusting the idle mixture screws to the optimum setting is will help it idle smoothly, as will precisely synced carbs.
Bike not idling below half choke, idle screw not affecting idle speed Zaraki_Kenpachi 1986 - 2007 Ninja 250R Tech Talk 2 March 6th, 2020 11:13 AM
Gas smell and erratic idle Noobman 2008 - 2012 Ninja 250R Tech Talk 5 May 25th, 2014 10:57 PM
Erratic idle Jefft 2008 - 2012 Ninja 250R Tech Talk 4 November 4th, 2013 12:38 PM
Sluggish rev, erratic idle, dies with throttle Fappy 2008 - 2012 Ninja 250R Tech Talk 12 October 8th, 2012 06:20 AM
Erratic idle, wont start cold, etc. d16soda 1986 - 2007 Ninja 250R Tech Talk 9 August 24th, 2011 02:12 PM
