Old October 20th, 2013, 10:11 AM   #201
FvnnyL3tt3r1ng
FvnnyL3tt3r1ng's Avatar
Motorcycle(s): Ninja 250 2001
Originally Posted by cuong-nutz View Post
A pressure tester will. I wonder if Autozone loans them out.
Yeah $180 deposit
Harbor freight sells them for $80.....
Mods: Offset clutch pressure plate
Old October 20th, 2013, 01:45 PM   #202
n4mwd
n4mwd's Avatar
I'm not sure what a pressure tester will get you. Are you trying to test your coolant pressure? Its not going to go above what the radiator cap is set for.
Since you changed a bunch of stuff when you were searching for your overheating problem, I would start by looking at that stuff first. Didn't you change the radiator cap? Did you reconnect the radiator overflow tube to the tank?
My Ninja Blog
Old October 20th, 2013, 02:04 PM   #203
FvnnyL3tt3r1ng
Testing what part of my cooling system is not holding pressure because of a leak.
Already looked everything over.
Old November 1st, 2013, 06:51 PM   #204
FvnnyL3tt3r1ng
Ran compression test tonight and got ~85 psi in cyl 1 and 110 in cyl 2...... Gonna be putting the other engine back in it tomorrow morning since I've got it all fixed up....(or do i )
Old November 1st, 2013, 07:35 PM   #205
n4mwd
n4mwd's Avatar
That's a pretty significant differential. A 10-15 psi might be OK, but that's a lot. Can you do a leakdown test and compare those results?
Was that with a new set of pistons and rings you bought on ebay? How many miles on the donor bike?
My Ninja Blog
Old November 1st, 2013, 07:51 PM   #206
FvnnyL3tt3r1ng
A leakdown test wouldn't be a bad idea. Yes, and 14k miles.
Old November 2nd, 2013, 04:00 PM   #207
FvnnyL3tt3r1ng
Started a leakdown test until once again my hose gets stuck inside the cylinder head. It spins now but is not de threading so I'm guessing it is spinning inside it's own connector.
I got a tight airseal for cyl 1 at tdc before the hose stuck in there. GRRRR
Old November 2nd, 2013, 04:11 PM   #208
n4mwd
n4mwd's Avatar
Time to throw that hose away. Didn't you say it got stuck before?
I'm not sure what to tell you as far as getting it out. Was the engine hot or cold when you put it in there?
My Ninja Blog
Old November 2nd, 2013, 06:12 PM   #209
FvnnyL3tt3r1ng
Cold engine. This was a different hose. The other one is for the compression tester and has a different size fitting.
Whatever the case that engine is now out and on my workbench for me to butcher up.
Old November 2nd, 2013, 06:47 PM   #210
n4mwd
n4mwd's Avatar
I'm not sure what they were thinking putting a swivel on the end like that. Any way to get a long pair of needle nose pliers in there?
My Ninja Blog
Old November 2nd, 2013, 07:16 PM   #211
FvnnyL3tt3r1ng
Doubtful. I'll figure something out. I've gotta figure out why this engine doesn't like compression in the meantime.
Racer X engine rebuild. Racer x 1986 - 2007 Ninja 250R Tech Talk 14 April 21st, 2018 04:26 PM
Engine Teardown and Rebuild Rustitution 1986 - 2007 Ninja 250R Tech Talk 77 February 27th, 2017 09:17 PM
Need Help Oil,engine rebuild meggyewill 1986 - 2007 Ninja 250R Tech Talk 10 July 22nd, 2014 02:39 AM
Two quick engine rebuild questions jayman87 1986 - 2007 Ninja 250R Tech Talk 16 March 3rd, 2013 07:26 AM
Engine Rebuild Question jayman87 1986 - 2007 Ninja 250R Tech Talk 16 December 21st, 2012 09:30 PM
