Old May 14th, 2011, 09:35 AM   #121
Shadozknight
Motorcycle(s): 10 ninja 250r
Umm, it did cause problems to the blinking so I just spliced the new wiring to the old signal lights. I hid the original blinkers under the seat. If I disconnect them, the all blinkers blink at the same time unless u re-wire under the dash. There's a post on that somewhere. I made it simple n simply hid the original blinkers under the seat n connected the wiring from the bike monkey blinkers to those stock blinker wires. Hope that helps.
Shadozknight is offline   Reply With Quote
Old May 14th, 2011, 10:00 AM   #122
sarapacman99
Climb to Glory!
sarapacman99's Avatar
Motorcycle(s): 2011 Kawasaki Ninja 250R White (sold)
anybody know where we can get this locally? i don't want to have it shipped all the way from AU and get lost/damaged. thanks!
I wanted to become Kamen Rider as a kid.
sarapacman99 is offline   Reply With Quote
Old May 14th, 2011, 10:09 AM   #123
Shadozknight
Google it. I got mine in the u.s. There's a company that makes it here and u can get it on amazon.com as well I believe
Old May 14th, 2011, 11:24 AM   #124
Nayt
Nayt's Avatar
Motorcycle(s): 011 ninja 250r
Originally Posted by Shadozknight View Post
those are the positive wires to the left blinker and the right blinker. the ground is run from the 1 ground wire thats connected to the brake light in the center housing. in another words, you dont need to wire anything to the negative for the blinkers, just to the positive for the left and right blinker.
GOT it makes sense thank you
Nayt is offline   Reply With Quote
Old May 17th, 2011, 12:34 PM   #125
muzkur
muzkur's Avatar
Motorcycle(s): 10' Ninja 250R
I have a question.
My taillight have just one ground too.
I want to put front led turn signals flush mounted with resistors to fix the blink speed.
Can I install the resistors in rear turn signals using the brakelight ground?
muzkur is offline   Reply With Quote
Old May 17th, 2011, 01:05 PM   #126
Vampyre
Vampyre's Avatar
Motorcycle(s): 2011 250R Black, 2005 ZX-6R Blue
This guy has an ebay store and runs out of Florida.
http://stores.ebay.com/2wheelstore?_trksid=p4340.l2563
I haven't ordered from him, but I plan to on Friday.
Vampyre is offline   Reply With Quote
Old May 17th, 2011, 01:06 PM   #127
Vampyre
Vampyre's Avatar
Oh crap sorry that is bikelitez
Old May 23rd, 2011, 02:44 PM   #128
ryan_bucky
Motorcycle(s): ninja 250
mine does this what the hell is rong!?!?!
http://www.youtube.com/watch?v=veAet7BqY2I
ryan_bucky is offline   Reply With Quote
Old May 23rd, 2011, 07:55 PM   #129
muzkur
muzkur's Avatar
Take a picture of the wires.
Maybe you plug any wrong.
Try to switch the wire into the original turn signal connector.
Old May 24th, 2011, 11:35 PM   #130
ryan_bucky
Not to sure what u mean left is to left
Old May 25th, 2011, 05:08 AM   #131
muzkur
muzkur's Avatar
I mean positive and negative.
Old May 25th, 2011, 06:22 AM   #132
nattygirl
nattygirl's Avatar
Motorcycle(s): 2010 Kawasaki Ninja EX250 Special Edition Red/Black
Does the brake light work as it should when the turn signals are not on? What kind of turn signals do u have in the front of the bike?
'10 Ninja 250R SE Red/Blk
Mods: Projekt D FE, Protons, HB Blk Windscreen, HIDs, TBR Blk Series Slip-On, Shogun Sliders, Solo Cowl, Integrated Tail Light, Gls Blk Rear Fender, Red Accents
nattygirl is offline   Reply With Quote
Old May 25th, 2011, 08:31 AM   #133
ryan_bucky
How can u have the pos & neg mixed up as they wouldnt work on a neg as that only receives power not gives it? I tried it with the earth and noting happened!! I have front LEDs that work fine just the rear light that's crap!!
Old May 25th, 2011, 08:52 AM   #134
muzkur
muzkur's Avatar
I had that problem too. In my case, switchin the wires works fine.
