Old November 11th, 2010, 05:38 PM   #1
JMcDonald
Motorcycle(s): 2008 250R
Engine ticking at idle?
I havent discountrd the possibility that I just happened to relatively recently notice a noise that has already been there, and now I am focusing on it so it sounds louder.
I checked all the valve lashes today, and they are all within spec. I was really expecting them to be really loose, because that was the cause of valve tick in every other case Ive experienced.
The engine is still running fine, and I have changed the oil and filter every 2k miles with mobile 1.
My only two guesses for a noise like this would have been large valve gaps or injector noise. Valve lash is fine and I have carbs, so Im at a loss.
II will put up a video tomorrow, but does this sound like anything you have experienced with your ninjettes?
Posted via Mobile Device
JMcDonald is offline   Reply With Quote
Old November 11th, 2010, 06:41 PM   #2
bob706
bob706's Avatar
cam chain tensioner
Old November 12th, 2010, 05:10 PM   #3
Momaru
Momaru's Avatar
My 250 has been doing it for at least the last 10,000mi+
I think what you're noticing is commonly called the "Kawai click"
From what I've been told it is indeed a weak automatic cam chain tensioner (CCT) that happens with a lot of Kawasaki bikes. Kawasaki supposedly just makes the tension a little low, thus the cam chain slaps around a little more, making some clatter. I have personally tried buying/installing a new OEM CCT, which changed nothing. I did that after checking the valve lash and they were all well within spec; just checked them again today and same deal.
I'm seriously considering a manual cam chain tensioner, but not to the 'do it' point just yet.
Proud member of the Blue Army
Old November 12th, 2010, 06:52 PM   #4
JMcDonald
Ok, so this means that it is the CCT making the noise, but it does not necessarily need replacing?
Thanks for that info, Momaru.
And sorry about the video, I've been really busy the last couple days .
Factory Pro Jet Kit, K&N R-0990 Pod Filter, Sportisi VR Black Exhaust, BRT TIS Ignition, White Paint, and 16/41 Sprockets. Soon: Maybe a 37T Rear Sprocket if I get things running like I'd hoped.
Old November 13th, 2010, 04:43 PM   #5
headshrink
headshrink's Avatar
From what I've been told it is indeed a weak automatic cam chain tensioner (CCT) that happens with a lot of Kawasaki bikes. I'm seriously considering a manual cam chain tensioner, but not to the 'do it' point just yet.
+1
My replacement CCT didn't do jack. And the screw threads strip easier than anything I have ever seen. I am planning on getting something like this tensioner when I do my next valve job: http://zxzone.com/tensioners.html
Old November 15th, 2010, 12:42 PM   #6
Momaru
Momaru's Avatar
Correct, some ticking is to be expected even with a factory-spec CCT. If the ticking gets real bad it may need replacing, but I'm honestly not sure where to draw the line.
Regarding the video, I'm guilty of the same thing; planning to make one for the CCT click and never quite getting around to it. There's a handful of similar threads around though if you want to do some further reading on the subject.
FWIW, if the chatter really bothers you, I've read on some other forums it is possible to back off the the CCT mounting bolts (the pair of 8mm ones) just a hair (like half a turn or less) to force the CCT to extend a little, then re-tighten them. Our CCT is designed to automatically extend, but not retract (without getting a screwdriver and manually re-winding it) so that'll increase the chain tension slightly. That said, it is very possible to cause engine damage doing this through over-tensioning your cam chain. Possible results include: stretched/damaged cam chain, worn guides, accelerated wear of cam/main driveshaft sprockets, and in worst case engine failure. Also known as: proceed at your own risk. However similar results are possible with the a manual CCT.
Old November 15th, 2010, 12:59 PM   #7
headshrink
headshrink's Avatar
I was wondering, for those that opt to install a manual CCT, how do you tension it properly?
Old November 15th, 2010, 05:36 PM   #8
JMcDonald
Wow thanks for that info! I will search around too, so thanks for the tip as well.
Old November 15th, 2010, 10:12 PM   #9
spooph
spooph's Avatar
Motorcycle(s): '08 Ninja 250R
MOTM - Oct '15
My bike did this too. I checked, re-checked and triple checked the valves, CCT, cam chain and everything. Then it started getting warmer as summer was approaching, so I put in 20-50W oil and it went away.... Ran it all summer like that. Switched back to 10w40 in the fall, and on the hotter days it would click. At 32F, it starts to click again.. Wondering if 5w30 will solve the problem in the colder months...
Old November 20th, 2010, 05:54 PM   #10
JMcDonald
I played with the CCT mounting bolts, backing them out as much as a half-mm and nothing changed. I switched to Rotella T6 5w-40 and now the noise is largely gone (what I can still hear I am not sure if it is the same noise or just the noise that was already there). Though I think it is because I was running 10w-30, which I now realize was too thin for the engine.
Old November 23rd, 2010, 09:07 PM   #11
indr
Reading all these replies, i'm seeing that all you run 2008 bikes. Does that mean that this problem has been solved for the 2010 models?
indr is offline   Reply With Quote
Old November 23rd, 2010, 09:07 PM   #12
JMcDonald
Arg. Internal tick went away, but now since I have no gaskets on my new exhaust I get that nice tick from there :P . Gotta try to fix that tomorrow.
Old December 16th, 2010, 05:29 PM   #13
JMcDonald
BTW, it started ticking again a bit ago, so today I loosened and reset the CCT by turning the inner screw behind the center 10mm bolt, and let it reseat itself against the chain. At least for now, that seemed to get rid of the ticking.
Last futzed with by JMcDonald; December 16th, 2010 at 08:04 PM. Reason: Clarification.
Old December 17th, 2010, 08:41 AM   #14
Does the ticking happen even at idle? Is it linked to engine or drivetrain speed? I'm just hoping that it's not the valves in my case.
Old December 17th, 2010, 10:11 AM   #15
JMcDonald
It only happened, or at least was noticable, at or near idle. From about 1-2.25k RPM (like if I blipped the throttle or if the engine was coming down after pulling in the clutch to stop). It happened whether or not the tranny was in gear.
2009 ninja 250r engine ticking & knocking noise ubxssangz 2008 - 2012 Ninja 250R Tech Talk 47 January 26th, 2017 12:15 PM
Clutch and Engine Idle Issues daphnelcc 1986 - 2007 Ninja 250R Tech Talk 11 August 23rd, 2013 12:48 PM
Engine ticking sound Nosajong 2008 - 2012 Ninja 250R Tech Talk 4 May 21st, 2013 07:57 PM
Can thinner oil cause engine ticking?? LoneRonin 2008 - 2012 Ninja 250R Tech Talk 7 June 11th, 2012 11:25 PM
Hard ticking at idle Hedge36 1986 - 2007 Ninja 250R Tech Talk 35 February 5th, 2010 06:54 PM
