Old April 10th, 2015, 02:22 PM   #1
bad vibe
Motorcycle(s): 2014 Ninja 300 SE ABS
wtb Rear Gel Comfort seat, or whole set
looking for some booty support for my lovely lady on the rear, i wouldnt mind the front either but if anyone isnt using the rear that would be awesome, Kawi Girl is fine too
bad vibe is offline   Reply With Quote
Old April 10th, 2015, 03:32 PM   #2
Kevin1956
Kevin1956's Avatar
@bad vibe: I've never had gel seats, but a friend did and absolutely hated them. He felt they were too squishy for good handling (an ex racer), but his biggest complaint was how they really heated up and held it when left in the sun. The same went for cold weather too. The semi-liquid gel wants to hold the ambient temperature. You may want to try a pad that straps to the rear seat to see if it even makes a significant difference in comfort first. Gel seats can be pretty pricey. Another alternative is to have additional, or different grade, foam installed in your rear seat. If needed, a ''skirt'' can be sewn to the stock seat cover allowing room for more padding, and you won't end up with mismatched upholstery either.
Last futzed with by Kevin1956; April 10th, 2015 at 05:09 PM.
Kevin1956 is offline   Reply With Quote
Old April 11th, 2015, 06:57 AM   #3
bad vibe
just want a comfy seat, plenty of front options but rear im not aware of any other than oem and custom, just seeing if anyone got the oem (comfort gel/gel channel) set and is using a solo rear cowl and wants to unload, I can deal with hot / cold posterior
Last futzed with by bad vibe; April 22nd, 2015 at 07:19 AM.
Old April 22nd, 2015, 06:05 AM   #4
HKr1
IC2(SW)
HKr1's Avatar
So, your looking for the oem front and rear seats?
Old April 22nd, 2015, 07:12 AM   #5
bad vibe
oem Comfort Gel seat or Gel Channel seat oem option, not stock oem seats
to specify these are kawi#'s
Ninja 300 Gel Channel Seat Set K53001246
or
Ninja 300 Gel Comfort Seat Set K53001245
Old May 4th, 2015, 11:25 PM   #6
PacificNW39
Motorcycle(s): Ninja 250R
PM sent!
PacificNW39 is offline   Reply With Quote