An important detail: With the 4 original turn signals the LED blink speed's faster than just the 2 front turn signals.
That tail light have a little weird circuit. lol
Old May 25th, 2011, 09:05 AM   #135
ryan_bucky
What do u mean switching the wires? Do u mean the green to indicator ahold be the black and yellow to indicator or the comple harness as in the black to grey connector I used off the original indicators???
Old May 25th, 2011, 09:12 AM   #136
muzkur
muzkur's Avatar
Yes. Something like that.
I could check how my wires are plugged and post here if you wish.
Old May 25th, 2011, 09:17 AM   #137
ryan_bucky
Yer please!! This is doin my head in it won't pass the MOT with lights like this!!!!!!!
Old May 25th, 2011, 09:44 AM   #138
muzkur
muzkur's Avatar
Checked.
The brake light is plug and play. No problem
To the left side, I have a blue wire in the taillight led and ablack connector with black and green wires in the bike. I plugged the blue in the green wire.
To right side I have a yellow wire in taillight and a gray connector with black and white wires. I plugged the yellow in the white wire.
My front turn signals are the originals, no changes. In tail I've used just the taillight, no other turn signals in led, original ones neither.
Here a video with my taillight in use:
http://s273.photobucket.com/albums/j...8042011001.mp4
Old May 25th, 2011, 11:05 AM   #139
ryan_bucky
What is the White wire on the right side? I have tried ever way and still no luck!
Old May 25th, 2011, 11:20 AM   #140
muzkur
muzkur's Avatar
In my bike it's the positive to plug connector in the bike to right turn signal.
Maybe in different countries or different year models that may change.
Old May 25th, 2011, 12:57 PM   #141
nattygirl
nattygirl's Avatar
As long as you have positive wire to positive wire, neg to neg, your wiring is good. I think your issue may be the fact that you have leds in your front signals as well. Have you done the diode mod? If not, you are going to need to. Check out this thread. It explains why it's necessary.
http://www.ninjette.org/forums/showt...ighlight=diode
I have the same tail light as you, proton flushmounts in the front, and also stock turns with leds in the back. I have the diode mod, and also a electronic flasher relay to stabilize the blink rate. Everything is all good.
Old May 25th, 2011, 08:34 PM   #142
muzkur
muzkur's Avatar
Im not using led in front yet because of that. But when I tried to use led in front, my turn signals simple didnt blink.
I wish to buy a resistor kit to fix that. I heard about some digital relay too. But that diode solution I dont know about it.
Old May 26th, 2011, 06:21 AM   #143
nattygirl
nattygirl's Avatar
Its one or the other. Either u use resistors or u do the diode mod. To me, installing the diodes were just as easy as doing the resistors, especially with the diy. Plus with resistors, they can heat up so you have to worry about where u install them. Also, u'll have to be able to calculate which size resistor is right for your setup. With the diode, there's no guess work.
Old June 19th, 2011, 10:13 PM   #144
The OP seems to forget the part where you remove the black plastic shroud that is attached over the brake light with plastic snaps and velcro.
Old August 21st, 2011, 12:20 AM   #145
Kawinja
FNG
Motorcycle(s): 08 Kawi Ninja 250r
what is an OP?
Kawinja is offline   Reply With Quote
Old August 21st, 2011, 01:12 AM   #146
Mr.E
That rider dude.
Mr.E's Avatar
Motorcycle(s): 2011 White Ninja 250 SE.
Originally Posted by Kawinja View Post
what is an OP?
Original post. Its the first post of a thread, in this case, the DIY.
Mr.E is offline   Reply With Quote
Old August 21st, 2011, 01:17 AM   #147
Kawinja
FNG
ah cool thanks for the lingo update. i'm noob to whole forum lingo!
Old August 22nd, 2011, 12:00 AM   #148
Kawinja
FNG
It worked i bought my bike and it came with an integrated tail light on it already. All i had to do was purchase the relay flasher and plug it in and now my signals finally blink!!!! YAY ME!!!!! lol
Old August 22nd, 2011, 02:07 PM   #149
Originally Posted by Mr.E View Post
what is an OP?
