Old February 11th, 2013, 01:40 AM   #1
novak2k9
Motorcycle(s): 2008 250r
How many links do I reduce my chain if adding 15t front sprocket, stock rear?
I'm adding a vortex 15t front sprocket, keeping rear stock at 45t. So essentially adding 1 tooth to the setup
The chain I got is a DID 110 link, so since stock is 106, do I reduce it to 107 links or keep it stock 106 and just adjust rear tire to spec chain slack?
Plan on doing this tomorrow.
Also has if anyone has changed to a vortex 15t front, any shimming involved?Guess I'll find out tomorrow
thanks
novak2k9 is offline   Reply With Quote
Old February 11th, 2013, 02:09 AM   #2
Stock 106 is fine. One tooth is well within the adjust-ability of the tensioners. 15T is the first upgrade many people do and I've never seen people get a new chain with it unless it was time to swap anyway, which I'm guessing is your situation.
Old February 11th, 2013, 02:25 AM   #3
novak2k9
Thanks for clarifying.. after an hour of searching I've dug up some info regarding older 250's keeping stock chain links with a 15t, so I figured my 08 was safe to keep at 106. Yup my bike has 18500 on it and planned on just changing everything out. Rear sprocket was a bit worn.
Can I get away with a 104 link chain with stock gearing? If not, what rear sprocket? CZroe 2008 - 2012 Ninja 250R Tech Talk 5 June 16th, 2012 06:26 AM
Adding a rivet master link to the stock chain ??? Tiane 2008 - 2012 Ninja 250R Tech Talk 1 June 13th, 2012 12:58 AM
15t front sprocket swap! play2pwn 2008 - 2012 Ninja 250R Tech Talk 3 October 17th, 2011 09:17 AM
15t jt front sprocket and now noise? greatwhiteninja 2008 - 2012 Ninja 250R Tech Talk 25 August 30th, 2011 08:34 PM
New 15t sprocket/chain alignment issue. headshrink 2008 - 2012 Ninja 250R Tech Talk 46 February 17th, 2011 01:45 PM
