Old November 7th, 2015, 11:56 AM   #1
gokartmozart
gokartmozart
gokartmozart's Avatar
Motorcycle(s): 250 ninja ,it's realy a ninja motor on a scratch built alum chassis (avatar is my old kart)
vent hose transmission 250
Has anybody removed the stock airbox , for any reason ? I'm replacing the stock airbox for what I call a "fuel tank/airbox" (my own design) * details if interested * question here is, what to do with the vent hose coming from the top of the trans? Install a breather filter or what ? thanx for any help
gokartmozart is offline   Reply With Quote
Old November 7th, 2015, 12:16 PM   #2
Yes, it's fairly common.
For the airbox removal:
https://www.ninjette.org/forums/showthread.php?t=11899
The hose out of the crank case under the airbox is a crankcase vent. When the airbox is removed, this gets a little bitty filter jammed onto it. This UNI breather fits if you keep the OEM "S" shaped rubber part:
"Uni Filter UP-103 1/2" Clamp-On Breather" I can't get the amazon link to work. But search the quoted name to find it.
FYI: the ninja250.org wiki is another awesome reference for typical stuff done to these engines, service, jetting, etc etc.
http://faq.ninja250.org/wiki/Ninja250_Howto
Google search is a great thing also. For example, "ninjette.org: airbox" should get you some info. That's all I did. Or you can search the ninja250 wiki the same way. "faq.ninja250.org: pod filter" or whatever you're interested in. You'll find those direct links, plus other forums where people have linked the URL of things like what you're searching for.
Old November 7th, 2015, 01:14 PM   #3
xXecuterXx2
ChocolateMilk Addict
xXecuterXx2's Avatar
Motorcycle(s): '05 EX-250 "Kallie" 85 KLT 110 ATC "Murdock"
well, not much else to say but
Burn Rubber, not your Soul.
xXecuterXx2 is offline   Reply With Quote
Gas vent hose for carburetor brian12 1986 - 2007 Ninja 250R Tech Talk 10 October 5th, 2015 07:23 AM
"Carb vent hose" ninja250 2008 - 2012 Ninja 250R Tech Talk 10 January 9th, 2010 05:15 PM
