Old June 14th, 2013, 12:25 PM   #121
FvnnyL3tt3r1ng
FvnnyL3tt3r1ng's Avatar
Motorcycle(s): Ninja 250 2001
N4mwd- I looked for the info on reading your crankcase to match it with the bearings in the service manual but I came up with nothing. Do you know where to find the info?
Old June 14th, 2013, 01:13 PM   #122
n4mwd
n4mwd's Avatar
Page 8-5 and page 8-14. Note the marks are in ink and not stamped. The crankcase has to be matched with the crankshaft and harmonic balancer using the appropriate bearings ($10/each half X 10 halves). The crankshaft and harmonic balancer also have markings but you obviously can't see those right now.
Getting a case with identical markings doesn't guarantee you wont need new bearings, it just improves your odds.
http://www.ebay.com/itm/110970784222...84.m1436.l2649
Hows that look? Granted it's the right model?
I don't see anything wrong with it. I also noticed that it has the bearings still installed - that's a plus but nothing to party over. The first photo shows the checkerboard where the marks should be. The squares will either ha e a dot or not. I don't see any dots, but the bearings are already there. If your bike has no dots, then its a match. Remember the dots are like paint or ink or something like that. They are not stamped.
But before you go this route, I would personally remove your engine and split the case to see if there are any more surprises if it was my bike.
Based on what we know, it doesn't sound like there was a valve - piston impact or a serious timing error. That's good. But you do know the chain was messed up so that's $60 for a new one. And if it turns out the crank is messed up in any way, it has to be replaced because they cannot be repaired.
The guy that is selling the whole engine is just up the road - well within head smashing distance if it comes to that. I would ask him if he would give you a discount if you pick it up in person. This is something you should consider if you want a faster solution to the problem.
But if you just want a learning experience then replacing the case is the way to go. Once you have the case and your engine out, you can bring them over here and I'll put it on my stand and we'll swap all the parts to the new case.
My Ninja Blog
Old June 14th, 2013, 01:17 PM   #123
n4mwd
n4mwd's Avatar
Also, putting the case together requires a bit of frustration and the use of plastiguage. You have to completely assemble the engine with the crank and harmonic balancer in place and the plastiguage and tighten all the bolts. Then you have to take it all apart again and check to see if the plastiguage is squished to the right width. If not, you have to buy new bearings and repeat the whole process.
My Ninja Blog
Old June 14th, 2013, 02:09 PM   #124
FvnnyL3tt3r1ng
Do you think the whole plastigauge ritual is necessary for my 20k mile engine? I'd like to throw it back together and get it running again asap. My other vehicle sucks gas like it's going out of style it's costing me a lot to drive it every day.
Edit: I should be on my vehicles forum asking questions about why my gas mileage is so low ha.
Old June 14th, 2013, 05:57 PM   #125
n4mwd
n4mwd's Avatar
The plastigauge is mandatory. The engine tolerance is in microns. No wiggle room.
My Ninja Blog
Old June 14th, 2013, 07:41 PM   #126
baxtc1
baxtc1's Avatar
Motorcycle(s): '92 GPX 250 (Gone and replaced with '08 V-Strom), 2005 Suzuki C50.
Also, as explained in the manual, don't replace half crankcase on it's own, always replace both halves as a pair.
baxtc1 is offline   Reply With Quote
Old June 15th, 2013, 01:36 PM   #127
FvnnyL3tt3r1ng
Engine has been dropped. This will be an excitiing rebuild for sure!
Old June 15th, 2013, 05:19 PM   #128
n4mwd
n4mwd's Avatar
Have you decided how you are going to handle it? New case or new engine?
EDIT: Nevermind, I see someone bought the case you were looking at. However, it really would have been a good idea to wait until you see what the condition of your crank is in. If the crank is bad, its around $500 to get a new one.
