#1 |
Join Date: Jun 2012 Motorcycle(s): the cool ones Posts: 182
need help with install Koso DL spedometer!
Alright When I bought my ninja it had no instrument panel but I figured I could just get one.
This is the one I got and it just came in today. http://www.kosonorthamerica.com/new/...ometer-55mm-4/ Right off the bat I'm confused (I'm a total newb to motorcycles). these are the instructions, however I have questions on the wiring. http://www.kosonorthamerica.com/inst...s/BB552B70.pdf Does the red connect directly over the positive terminal of the battery? Where do I find the wire for the fuel gauge? How exactly do I connect the brown wire to the ignition key? Any help or advice would be greatly appreciated Here's an actual pic of wires on the speedo if it helps. http://i.imgur.com/L0NtO.jpg |
#2 |
Hi - have you reviewed the Koso threads on this site already?
Here's one from the DIY sticky thread at the top of the tech section: DIY: Installing Koso Gauges
#3 |
ahh yes, I did. That actually answered my first question. But in that case the used a plug and play kit for the specific speedo. From the looks of it I need to do some splicing for the green fuel wire, except I'm not sure where. And I still have how to wire the brown wire to the ignition.
#4 |
So I did a bit of looking in the wiring diagram and figured out all my questions except for one.
how to do connect the brown wire to the ignition(which is need according the the instructions?) the red must go directly to the battery's positive terminal, the green and black require splicing on the bikes harness and connected to the light green/black wire and black/yellow wire (respectively), and the brown goes to the ignition, but I'm not sure how? which color wire do I connect it to? The instructions also say that the red and brown wires must not be in parallel. http://www.mickeywebpages.com/users/...e_Dia_v1.1.gif |
#5 |
ModMy250.com
I installed a similar gauge (made by koso) and it died a couple months back. I hope yours last longer.
In regards to the brown wire, just tap it off the low beam head light or run an extension and connect it to the license plate light. You don't need to attach it to the ignition wire, just a wire that is +12v only when the engine is on. Use a wire tap and it shouldn't take very long. |
#6 | |
Hope mine lasts. and thank you so much that was all I needed to figure this out! Ill try that first thing tomorrow morning. ![]() |
#7 |
ModMy250.com
just over a year.
DIY: koso gauge install | dyeforever | 2008 - 2012 Ninja 250R Tech Talk | 207 | March 30th, 2017 03:50 PM |
Koso RX-1N guage install help | UnshavenCanuck | 1986 - 2007 Ninja 250R Farkles | 5 | May 12th, 2014 10:12 AM |
Koso gauge install question | randomwalk101 | 2008 - 2012 Ninja 250R Tech Talk | 6 | February 17th, 2012 01:54 PM |
Koso gauge & gear Indicator install | randomwalk101 | 2008 - 2012 Ninja 250R Tech Talk | 4 | February 20th, 2011 10:32 PM |
For the next person to install a Koso gauge cluster... | headshrink | 2008 - 2012 Ninja 250R Tech Talk | 8 | October 26th, 2010 06:25 AM |
