Old February 4th, 2012, 06:52 PM   #1
headshrink
headshrink's Avatar
idle screw adjustment
Real quick... I'm fine-tuning my fuel mix screw, am currently 4.0 turns out, and still run a bit lean. How far out can I go without needing to pull out the carbs and change the pilot jet (currently #38)?
Old February 4th, 2012, 07:25 PM   #2
setasai
setasai's Avatar
At 4 turns you're basically all the way out.
2009 Ninja 250R SE Green Sport Touring Style:
ZG ST; Symtec heated grips; RAM GPS w/ mUSB; DIY reshaped seat; DIY Givi E21 Sidecases; 15T sprocket
Old February 4th, 2012, 08:06 PM   #3
headshrink
headshrink's Avatar
Bummer, I hate pulling the carbs out. Thanks for the feedback.
Old February 4th, 2012, 09:02 PM   #4
jasle
Motorcycle(s): 09Ninja250, Ducati Monster 800ie, Harley FXSTS,Rebel 250,CR144,KX85,RM85L
+1 for next size bigger pilot...but check for vacuum leaks first. spray some carb cleaner at the carbs base and hose connections. Seen some leaks screw up jetting. Go bigger on pilot and then way too rich all of the sudden. crack in a line...
Thanks to: , DUNLOP, WHOOPIE RACING, 995 PAINTWORKS, South Austin Motorcycles
jasle is offline   Reply With Quote
Old February 4th, 2012, 09:55 PM   #5
headshrink
headshrink's Avatar
I'll double-check that when I pull the carbs out, but I have been over the tubes several times. I had things relatively close, but when I added the BRT-TIS, it suddenly felt way lean. I've wondered if the missing link was the float height, but since very few tend to mess with them, I'm hesitent to start. I don't recall the height, but it was WNL.
Old February 5th, 2012, 02:04 PM   #6
headshrink
headshrink's Avatar
My bad, I was acctually 4.5 turns out.
This statement from FP, "Rule of thumb....
If you go 1 size larger or smaller on the size of the pilot jet, you will change the fuel screw ~1.5x richer or leaner to retain the original idle mixture..."
Therefore, going from my #38 with 4.0 turns to #40 would be equal to 2.5 turns - Generally speaking, does that sound about right?
Old February 5th, 2012, 08:46 PM   #7
headshrink
headshrink's Avatar
I started at 3 turns on the #40, and although I need to adjust it a little further, the surge is much harder to detect, and start/idle are a little better. I could use a wee bit more power off the line though.
Then, when I went to try 3.25 turns, I noticed I had lost a bolt on my AreaP header... AGAIN! I check those bolts almost every time I do work on my bike, and they have always been fine since I have done that, but this is actually the second time I have lost a bolt from there (first was with original exhaust). I used a tube to check for exhaust leaks, and could detect a small leak. I can't tell visually, as it looks pretty tight. I am going to order new gaskets from AreaP (they claim to have more crush room than OEM). I also ordered 5 new bolts for the header.... 1 to replace the one I lost, and the other 4 are going to be used as locking nuts. I am NOT going to loose that thing again!
Would a minor exhaust leak at the header be enough to mess-up my re-jetting efforts?
With all the other header bolts tight, and the leak contained to a trickle, would it harm my engine if I used it to get to work until the parts arrive?
what is the best idle screw mixture vmax 2008 - 2012 Ninja 250R Tech Talk 9 July 1st, 2017 10:45 AM
HELP! idle adjustment screw came out! str8t six 2008 - 2012 Ninja 250R Tech Talk 5 March 21st, 2012 10:30 AM
Idle Mixture adjustment screw Q indr 2008 - 2012 Ninja 250R Tech Talk 1 December 2nd, 2010 09:36 PM
Help. Idle Adjustment Knob cable came off. RyanJames 2008 - 2012 Ninja 250R Tech Talk 3 November 2nd, 2010 11:22 AM
Valve Adjustment-Really Tight adjustment screw? mikesova 1986 - 2007 Ninja 250R Tech Talk 5 May 2nd, 2010 04:57 AM
