Old September 28th, 2011, 04:22 PM   #161
quanttrom
Motorcycle(s): 250r
I am not 100% sure but I would like to give you my reasoning.
Typically hall effect sensors are used for abs and other accurate speed detection applications. They will detect ferromagnetic materials(eg iron) such as in a sprocket or other shape where teeth are moving in and out of the magnetic field of the hall effect sensor. Those types of sensors produce a sine wave as one would expect.
The downfall and why I believe they cannot be used in the speed sensing application for our bikes is because the magnet is attached and one or a few locations of the rotating wheel. The longest possible distance between the hall effect sensors and the magnet is lets say 10 cm. Well above anything that a hall effect sensors with that size can detect especially considering all the iron concentrated in the area; forks, break disk, etc.
The output will almost look digital . You are gonna have a short period or a rise, then rapid fall followed by a long idle time of no signal.
I believe an on/off hall effect switch is typically used in those applications in a digital manner. The gauge will time the delay between rising edges (or falling or w/e) and since the circumference of the wheel is know , the speed can be calculated. In order to improve the reliability at varying distances between the sensor and the break disk there are two pieces and it is necessary to insert magnets in the sprocket bolts.
quanttrom is offline   Reply With Quote
Old October 8th, 2011, 09:28 AM   #162
Couldn't you just leave a magnet out?
Old October 12th, 2011, 10:16 AM   #163
quanttrom
Motorcycle(s): 250r
so it seems like jonnyc is out of this.
Does anybody know where we can get a comparable gauge? maybe a little bigger? i would be interested in continuing this.
Old November 21st, 2011, 05:20 AM   #164
dougherty
Motorcycle(s): 2009 HD Street BOB 2010 HD Roadglide
If it works and the Rpm reflects up to 14000
Id be in
dougherty is offline   Reply With Quote
Old November 21st, 2011, 10:25 AM   #165
dougherty
scratch that lol sorry
Old February 21st, 2012, 09:18 PM   #166
justinswidebody
justinswidebody's Avatar
Motorcycle(s): 250 ninja
Here's some pics of my new gauge cluster with 2 air fuel ratio gauges. I like it. Now I just need to reinstall my fuel injection. I still need to figure out how to fix the 10mph difference in speed.
I think I'm going to move the main gauge cluster closer to the top. I think it will look better. What does everyone think?
justinswidebody is offline   Reply With Quote
Old February 22nd, 2012, 08:10 AM   #167
massacremasses
Avid Kitteh Poster
massacremasses's Avatar
Motorcycle(s): 2006 Yamaha TTR 50 SUCK IT
what cluster is that? is that a Koso with custom gauges?
I powdercoat stuff Help me pay for my addiction
I say funny stuff. http://twitter.com/JustinPWNSyou sometimes...
I write like a 12 year old too, http://justinpwnsyou.wordpress.com/
massacremasses is offline   Reply With Quote
Old February 22nd, 2012, 09:48 AM   #168
quanttrom
Motorcycle(s): 250r
justinswidebody, would you be able to get a video as well !?
Old February 22nd, 2012, 01:34 PM   #169
justinswidebody
This is the same cluster Johnny had. I bought one and did my own spin on it. I made the back plate and fitted it all together. I uses two a/f gauges cause I have the ecotrons efi kit which has two oxygen sensors. So I use the a/f gauges to monitor each cylinder. I built this all for 150 dollars.
Old February 22nd, 2012, 01:39 PM   #170
massacremasses
Avid Kitteh Poster
nice.
you should sell it. Seriously.
Old February 22nd, 2012, 02:21 PM   #171
mustang5.0
Motorcycle(s): 2011 GIXXER 600
srly... I'm in..i want that ish
"You see it's not the blood you spill that gets you what you want. It's the blood you share, your family, your friendships, your community. These are the most valuable things a man could have."
mustang5.0 is offline   Reply With Quote
Old February 22nd, 2012, 06:35 PM   #172
justinswidebody
I could make more. I would just like to get the speedometer issue fixed. Also need to figure out a correct way to get the collant temp sensor to work. If someone could help me find how the stock coolant sensor works I'm sure we could figure it out. I could make these with any other two gauges anyone would want.
Old February 22nd, 2012, 08:24 PM   #173
quanttrom
Motorcycle(s): 250r
How did you make the dash faceplate?
By hand and just drilling it?
Old February 22nd, 2012, 08:44 PM   #174
Klondike1020
Intrepid Adventurer
Klondike1020's Avatar
For 150? U mean just the a/f gauges and plate right . What about the cluster ?
Old February 22nd, 2012, 09:06 PM   #175
justinswidebody
All together was 155 dollars sorry for the miss calculation earlier.. Main gauge is 85 dollars then both a/f gauges were 35 a piece so 70 for those. And then I cut out my own back plate out of spare 1/4 inch thick plexiglass I had laying around. I can easily make the gauge cluster plug in play. It's a very simple installation.
Old February 23rd, 2012, 06:38 AM   #176
Klondike1020
Intrepid Adventurer
Where did you buy your gauges ? I haven't found them that cheap?
Old February 23rd, 2012, 10:31 AM   #177
mustang5.0
waiting on you, bud!!
Old February 23rd, 2012, 12:06 PM   #178
justinswidebody
Here's a link to the gauge cluster.
http://www.ebay.com/itm/LCD-digital-...item19cd3c3cd9
Old February 23rd, 2012, 08:34 PM   #179
Klondike1020
Intrepid Adventurer
Thanks ! I am too dumb to find it on ebay
Old February 24th, 2012, 04:45 AM   #180
justinswidebody
No problem.
