May 1st, 2014, 06:29 PM | #1 |
Join Date: Mar 2013 Motorcycle(s): 08 cbr1000rr, 2008 + 2012 ninja 250, 06 zx6r (636!) track only Posts: 150
Blinkers not blinking Hallllp!
Buddies 08 250 blinkers don't blink, shoot me some ideas!
Stock lights all around 1. Blinkers dont blink, but the lights are on rear and front 2. Occurs on both sides 3. The license plate light is on 4. brake light is working 5. Headlights are working 6. High beams work What is my next step? Ive read so far that sometimes water can get in the switch area (well any where but this was a common finding) Where is the relay?
http://www.1000rr.net/forums/showthread.php?t=90412 http://www.8thcivic.com/forums/ http://www.facebook.com/profile.php?id=1209877267 |
May 1st, 2014, 06:42 PM | #2 |
Hm. Perhaps a bad flasher? Its located inside on the left rear fairing and can be accessed when you removed the seat.
May 1st, 2014, 06:58 PM | #3 |
Join Date: Jun 2013 Motorcycle(s): 2010 Ninja 250 Posts: 596
Check the front left bulb as well as the flasher relay.
If the problem happens to be with the relay, replace it with the Tridon/Novita EP34 relay found in any autoparts store. |
May 1st, 2014, 07:28 PM | #4 |
Join Date: Jun 2013 Motorcycle(s): 2010 Kawasaki Ninja 250R (Passion Red, Ca Model) Posts: 107
Make sure the wiring is good. I had a short on one of my blinkers the wiring was kinked up prity bad so i removed that section of wire and fixed the problem.
I would be rich by now if I had a dollar for every person that has told me "You need to upgrade, You need a bigger bike, You need more power..." |
May 2nd, 2014, 02:54 AM | #5 | |
Well as in orginal post that light is working (stays on)
May 2nd, 2014, 09:16 AM | #6 |
Hello Moto
Join Date: Mar 2013 Motorcycle(s): 1975 RD350; 2001 KX125; 2003 Z1000; 2003 KDX50; 2009 ZX6R; 2011 Ninja 250R; 2014 KX250F Posts: 352
May 2nd, 2014, 09:35 AM | #7 |
not an actual panda
Join Date: Aug 2012 Motorcycle(s): 2008 Ninja 250, 2009 CBR600RR (Sold) Posts: A lot.
May 2nd, 2014, 09:37 AM | #8 |
Join Date: Mar 2014 Motorcycle(s): 2005 Ninja 250 Posts: 3
will the Tridon/Novita EP34 work on an 05 ninja 250???
I'm having the same issues... |
May 6th, 2014, 07:53 AM | #9 |
Bump for response, thanks
June 12th, 2014, 11:05 PM | #10 | |
BTW thanks guys, got the replacement for 12 bucks and worked great!!!!!
Turn Signals ? nothing .... no blinking! | Klondike1020 | 2008 - 2012 Ninja 250R Tech Talk | 2 | July 17th, 2013 08:52 AM |
Turn Signal lights but no blinking | Murtasma | 2008 - 2012 Ninja 250R Tech Talk | 3 | August 1st, 2011 06:06 PM |
1) Turn signal not blinking, 2) Brake modulator down | MysterioX | 2008 - 2012 Ninja 250R Tech Talk | 3 | May 28th, 2011 03:00 PM |
Turn signals not blinking | singlecoillover | 1986 - 2007 Ninja 250R Tech Talk | 6 | March 4th, 2010 11:00 PM |
Fast blinking turn signal | austexjg | 1986 - 2007 Ninja 250R Tech Talk | 9 | December 31st, 2009 10:46 AM |
