Old May 22nd, 2012, 09:23 AM   #1
BenBris
Ben
Motorcycle(s): Kawasaki Ninja 250r
Frame sliders - Install Help
basically i am new too all this stuff and i decided to fit frame sliders,only problem is you have to remove the main engine bolt to fit the new one so as i knocked the old one through as i placed the new one through by it got stuck on the other side as the engine has dropped by around 1mm ....... tried many things to rise it. any help please !!!
BenBris is offline   Reply With Quote
Old May 22nd, 2012, 09:41 AM   #2
Reyno2ac
Reyno2ac's Avatar
Motorcycle(s): Red 2009 Ninja 650r
A block of wood and a jack under the motor will lift it up.
Reyno2ac is offline   Reply With Quote
Old May 22nd, 2012, 09:58 AM   #3
BenBris
Ben
yea really didnt think it through .... i dont have a jack :S i have got the bolt through one side so its not going anywhere for the time being , guna have to borrow a jack tomorow , thanks
Old May 23rd, 2012, 06:09 AM   #4
RaceBikeRentals
Pimpin
RaceBikeRentals's Avatar
Motorcycle(s): Bunch of em
I'm sure you could also rig up a fulcrum with a 4x4 block and a 2x4, or something similar. The engine isn't that heavy and should move fairly easily.
-Richard
MotoList.com <<<List your stuff!
RaceBikeRentals is offline   Reply With Quote
Old May 23rd, 2012, 02:46 PM   #5
BenBris
Ben
Finally got them in !!!
Old May 23rd, 2012, 06:51 PM   #6
BenBris
Ben
used something very helpful called my dad had to loosen off a few other bolts as the engine refused to budge . also one slight problem I have come across is that the bolt sticks through quite far and rubs on the radiator hose so I am making up a spacer to move it out a few mm .
Streetbikes Unlimited Frame Sliders Install????? jboyd12 2008 - 2012 Ninja 250R Tech Talk 3 July 1st, 2012 12:50 PM
Easiest Frame Sliders to Install? ajcadoo 2008 - 2012 Ninja 250R Tech Talk 4 February 22nd, 2012 12:30 AM
Frame sliders install nixthewiz 2008 - 2012 Ninja 250R Tech Talk 1 October 28th, 2011 10:23 AM
PSR Frame Slider Install eds2fitty 2008 - 2012 Ninja 250R Tech Talk 4 August 7th, 2011 08:17 PM
Remove fairing and install generic frame sliders for my sister to practice... CZroe 2008 - 2012 Ninja 250R Tech Talk 8 January 23rd, 2011 11:39 PM