Old February 24th, 2012, 03:09 PM   #181
EMSRacer07
EMSRacer07's Avatar
No problem.
Do u have to re wire it? well i know thats probably given. But did u get it to connect to the stock harness.
Old February 24th, 2012, 04:51 PM   #182
justinswidebody
The plastic conector it comes with actually slides into the ninja connector. You just have to depin the gauge conector and put the pins in the correct spot. However it does not come with the three prong connector. So I easily removed the conector from the factory gauge cluster and used it on this one. I will say that a 400ohm resistor did not fix the fuel gauge. So problems still are fuel gauge, speedometer reading 10mph to high and also the water temp sensor. If you buy one from eBay I will be more than happy to post up a wire diagram for you.
Old February 25th, 2012, 12:51 AM   #183
Will it work with a pre-gen?
Old February 27th, 2012, 06:46 AM   #184
justinswidebody
Guys I don't think I would buy this gauge if I where you. I'm gonna buy something different and when I'm done I will post back. But the next gauge should be cheaper than most koso installs but a little more than this one.
Old February 27th, 2012, 07:04 AM   #185
Klondike1020
Intrepid Adventurer
If you decide to get rid of it . Want to sell me yours for a used discount ?
Old February 27th, 2012, 07:07 AM   #186
Keep us informed. Thanks!
Old February 27th, 2012, 02:20 PM   #187
justinswidebody
Klondike, I might let it go. Do you want just the center gauge? Or do you want all of it?
Old February 27th, 2012, 06:35 PM   #188
razorgamez
razorgamez's Avatar
Motorcycle(s): 2008 ninja 250r
Looks like the gauge on the Megelli 250r
These gauges look way too similar to the gauges on the Bennche Megelli 250r...
....(O_O)....(O_o)....(o_O)....(-_-)
razorgamez is offline   Reply With Quote
Old February 28th, 2012, 12:23 AM   #189
Kstorm21
Kstorm21's Avatar
Motorcycle(s): 2009 Ninja 250R SE
Do you still plan on possible getting stuff together for a (possible) group buy? If so I'd totally be interested. What is the in-between gauge?
Kstorm21 is offline   Reply With Quote
Old February 28th, 2012, 04:24 PM   #190
justinswidebody
We will see what happens when I get my two new gauges. One is the trail tech vapor and the othe is the Dan moto 180. I will see which one I like best and make it fit the ninja.
Old February 28th, 2012, 06:05 PM   #191
Kstorm21
Kstorm21's Avatar
I don't think either of those have a fuel gauge. What will you do for that?
Old February 28th, 2012, 08:58 PM   #192
saxnbass
saxnbass's Avatar
Motorcycle(s): 2009 CBR600rr
The DanMoto Speedo
A LCD cockpit which combines a speedometer(mph&kmh), Tachometer, fuel gauge, a clock and a
milage counter(total & trip).
Adjustable to tyre sizes from 13 to 25 inch.
Indication lights for turnsignals, high beam,neutral and empty fuel tank.
saxnbass is offline   Reply With Quote
Old February 28th, 2012, 10:17 PM   #193
justinswidebody
http://www.dan-moto.com/DM_US/danmot...cr0nj9u59m2gd7
I was actually refering to this one :-)
Old February 28th, 2012, 10:20 PM   #194
justinswidebody
http://trailtech.net/vapor.html
And this one. Which one does every body like best?
Old February 28th, 2012, 10:33 PM   #195
Kstorm21
Kstorm21's Avatar
Did you see how big or little it is? Does it look crazy small or is it me?
Old February 29th, 2012, 12:28 AM   #196
justinswidebody
Yes it is small. However if you go back a few pages is the thread you will see how small the first gauge looked. I will find a way to dress these up and add more features that will make them look very appealing.
Old February 29th, 2012, 01:19 AM   #197
Kstorm21
Kstorm21's Avatar
Okay but it's really small...I converted the mm to inches and it comes out to 4.7"x2.3". Ya might need a few of them.
Old February 29th, 2012, 09:34 AM   #198
justinswidebody
LOL. The way I look at it is it gives me a chance to integrate a bunch more stuff into it. You will see. I have some ideas.
Old February 29th, 2012, 09:47 AM   #199
EMSRacer07
EMSRacer07's Avatar
thats true looking at the pics its probably the same length as the other one lol. funny. but i think i like the 180 degree one. looks cool lol. Very interested if u can get either of those to work. haha.
Old March 12th, 2012, 08:28 AM   #200
matmat1222
Motorcycle(s): 2008 Kawasaki ninja 250r
Add me to the list. Been looking for digital gauges for my ninjette. And howblong do you think it will be till we would get these?
matmat1222 is offline   Reply With Quote
When's the next Koso group buy? IF13 Motorcycle-related 23 March 18th, 2014 08:26 AM
pre-gens: possible group buy for orange side pods Singh2jz Motorcycle-related 6 April 29th, 2013 11:41 AM
danmoto digital gauges Jordan91 2008 - 2012 Ninja 250R Farkles 4 December 29th, 2012 08:37 PM
Group Buy on Koso Gauges *requested* RaceTech Electric Motorcycle-related 228 July 16th, 2012 06:43 AM
Slingshot Pre Load Adjuster Group Buy ztrack157 Motorcycle-related 24 May 31st, 2011 06:59 PM
