Old August 12th, 2018, 04:45 AM   #1
Micah
Motorcycle(s): 01 Ninja 250r
What’s my break in period for a new piston?
My 2001 ninja 250 was running too lean on one cylinder and one of the pistons had a hole in it so we replaced it. One new piston and rings. How many miles should I be babying my engine? Everything is old but the new piston and ring set.
Micah is offline   Reply With Quote
Old August 12th, 2018, 09:48 AM   #2
CC Cowboy
CC Cowboy's Avatar
MOTM - Mar '13, Jun '14
How do you pronounce the town you live in, LI TITZ? I have family in that area (Highspire, Middletown) but have never heard of Li Titz! I hear it's the 'Coolest Small Town in America'. I was wondering what makes it so "Cool"? Could it be the Li Titz or is there another reason that is not so apparent?
Old August 12th, 2018, 10:18 AM   #3
Micah
Lit its there are a bunch of old shops and stuff, not that cool to a 17 yr old kid, but there is a lot of tourism.
Old August 12th, 2018, 03:03 PM   #4
Did you have cylinders honed and cross-hatched?
Did you put in single-weight break-in oil?
Old August 12th, 2018, 04:17 PM   #5
Micah
The cylinders were honed cross hatching is good. I used 10w-40 (recommended) conventional oil.
Old August 12th, 2018, 05:29 PM   #6
Who recommended that oil???
Old August 12th, 2018, 05:52 PM   #7
Micah
The owners manual recommended 10w-40. My dad says conventional is better for breaking in, compared to synthetic (what I normally run).
Old August 12th, 2018, 06:42 PM   #8
Snake
Snake's Avatar
Mechanics I know have recommended conventional oil for the break in period.
Old August 13th, 2018, 10:11 AM   #9
Break-in is more for seating the rings than anything to do with the actual piston. To seat the rings you want cylinder pressure. That means load. Moderate loads with a variation in RPMs is usually recommended, as is some heat-cycling.
I've been told by a high-end (Porsche, Ferrari, Nascar and NHRA experience) engine builder that extended break-in time isn't needed if the machine-work has been done properly. He said oil isn't critical (synthetic isn't any more "slippery" than conventional oil as long as it has the correct additive package - no "Friction Modifiers"), but he likes to change it fairly quickly after the engine has been run a while (complete rebuild, after running maybe an hour). So just run an inexpensive conventional oil that's motorcycle compatible like Rotella T. Don't run any automotive oil in a cycle engine.
That's pretty much in-line with what I thought, but there are many opinions on the subject.
Break-In Period CC Cowboy General Motorcycling Discussion 7 April 23rd, 2013 08:13 AM
Motorcycle Break-In Period? quadcrazy General Motorcycling Discussion 5 April 5th, 2013 12:14 PM
Break In Period NicoleH28 2008 - 2012 Ninja 250R Tech Talk 7 April 11th, 2011 03:20 AM
Break-in period. Betlog 2008 - 2012 Ninja 250R Tech Talk 8 December 26th, 2009 03:38 AM
New 09 questions/break in period DarkNinja52 2008 - 2012 Ninja 250R Tech Talk 13 July 31st, 2009 01:47 PM