My Ninja Blog
Old June 16th, 2013, 10:02 AM   #129
FvnnyL3tt3r1ng
I'm going to buy a used engine and take my time rebuilding this one. Maybe I'll keep it after, maybe I'll sell it.
Old June 16th, 2013, 12:46 PM   #130
n4mwd
n4mwd's Avatar
Its nice having a hot spare. I recommend keeping it well lubicated, especially in the cylinders, and storing it indoors in the A/C. I say that because if you store it outdoors, condensation will fill the cylinders with water and rust everything up.
I saw a guy in Gainsville that had a set of plastics for the pregen for sale, but he wanted too much for them. Would you consider new ones if the price was right? Do they have to be red?
My Ninja Blog
Old June 16th, 2013, 04:10 PM   #131
FvnnyL3tt3r1ng
I'd only buy plastics to sell the bike honestly. I'm pretty sure they'd get in the way of my clip ons anyways.
Old June 17th, 2013, 06:45 PM   #132
FvnnyL3tt3r1ng
Spare engine
So frustrated I'm too tired to put her in the bike tonight. School will wait tomorrow until this is finished
Old June 17th, 2013, 07:42 PM   #133
n4mwd
n4mwd's Avatar
Came kinda quick. Did you go up and get it? Not sure if skipping class is a good idea though. Depends on the subject I guess.
My Ninja Blog
Old June 18th, 2013, 02:10 PM   #134
FvnnyL3tt3r1ng
Didn't have to skip any class.
Drove up to Tampa and back yesterday, put her in this morning. She drives very nice now!!!
Now I'm searching for the operating temp the radiator fan is supposed to switch on because I'm not sure it's doing that automatically yet!
I read up to 210 F I believe w/ no fan blowing so I'm a little worried about that...
Edit: Read on the 250 wiki page it kicks on at 225F so I guess I'm good so far. Gonna put that into my gauge.
Learned this morning how important it is to keep the engine mounting bolts loose until your radiator is on!!! That last bolt wouldn't go through so I had to pull the front sprocket cover off, loosen all the bolts, take one of the engine mounting bolts out until I got the radiator's bolt through, then torque all of them down.....
Also, putting the headers on before the radiator is also a pretty good idea. Doh
Now I have a spare 16t sprocket even though I run a 13 in front.
Old June 18th, 2013, 04:10 PM   #135
n4mwd
n4mwd's Avatar
Congratulations on getting it running. Are you sure its a 16T and not a 15T? I heard that 16T sprockets don't fit.
I didn't follow you about the radiator bolts. Are you sure you didn't mean the front motor mount brackets. Anyhow, its definitely best to keep all three loose until they are all in - then torque them all at once.
I'm sure you put new oil in it. A lot of times salvage dealers drain it for shipment.
Question: What kind and where did you get your compression gauge? There aren't that many that will do a 10mm plug hole.
My Ninja Blog
Old June 18th, 2013, 06:22 PM   #136
FvnnyL3tt3r1ng
I got mine at harbor freight. Mine came w/ the right size. It's the smallest piece of the set. I also got my leakdown tester there which did not come with the right size so I have to use the compression tester's piece with it.
I'm having an issue now with starting the bike. I'll stop after riding for a period of time and it doesn't want to start. If I sit there and wait it will fire up again with a lot of choke. It died once while I was driving it at a low speed........ I hope it's not my jetting and I do suspect the battery might be going. If it doesn't start tomorrow before work and I jump it with my van's battery then I'm going to get it tested.
Old June 18th, 2013, 06:55 PM   #137
n4mwd
n4mwd's Avatar
I bought the harbor freight tester too. It has over a yard of hose which lowers the value. It only showed about 35 psi on both cylinders on mine. I am a little concerned.
But in your case, is your petcock working OK and your fuel filter? Any issues at high speed & under load.
Your battery is easy to test with a voltmeter. See my battery blog here.
Any chance you wired the coils back incorrectly?
