Old April 10th, 2013, 03:59 PM   #1
THE BIG SITT
THE BIG SITT's Avatar
Valve Adjustment Help
I'm gonna need to do my valve adjustment soonish. Looking at the DIY, theres no way. Thats way above my skill level. Anyone want to come help? I'll buy ya pizza and beer during the day, AND I'll take you (and a lady if you have one) out for dinner (no homo). No, this isn't a joke.
THE BIG SITT is offline   Reply With Quote
Old April 10th, 2013, 04:05 PM   #2
krolinked
Nerd
krolinked's Avatar
I wish you were closer. I'd totally do it!
Old April 10th, 2013, 04:19 PM   #3
THE BIG SITT
I wish you were too… I can't afford to pay for your airfare unfortunately.
Old April 10th, 2013, 04:19 PM   #4
its not hard. just go slow and know what you are doing. read a lot and make sure you understand how what you are working with functions. know what changes you are making. if you really understand what you are doing, its very easy.
if you need help- you have your support group here waiting for you.
Old April 10th, 2013, 04:19 PM   #5
Lychee
sail away
Lychee's Avatar
Have you watched any you tube videos? Read the procedure at faq.ninja250.org? I just did my first DIY valve job a few days ago. It sounds difficult, but when you actually get to it, it is really not that bad. Which part in the procedure sounds unmanageable to you?
Here are the bits that I committed to memory after doing it:
-The hardest part is taking off the valve cover without draining the coolant. If the procedure to take off the cover without draining the coolant sounds difficult, then drain the coolant. Without the coolant in the system it is very easy, you just pop off the valve cover and the coolant pipe with it.
-If you don't have a proper valve adjustment tool, tightening down the rockers without messing up your setting is a little maddening, but not impossible. Use a 9mm socket with a wobble extension and a small slotted screwdriver. Undo socket, change screwdriver setting, tighten socket, recheck. Be patient and don't drop anything into the engine.
-The right side intake valve was the most annoying.
-Don't overtighten the 9mm locknuts
-When you put it back together be sure to put the spark plug gaskets (tear shaped) on the engine and not the valve cover. That way the possibility of them falling into the engine out of place is eliminated.
-Don't forget to carb sync. (more you tube videos)
Old April 10th, 2013, 04:22 PM   #6
THE BIG SITT
I've read that its easy and all, but I'm still hesitant. last year I had my bike apart for 6(?) weeks while I removed the airbox, tuned the carbs, tuned the carbs, and then I tuned the carbs. It was a disaster. I really don't want to do it and end up in a similar position. How long does it take to do?
Old April 10th, 2013, 04:23 PM   #7
@Lychee, 08+gen is overhead cam with bucket shims. not the locknut rockers in the pregen.
i'll say this- don't be lazy. give yourself as much room as possible. remove the cooling system. do not use open end wrenches. use torque wrenches and use the correct torque settings.
Old April 10th, 2013, 04:25 PM   #8
THE BIG SITT
As far as a torque wrench goes, I have one that has an analog dial and the whole thing is about a foot long. Good enough?
Old April 10th, 2013, 04:26 PM   #9
thats good for torques above 30ftlbs. buy a smaller more accurate one for working inside the head.
Old April 10th, 2013, 04:27 PM   #10
THE BIG SITT
Gotcha. So when will you be here? Need directions?
Old April 10th, 2013, 04:28 PM   #11
rojoracing53
Fast-Guy wannabe
rojoracing53's Avatar
MOTM - Jan '13
First time it took me all ****ing day because I was distracted by my helper and forgot to mark the chain so I had to do endless double checking
Second time about 3hr total time with a break in the middle to eat some damn good buffalo wings
I offered to do my buddies at the same time as mine but his lazy cheap ass would order a second shim kit so we have enough for both bikes so he's screwed. At least I tried to help
Old April 10th, 2013, 04:29 PM   #12
THE BIG SITT
Ok…. so when will YOU be here? Need directions?
Old April 10th, 2013, 04:40 PM   #13
send me your bike. i'll do the valves and make sure everything is in good working order. my standard tests include 4 CVMA races in a weekend.
Old April 10th, 2013, 04:41 PM   #14
Lychee
sail away
Lychee's Avatar
oops
Old April 10th, 2013, 04:59 PM   #15
krolinked
Nerd
krolinked's Avatar
Let me know if you need a second opinion on the bikes performance.
Old April 10th, 2013, 04:59 PM   #16
THE BIG SITT
Deal. Actually, I'll ride it there, as long as I can ride bitch during the races.
Valve Adjustment quarterliter 1986 - 2007 Ninja 250R Tech Talk 7 June 25th, 2013 05:32 PM
Valve adjustment ?s Jewtoys 2008 - 2012 Ninja 250R Tech Talk 5 August 1st, 2012 08:47 PM
valve adjustment little fish 1986 - 2007 Ninja 250R Tech Talk 8 November 4th, 2011 10:10 AM
Valve Adjustment-Really Tight adjustment screw? mikesova 1986 - 2007 Ninja 250R Tech Talk 5 May 2nd, 2010 04:57 AM
anyone want to help with a valve adjustment? diablo250 Group Rides and Local Events 2 March 28th, 2010 02:00 AM
