Old April 4th, 2009, 11:16 AM   #41
mcteague
mcteague's Avatar
Motorcycle(s): 2008 Yamaha FZ6
They look like they are not as tall as the stock pegs due to the lack of a rubber top. Do you notice any extra legroom? How about vibration?
Tim
mcteague is offline   Reply With Quote
Old April 4th, 2009, 03:14 PM   #42
JaeL
Bike Thrasher
JaeL's Avatar
Motorcycle(s): 2008 EX250r
Wife Is Gonna Be Pervvvved
I walked into the light and bought some of these too!!!
Intuitive Sliders, Aftermarket pegs, Custom Paint, Seat Cowl, Tinted Screen, Aftermarket flush mounts, Wheel Tape, Fender Chopped, Stock Shortie Exhaust and Woodcraft ClipOns
JaeL is offline   Reply With Quote
Old April 6th, 2009, 10:18 AM   #43
Ichiro
Motorcycle(s): 2008 250r(sold). 2013 Kymco Super8 150
Got 'em. Easy installation. I definitely used loctite 'cause the thing is screwed together and the movement/pressure of your foot could cause the peg to get loose.
Ichiro is offline   Reply With Quote
Old April 6th, 2009, 11:04 AM   #44
M-Oorb
M-Oorb's Avatar
Motorcycle(s): 2008 250r (Fastest Color)
Just wondering...other than looks why are you buying these. I do like the way they look but to those who have bought these...any other advantages?
Posted via Mobile Device
M-Oorb is offline   Reply With Quote
Old April 6th, 2009, 11:58 AM   #45
Shift250R
Shift250R's Avatar
Motorcycle(s): 08 Ninja 250R
some people find that having solid pegs gives you a better feel for the bike instead of the rubber ones which feel soft. For me they also gave me a little more foot room between the peg and shifter/brake. You can kinda see it in the pics. Also alot of (if not all) aftermarket rear sets and supersport bikes have solid pegs so there must be an advantage over the rubber ones.
Shift250R is offline   Reply With Quote
Old April 6th, 2009, 03:32 PM   #46
Ichiro
As Shift said, the solid feel versus the spongy rubber is the reason I bought them. They just feel better more solid under my feet.
Old April 6th, 2009, 04:00 PM   #47
Jiu Jitsu Player
Live 2 Ride Forced 2 Work
Jiu Jitsu Player's Avatar
Motorcycle(s): 2008 RED 250r
Nice. I ordered some of these also and I'm still waiting for them to come in. I can't wait to install these. Thanks for the tip about the loctite.
SAVAGE MODE: [ON] OFF
www.7milesdown.com
Jiu Jitsu Player is offline   Reply With Quote
Old April 6th, 2009, 04:01 PM   #48
TnNinjaGirl
Ms. Personality
TnNinjaGirl's Avatar
Has anyone told that eBay company that they will work on the newgen 250's?
Old April 6th, 2009, 04:41 PM   #49
Jiu Jitsu Player
If they work on my 250, I'll definitely let them know. I'll have to install them and see how they hold up before I tell them though!
www.7milesdown.com
Old April 6th, 2009, 05:45 PM   #50
Jiu Jitsu Player
Looks like Christmas came early for me today! Got my pegs, A-tech rear hugger, and new blinkers all in the mail! Woo! Can't wait to get these on!
www.7milesdown.com
Old April 6th, 2009, 05:56 PM   #51
they made a mistake.. that a-tech hugger was supposed to be sent here.
Old April 6th, 2009, 05:57 PM   #52
Jiu Jitsu Player
It's a mistake I can live with!!
www.7milesdown.com
Old April 6th, 2009, 06:03 PM   #53
I can't... send it here.
Old April 7th, 2009, 04:21 AM   #54
Jiu Jitsu Player
Any tips on getting the spring in line with the pin? I'm having a hell of a time getting that damn thing in place!
www.7milesdown.com
Old April 7th, 2009, 07:11 AM   #55
M-Oorb
M-Oorb's Avatar
Chris...make sure you post some pics up when your all done
Old April 7th, 2009, 09:52 AM   #56
Ichiro
Jiu Jitsu Player: Kind of hard to describe, but first get the pin through the first hole of the peg. Then push the spring down into place with your finger and once the tangs settle in keep pushing down with your finger while pulling the peg up a little to lever the spring into closing a little. You can then push the spring into position because the leverage of the peg holds it in place rather than trying to squeeze it shut with you fingers, which is extremely difficult. Then you just have to push the pin through or tap it through with a plastic or rubber mallet.It is easier if you have three hands, but is not hard with two once you get the hang of what I am trying to say. Good luck.