My Ninja Blog
Old June 19th, 2013, 06:04 AM   #138
FvnnyL3tt3r1ng
My compression tester hose is about a foot long and tests my psi just fine....
Maybe we have different ones.
My petcock has needed a rebuild for a while but it is flowing fuel (just not stopping fuel in "Off"). The bike has been flying so I'd be surprised if it was a tuning issue. I'll check the voltages later on today.
Old June 19th, 2013, 04:37 PM   #139
Lychee
sail away
Lychee's Avatar
Dude- glad you are back on the road! (sort of...)
Old June 19th, 2013, 06:07 PM   #140
FvnnyL3tt3r1ng
sort of?
You must have known I got 2 tickets today. GGRRRRRRRR
Old June 19th, 2013, 06:15 PM   #141
n4mwd
n4mwd's Avatar
sort of?
Tickets? For what?
My Ninja Blog
Old June 19th, 2013, 09:04 PM   #142
FvnnyL3tt3r1ng
Tickets? For what?
speeding (no speedo hooked up yet) and no blinkers (also not installed)
Old June 20th, 2013, 03:47 AM   #143
n4mwd
n4mwd's Avatar
I guess that was the front blinkers. I'm surprised that he didn't say something about your new front plastic and its headlight.
As far as the speedo, I thought your new gizmo did speed. What does it do if not speed?
The rear blinkers can integrate into the tail light.
Anyhow, wait about a month and the lawyers will come out of the woodwork begging to get you off. The blinker ticket goes away as soon as you fix it and take it to the county clerks office to inspect it. And pay them $10 I think. Good luck with it. With the speeding, you can elect to pay the fine without points if you have a decent driving record by pleading no contest. The problem is that the news of your speeding ticket has probably already spread like wild fire amongst all the insurance companies.
I really think some factory plastics would solve a few of the problems. At least the blinker issue.
My Ninja Blog
Old June 20th, 2013, 09:28 AM   #144
Lychee
sail away
Lychee's Avatar
sort of?
sort of back on the road, meaning major issues fixed but bike still has issues...
Old June 20th, 2013, 01:33 PM   #145
FvnnyL3tt3r1ng
I have no rear blinkers because I still need to order the clear lenses in the rear. If anyone has the link to that site I'd appreciate it. I believe I got them for $12 last time?
Isn't there a 30 day limit to pay your ticket from date of issue? I'm definitely going to elect a lawyer this time. I already took the traffic school in Dec. so that's a no go anyways. I'm going to try and slow down and stay OFF of southern blvd from now on.
The gauge reads speed but you have to install the magnet and cable for it first! I got the tach working yesterday it's probably the only thing I'm unhappy about. I think I may try to take the tach out of the stock gauge and re-install it. Nothing beats that needle.
Old June 20th, 2013, 01:37 PM   #146
FvnnyL3tt3r1ng
ok gotcha.
I think I have to re-tune the jetting it's honestly hard to tell sometimes!
Old June 20th, 2013, 01:55 PM   #147
FvnnyL3tt3r1ng
Found these for less than $20 last time I swore. Does anyone know where they can be found cheaper?
http://www.ebay.com/itm/Advanced-Lig...b325f8&vxp=mtr
Old June 20th, 2013, 02:50 PM   #148
Lychee
sail away
Lychee's Avatar
Don't think these are made anymore. Price might be right.
Old June 20th, 2013, 03:49 PM   #149
n4mwd
n4mwd's Avatar
You've already got red rear lenses. All you need is two of [these]:
Or similar. You just need to get one that is the right size for the hole and has a single wire (you need to add a ground wire).
My Ninja Blog
Old June 20th, 2013, 06:11 PM   #150
FvnnyL3tt3r1ng
I vaguely remember reading the florida statue that stated your signals had to be amber in color...
Old June 20th, 2013, 06:23 PM   #151
n4mwd
n4mwd's Avatar
I think that only applies to the fronts. The rears can be either amber or red.
