Old April 19th, 2011, 10:23 AM   #1
SdSy675
Motorcycle(s): 06 Daytona 675, 09 Ninja 250
California Emissions Removal
I think I've read all the posts regarding the removal of the Kleen Air system but what about the Cali emissions junk? I shot a PM to VeX since he provides a lot of DIY... I'm just trying to piece all of the info together. Since my bike is completely disassembled right now, I would like to remove all the unneccessary junk before putting it back together...
Left side of tank = three hoses. The right side tube... cap it, the middle tube run a PVC to an inline filter... What about all the hoses, box, cylindrical thingy etc... I'm good with following directions but can't seem to piece everything together to feel confident to properly terminate all the hoses... Any help would be appreciated!
SdSy675 is offline   Reply With Quote
Old April 19th, 2011, 12:27 PM   #2
KGar
Mid Life Crisis
KGar's Avatar
Motorcycle(s): 2010 Ninja 250r (Passion Red); 1999 BMW K1200RS (Marrakesh Red)
I had no idea that I purchased a bike in AZ that had cali emm so I just deleted mine along with the kleen air and rejetting for my new area p exhaust. I searched and found this on another forum though it looks like a pregen bike. I capped the middle and left the tube closest to the rear open. Initially I had both capped but found out about 2 miles from home that wouldn't work..it got starved for fuel. Then I came across what I think is the answer. You mentioned that you capped the rear tube and put a filter on the middle? maybe I'm wrong but so far I ridden it about 200 miles since deleting the bs. Let me know about the tube situation and capping them properly. Good Luck
http://faq.ninja250.org/wiki/Hose_ro...ontrol_systems
Edit: just saw info on here about emissions
Kleen Air removed, Cali emissions removed, drilled slides, 15/43 JT's, 150/60 Rear
Last futzed with by KGar; April 19th, 2011 at 12:59 PM. Reason: needed to research more
KGar is offline   Reply With Quote
CA Emissions removal Olie 2008 - 2012 Ninja 250R Tech Talk 19 April 30th, 2014 10:39 PM
California Emissions Removal Bo0stZomb13 2008 - 2012 Ninja 250R Tech Talk 3 May 6th, 2011 02:39 PM
CA Emissions Removal question (carb parts) CynicalC 1986 - 2007 Ninja 250R Tech Talk 6 March 17th, 2011 09:18 AM
California Emissions? jump General Motorcycling Discussion 3 October 25th, 2009 10:41 AM
thoughts on emissions removal speedgsx98 1986 - 2007 Ninja 250R Tech Talk 8 July 14th, 2009 07:33 AM