Old April 7th, 2009, 11:24 AM   #57
Shift250R
Shift250R's Avatar
I used a flat srewdriver to push the spring down while sliding in the pin. Once its in a little bit you can just tap it through. Remember the top spring clip (or piece that sits on the top of peg) sits a little more back towards the bike and down it.
Old April 7th, 2009, 04:25 PM   #58
Jiu Jitsu Player
I couldnt get any part of the peg through the spring. I tried the screwdriver method, but the coils of the spring split apart after a while and the screwdriver head gets stuck in between. Other times, the screw would launch out of there and I dont really feel like losing an eye this week. When I put the OEM one back in the peg literally slid into place no problem. I didn't have too much time to fumble with it yesterday so hopefully tonight I can work on it again. I'm going to check Kkim's DIY on this for some gems of wisdom that may help me out.
www.7milesdown.com
Old April 8th, 2009, 05:09 PM   #59
JaeL
Bike Thrasher
JaeL's Avatar
Ok Just put mine on...
Can I hang out with the kool kids now?
Old April 8th, 2009, 06:28 PM   #60
Jiu Jitsu Player
Had some time last night to muck around with these and finally was able to get them on. I just used the fattest flat head screwdriver I could find to push & hold the spring down while I worked the pin into place.After I got the first one, the other side went through no problem. I would post pics but just picture Jael's exact pics only on a red bike.
www.7milesdown.com
Old April 8th, 2009, 07:26 PM   #61
TnNinjaGirl
Ms. Personality
How come mine haven't come in the mail yet? I'm freaking out!!! My feet need pegs!!!! AAAAHHHHH!!!!!
Seriously though, I am getting pretty excited. Also, JaeL, your bike makes me smile everytime I see it. You've made my day.
Old April 8th, 2009, 09:07 PM   #62
Shift250R
Shift250R's Avatar
Nice, Jael you were already a cool kid since your bike is white.
Old April 8th, 2009, 10:07 PM   #63
Jiu Jitsu Player
no doubt! Definitely cooler than most.
www.7milesdown.com
Old April 8th, 2009, 10:28 PM   #64
miks
I'm lovin' it.
miks's Avatar
Motorcycle(s): '09 Black 250R
Looking good JaeL!!
Son: When I grow up I want to ride a motorbike.
Father: You can't do both son.
miks is offline   Reply With Quote
Old April 8th, 2009, 10:49 PM   #65
Small Ninja
Small Ninja's Avatar
Motorcycle(s): 2008 Ninja 250 Candy Plasma Blue
But The Real Question...How Do They Feel When You Ride?
Small Ninja is offline   Reply With Quote
Old April 8th, 2009, 10:59 PM   #66
Jiu Jitsu Player
I like them a lot better. They feel pretty sturdy and you can manuever your foot more.
www.7milesdown.com
Old April 8th, 2009, 11:11 PM   #67
Small Ninja
Do They Give A Lot Of Grip? And Do They Stick out More Or Less?
Old April 9th, 2009, 04:27 AM   #68
Buffalony
Buffalony's Avatar
Got em today. They look really good. Glad I got em. and I wasn't even looking to by pegs! I'll throw them on the mod pile.
It's gonna take me weeks to install all these parts or one really long day with out sleep! Wish I had a heated garage atleast!
I should stop buying parts....Well a couple more things to go to finish the list....like red/blue loctite....man this is addicting. It can be and expensive habit...I should start selling my needs for my habit....this forum is my enabler... I might need therapy..........rambling!
jk
Old April 9th, 2009, 06:10 AM   #69
JaeL
Bike Thrasher
JaeL's Avatar
I haven't takin' my ride outta the garage since installing them last night. And Corey the reason I got mines so quick is b/c i'm only about 300 miles away from the seller.....
Old April 9th, 2009, 04:08 PM   #70
Jiu Jitsu Player
They stick out roughly the same, but there is noticeably less peg underneath your foot if that makes sense. As far as grip goes, I haven't had any slipping problems yet and I rode with them wet yesterday. For some reason my left peg feels slightly angled downward more than my right. Not sagging, but just ever so slightly lower. It doesn't affect anything at all, I'm just pretty anal about every detail on the bike.
www.7milesdown.com
Old April 13th, 2009, 09:25 PM   #71
TnNinjaGirl
Ms. Personality
Got my pegs in. I saw where USPS delivered them and I told my boss I had to go home real fast. It took a total of 22 minutes to drive to my house, back and then install them.