My Ninja Blog
Old June 21st, 2013, 08:39 AM   #152
FvnnyL3tt3r1ng
http://www.leg.state.fl.us/Statutes/.../0316.224.html
Looks like you're right
Old June 21st, 2013, 09:31 AM   #153
n4mwd
n4mwd's Avatar
If you integrate your tail lights, make sure you measure and get the right sized bulb socket for a single wire bulb - Dorman #85806 for a 3/4" hole. I'm not positive on the hole size so you should measure it to be sure.
Then solder a ground wire on it. To mount it in the hole, you might have to use JB-Weld.
My Ninja Blog
Old July 10th, 2013, 04:10 PM   #154
FvnnyL3tt3r1ng
Ok so with the new engine in and the new thermo switch the bike is starting to get really hot at stop lights. It got up to 240 today and the fan kicks on well above 225... I'm guessing I have the problem isolated to the radiator and the thhermoswitch but I'm a little confused as to why the thermoswitch would function normally for a couple weeks then stop???? Should I look into a new radiator and thermoswitch??
Old July 10th, 2013, 04:31 PM   #155
sousuke86
sousuke86's Avatar
Motorcycle(s): 2011 Ninja 250R SE
I did not read through the entire thing but have you tried bleeding the system? Sometimes air bubbles get caught in there and cause the coolant to not flow
sousuke86 is offline   Reply With Quote
Old July 10th, 2013, 04:39 PM   #156
FvnnyL3tt3r1ng
That brings up a good point. I had knocked the radiator cap off halfway during one ride and maybe that let air in!!!!
But shouldn't that problem correct itself automatically?
Old July 10th, 2013, 06:18 PM   #157
n4mwd
n4mwd's Avatar
Running with the radiator cap off will actually let the air out. Or more specifically, brings the air pocket to the radiator where you can fill it up.
It sounds like the same problem you had before. The cooling fan doesn't really work that well unless you are sitting still with the engine on. Getting hot while idling or moving slow doesn't really count. What counts is your over 40 mph speed. That shouldn't get more than 1/3 the way across on a day like today.
Did you put a jet kit in your carb or modify the needles?
Are you using regular antifreeze?
My Ninja Blog
Old July 10th, 2013, 06:25 PM   #158
FvnnyL3tt3r1ng
The temp used to stay below 230 while sitting at traffic lights.... The radiator fan would kick on at about 221 and drop the temp a lot faster than it has been.
I have a jet kit in but I've never had problems with overheating after my install. I've used dex-cool for the entire time I've owned the bike.
Old July 11th, 2013, 06:45 AM   #159
n4mwd
n4mwd's Avatar
It sounds like your switch is bad. Or it could also be the fan or wiring. The connector on the switch could be dirty or not connected properly.
Do you have the proper spark plugs, NGK CR8HSA, in there? The wrong plugs can make it run hotter than its supposed to.
It really sounds like your switch is bad. Most of those switches have wax inside them them that expands and pushes on a pushbutton switch. The wax can leak out causing the activation temp to increase. A new one is $50 at the dealer. Ebay has used ones, but you already have a used one.
If you've tested the fan motor by shorting the two connections in the connector and it comes on, then the only thing left is the switch.
If your switch has only one prong instead of two, then you could have a ground problem The two prong switches don't need a ground.
My Ninja Blog
Cooling issue... braaap 1986 - 2007 Ninja 250R Tech Talk 42 May 5th, 2014 10:14 AM
Radiator cooling fan wiring Eagle981 1986 - 2007 Ninja 250R Tech Talk 7 March 4th, 2013 07:19 PM
Cooling System Issues AlfredoGonzalez 1986 - 2007 Ninja 250R Tech Talk 8 January 4th, 2013 02:14 PM
anyone have experience with cooling vests? oblivion007 Motorcycle Gear 24 July 21st, 2012 08:04 AM
Phase Change Cooling Vest PitBull Motorcycle Gear 15 July 2nd, 2010 08:06 PM
