Old September 18th, 2012, 02:00 PM   #1
cuz
cuz
cuz's Avatar
Motorcycle(s): 09 ninja 250r
Broke Off Valve Cover Bolt off any advice
i just wana kick the bike over right now lol
THE GOOD LIFE
cuz is offline   Reply With Quote
Old September 18th, 2012, 02:02 PM   #2
take the other bolts out and take the valve cover off and use some vicegrips to remove the remaining bolt stud then replace it. if it broke off down in the threads, try using a tiny extractor bit once the head is off. if that doesnt work you'll need to drill it and retap it then stick in a helicoil. if the head is just destroyed, just cut the head off and get it to a stud then remove the rest of the bolts and take the cover off and remove it with grips.
Old September 18th, 2012, 02:06 PM   #3
Monkeytofu
I told you bro
Monkeytofu's Avatar
I spent about 3 or 4 days trying to get the proper equipment to remove it from within the engine. You can remove the bracket the valve cover bolt screws into pretty easily. Held in by two bolts.
an OEM bolt is relatively cheap. around 5 bucks with shipping included.
Old September 18th, 2012, 02:25 PM   #4
cuz
cuz
cuz's Avatar
"SNAP"once i heard that i was like F this. and this is the result and thanks for the responses
THE GOOD LIFE
Old September 18th, 2012, 02:40 PM   #5
you're screwed
Old September 18th, 2012, 02:42 PM   #6
cuz
cuz
cuz's Avatar
THE GOOD LIFE
Old September 18th, 2012, 02:47 PM   #7
flynjay
flynjay's Avatar
That looks like one of the cam bearing/cap bolts. Getting the threaded end of that out is not going to be easy. Remove the cam bearing and see if you can see the threads sticking of the head.
I might have a bolt that size you can borrow until you get a replacement, if you need to get up and running this week. Otherwise you should probably just order a new one.
Old September 18th, 2012, 03:28 PM   #8
cuz
cuz
cuz's Avatar
Perfect
THE GOOD LIFE
Old September 18th, 2012, 03:30 PM   #9
dino74
dino74's Avatar
you're screwed
Pun intended?
CVMA #55
Old September 18th, 2012, 03:33 PM   #10
dino74
dino74's Avatar
Maybe this will help...
I know your bolt is a lot smaller than his but still...
CVMA #55
Old September 18th, 2012, 03:44 PM   #11
headshrink
headshrink's Avatar
I don't recall the exact torque value off hand, but the cam cap bolts aren't supposed to be be torqued that much. Sorry it's such a PITA.... I've certainly been there.
Old September 18th, 2012, 03:48 PM   #12
dino74
dino74's Avatar
Here's some ideas if you do try what they did in the video
Drop some rust penetrating oil into the hole.
Let it sit for a hour and occasionally tap (lightly) the broken bolt with a metal punch. This helps the oil get between the treads.
When you drill the bolt, measure the broken bolt so you know how deep to go without drill through the broken bolt.
CVMA #55
Old September 18th, 2012, 03:52 PM   #13
Originally Posted by dino74 View Post
Pun intended?
if it wasn't, that would have been a pretty ****** post.
Old September 18th, 2012, 04:23 PM   #14
cuz
cuz
cuz's Avatar
I smell a DIY
THE GOOD LIFE
Old September 18th, 2012, 04:24 PM   #15
Originally Posted by cuz View Post
I smell a DIY
on how to rotate pictures?
(j/k, good luck! )
Old September 18th, 2012, 04:56 PM   #16
@Nemesis *poke*
Old September 19th, 2012, 05:56 AM   #17
cuong-nutz
cuong-nutz's Avatar
Cuz, I thought you finished putting the bike together. If you finish, come out Saturday for the clean up and ride.
Have to ask, was this putting it all back together or taking it apart
HalfFast Racing Team
Old September 20th, 2012, 09:52 PM   #18
cuz
cuz
cuz's Avatar
Wd-40 ftw
My drill was to big.(zing) So had to pull the engine out to get a clean strait shot at the bolt. Soaked it w/40 had it over night and it came right out so easy that the bit didn't make a hole.
use a left hand drill bit GOING reverse
THE GOOD LIFE
Old September 21st, 2012, 08:14 AM   #19
cuong-nutz
cuong-nutz's Avatar
I see you got new tires. You REALLY need to clean up all those wires dangling.
Old September 22nd, 2012, 08:48 AM   #20
Lychee
sail away
Lychee's Avatar
nice pjs
valve cover gasket drewsley 1986 - 2007 Ninja 250R Tech Talk 8 August 21st, 2014 04:59 PM
Trouble removing valve cover. Floki 2008 - 2012 Ninja 250R Tech Talk 6 January 4th, 2014 06:06 AM
Removing the Valve Cover n4mwd 1986 - 2007 Ninja 250R Tech Talk 19 June 24th, 2013 08:25 PM
Broke a damn rocker arm during valve adjustment. SV_Hadder 1986 - 2007 Ninja 250R Tech Talk 7 April 3rd, 2013 03:00 PM
Ebay lever broke my clutch lever mounting bolt! pilotgeorge747 2008 - 2012 Ninja 250R Tech Talk 8 December 22nd, 2011 07:22 AM
