April 26th, 2020, 05:33 AM | #1 |
Stuck front sprocket
Hey!
I am changing my sprockets and rear brake. The front sprocket is stuck, it won't slide of the shaft. What should I do? I think the last owner used locktight(?) On it. I have tried a puller and hammering it. Even tried rust remover. Edit: Got it off, used a diffrent puller. |
April 26th, 2020, 10:01 AM | #2 |
Hi! Good job getting that sprocket off. Wonder what was going through PO’s mind when they glued it on? That giant nut holds it on plenty tight!
April 26th, 2020, 03:28 PM | #3 |
Join Date: Oct 2013 Motorcycle(s): Ninja 250R, Tiger 800 XRT Posts: 828
King Kong tightened mine at the factory. I had to use a ~5 foot breaker bar and thought the 2x4 through the rear wheel was going to explode when it finally broke loose.
Good job getting yours off!
bike * miles = smiles smiles / bike = miles smiles / miles = bike |
[kropotkin thinks...] - Additional Front Tire Withdrawn After Getting Stuck In Custom | Ninjette Newsbot | Motorcycling News | 0 | April 8th, 2017 05:40 AM |
Front Sprocket Stuck On Driveshaft | z0sum | 2008 - 2012 Ninja 250R Tech Talk | 36 | February 22nd, 2017 04:04 PM |
Bolts stuck on front brake caliper | Lap202 | 2008 - 2012 Ninja 250R Tech Talk | 22 | August 5th, 2016 05:42 AM |