First impressions... Sweet!! The fit and finish is great.
Installation... Super easy. I put some loctite on them and some lube called HHS2000. I'm not sure what loctite it was. I think it was some high-temp stuff. Anyways, it was the closest thing around.
Riding... Much better feel for the bike. My shifts are more sure. They have better grip (haven't tried in the wet yet). They don't seem to wear my feet out as bad as the rubber ones. Idk how that happened but it seems to be the case.
All in all... One of the best purchases for my bike. Simple, inexpensive, improves style and improves feeling.
Old April 13th, 2009, 09:44 PM   #72
Shift250R
Shift250R's Avatar
Nice, so far mine are still in great shape with no sag or paint chip. Glad everyone is happy with theirs I also noticed someone told the seller they fit our bikes so thats cool.
Old April 13th, 2009, 10:23 PM   #73
Small Ninja
Im On My Way To Grab A pair thanks guys for all the advice
Old April 14th, 2009, 05:47 AM   #74
JaeL
Bike Thrasher
JaeL's Avatar
ohh yeah mane i had to let'em know, now i should be gettin' commission off every sale!!
Old April 14th, 2009, 06:48 AM   #75
camaroz1985
camaroz1985's Avatar
Motorcycle(s): 2008 WR250R, 2006 Ural Raven (Sold), 2009 Versys Green (Sold), 2008 Ninja 250R Green (Sold)
I just put on some Buell XB pegs before my trip last weekend. They are kind of opposite of what most people want (they lower your foot about 0.75-1.0 inch, and therefore decrease cornering clearance), but they make for a lot more comfortable ride. I was kind of worried that the lack of rubber would make for an uncomfortable ride, but they were great.
http://cgi.ebay.com/ebaymotors/Buell...11510004r27797
camaroz1985 is offline   Reply With Quote
Old April 14th, 2009, 07:09 AM   #76
g21-30
g21-30's Avatar
Does that price include shipping?
Old April 14th, 2009, 07:11 AM   #77
Buffalony
Buffalony's Avatar
Installation... Super easy. I put some loctite on them and some lube called HHS2000. I'm not sure what loctite it was. I think it was some high-temp stuff. Anyways, it was the closest thing around..
HHS Is the best lube. I can not say enough good things to enough people about. Its superior for roller chains. Last Reeeaaall long too. It goes for $10-$20 but goes along way. It seeps into cracks and gels up. Doesn't fling off,waterproof,etc,etc. check it out everyone.
sorry.
Anyways back to the pegs.
As for the pegs I like them alot.They look fantastic. They have less traction than the ol'bumpers but nothin bad. As for sagging I can see them sagging in the future because of the design. There isnt that much in contact with the base it touches(cant think of prt name right now,Factory rearset maybe?).
It would be better if the spring notch was not cut all the way through, like the factory rest so there would be more supporting the peg.ya know?
Old April 14th, 2009, 07:58 AM   #78
camaroz1985
Yeap that is shipped. All you need to do is drill out the pin hole, and file down the sides a bit.
Old April 14th, 2009, 08:01 AM   #79
g21-30
g21-30's Avatar
Did the slight change in control positions (shift and brake lever) effect you much?
Old April 14th, 2009, 09:37 AM   #80
camaroz1985
No I just adjusted the shifter and brake and it feels great. When I got my new boots I had to adjust the shifter up anyway and didn't like it. Now I was able to move it back down and it feels pretty much perfect.
How to raised foot pegs? caineroad General Motorcycling Discussion 4 November 6th, 2013 03:23 PM
Question about foot pegs. Hawk637 General Motorcycling Discussion 5 April 19th, 2011 10:22 AM
More room at the foot pegs? iceman.kcmo 1986 - 2007 Ninja 250R Tech Talk 8 January 16th, 2010 11:11 AM
aftermarket foot pegs? RRTRIDER 2008 - 2012 Ninja 250R Farkles 14 December 6th, 2009 11:28 AM
Grinding Foot Pegs jonb08 1986 - 2007 Ninja 250R Tech Talk 14 June 17th, 2009 06:57 PM