Sometimes it also refers to the person who made the original post. It looks like he could have used it that way in the vinyl thread.
Old August 24th, 2011, 10:18 PM   #150
ACT250R
ACT250R's Avatar
Motorcycle(s): 2008 Red Ninja 250R
Issue fixed
Last futzed with by ACT250R; August 25th, 2011 at 04:49 AM.
ACT250R is offline   Reply With Quote
Old August 26th, 2011, 12:59 AM   #151
DarkNinja52
DarkNinja52's Avatar
Motorcycle(s): Red 09 Ninja 250r aka Sheila (RIP), Red '10 Ninja 250r aka Sasha (Sold), White '13 Ninja 300 (To be Purchased)
what was the issue?
DarkNinja52 is offline   Reply With Quote
Old August 28th, 2011, 01:04 AM   #152
DarkNinja52
How is the BM different than the DMP and the TunerX factory versions?
Old August 29th, 2011, 07:34 AM   #153
Momaru
Momaru's Avatar
At a glance, I'd say none, save perhaps lower quality components and assembly. Looks like they directly ripped off the BikeMonkey design, flash pattern, wiring connections and all.
Personally, I'd go with them as I'm fairly sure it's their design and I prefer to support the people that actually did the work to develop a good product.
I might be wrong about eithr of those statements, but I can say that my BikeMonkey is still working like a champ 16,000mi (and almost three years) after install and I've gotten several compliments (no complaints) about brake light visibility.
Proud member of the Blue Army
Old August 29th, 2011, 09:55 PM   #154
DarkNinja52
Between having the same design, flash pattern and wiring connections, i feel it may be possible they were manufactured by the same company but the rights were sold to different vendors. If that's even something that happens
Old August 30th, 2011, 03:31 PM   #155
Momaru
Momaru's Avatar
Perhaps. I've been told something similar with several brands of protective gear, that the 'daytime' factory operations are for the major brand, and that 'night-time' operations, with the same materials, processes, etc, is for the off-brand. The difference between them is the quality control. Lots for the main-brands. Almost none for the off-brands. That's all hear-say and my somewhat unreliable memory though.
All I know is that I've bought a couple knock-off products in the past and had them wind out to be less than what I'd hoped for, in comparison to the 'genuine article.' Not saying that's the case with these other companies making the integrated tails, but ya never know till you throw down the $.
Old August 31st, 2011, 11:41 PM   #156
DarkNinja52
Well i threw down the the $ for dmp fender elim and dmp tail light. look just like the b2 industriesfender elim and the Bike monkey tail light.. we'll see
Old September 2nd, 2011, 09:35 AM   #157
natek
Motorcycle(s): Honda Ruckus
pics when done please
natek is offline   Reply With Quote
Old September 2nd, 2011, 07:12 PM   #158
DarkNinja52
I'll keep you updated over here
http://www.ninjette.org/forums/showthread.php?t=83900
Also I might put some pics in the BM thread as the install might be EXACTLY the same. Including diode and Flasher relay install
Old January 25th, 2012, 02:39 AM   #159
Sqwacka
Motorcycle(s): Kawasaki Ninja 250 2011
Hey! I recently bought the Bike Monkey intergrated tail light for my bike. Just wondering if you need to buy the aftermarket LED flasher?? The indicators in the tail light are lit up but not flashing..
Cheers
Sqwacka is offline   Reply With Quote
Old January 25th, 2012, 05:48 PM   #160
Shadozknight
Cheers
Yes u do have to buy a led flasher. Get 1 at kragen, pep boys or autozone
DIY Integrated Tail Light (cool way) PsHYk 2008 - 2012 Ninja 250R Tech Talk 2 July 18th, 2012 11:04 AM
DIY/Review of the Bikelitez Integrated Tail light blbills 2008 - 2012 Ninja 250R Farkles 33 May 2nd, 2011 04:40 PM
NON-integrated Bikemonkey light? adouglas 2008 - 2012 Ninja 250R Farkles 30 October 24th, 2009 04:57 AM
Video Request of BikeMonkey Integrated Tail Cicarius 2008 - 2012 Ninja 250R Farkles 4 September 11th, 2009 01:02 AM
