Old January 7th, 2010, 06:15 PM   #1
ASecretNinja
ATGATT Squid Killer
ASecretNinja's Avatar
Motorcycle(s): '06 CBR600
soft spot between 6k-7.5k RPM
Man what a difference temperature makes on our small displacement carb'd engines. I've noticed a bit of a soft spot right around 7k RPM. When I say soft spot, it's the same feeling that the bike makes when its starting to run out of gas. I know it's a jetting issue, but I don't know what it could be. Could shimming the needles take care of the problem? Obviously if I am hard on the throttle accelerating this is not an issue, but I really notice it when I'm semi cruising. It's not a big deal at all, and I bet a lot of riders wouldn't even notice it. I'm really just looking for an excuse to play with my bike lol. Thanks for any help.
Edit: why the hell did I post this in farkles? Sorry!
ASecretNinja is offline   Reply With Quote
Old January 7th, 2010, 08:02 PM   #2
Snake
Snake's Avatar
Shimming the needles will help out quite a bit. Cold air is denser and will lean out the air/fuel mixture. Something else you should look at is your filter to make sure it is not clogged and you are getting plenty of air.
Old January 8th, 2010, 12:44 AM   #3
/moved to tech...
Old January 9th, 2010, 01:00 AM   #4
Verus Cidere
Verus Cidere's Avatar
Motorcycle(s): '91 Honda CBR600 F2
You're running lean. I'm having the same problem with my AP exhaust ATM. Shim the needles, bigger main jet, etc.
1991 Honda CBR600 F2, White/Gray, D&D slip-on exhaust, tail integrator, gel grips, Custom undertail.
Verus Cidere is offline   Reply With Quote
Old January 9th, 2010, 10:01 AM   #5
Snake
Snake's Avatar
Chad try this jetting database and add your own info when you are done.
Old January 30th, 2010, 12:12 AM   #6
oldbutnewbie
Motorcycle(s): 2002 ex250f,1981 kz550ltd, 1999 vs800
I had this very same problem 2002 model.I had already pulled the welch plugs and adjusted the idle screws out [factory setting was all the way in on side and 1 1/2-2 on the other].They are now out 3 1/2-4 rounds...this got the engine to run better.Installed a 4mm washer under the needles.Ran great with accelleration=had the 6500-7500 rpm cruising leanout shudders.Installed a 2nd 4mm washer under the needles=fixed it.
oldbutnewbie is offline   Reply With Quote
Old January 30th, 2010, 05:59 PM   #7
nate-bama
North Alabama Mtn. ryder
nate-bama's Avatar
Motorcycle(s): 2006
you could stay in the power band, and presto no worries
QTRltrPWR
nate-bama is offline   Reply With Quote
Old January 30th, 2010, 08:58 PM   #8
Zim
Motorcycle(s): '04 EX250F
What database?
Zim is offline   Reply With Quote
Old February 4th, 2010, 12:18 AM   #9
ASecretNinja
ATGATT Squid Killer
If the bike wasn't slumping at the RPM range I indicated then I would be in the power band, now wouldn't I? At any rate, I'm more interested in fuel economy and not taxing my engine too hard. Looking to sell this thing in the Spring.
I've got the washers, just haven't had time to try this out. Maybe tomorrow! And why is everyone saying 4mm? I thought the DIY said 3mm?! I bought 3mm..
Old February 4th, 2010, 01:43 PM   #10
nate-bama
nate-bama's Avatar
Motorcycle(s): 2006
Wink
well at first you said kinda a soft spot..but you can't get past 8k? that would sound like a diaphram leak or a unseated intake boot
QTRltrPWR
Old February 4th, 2010, 06:40 PM   #11
oldbutnewbie
4mm is what I used;just for the thickness and trial/error of the situation=sometimes you win! My pipes are factory and the air filter is factory...the bike was so lean I really don't see how it was running.As I had posted earlier,the soft spot was 6500-7500 on my engine...anything above or below was fine...8000 cleared up and it pulled from there.As of now,I took it on a test run up Lookout Mtn. and on some town cruising.The soft spot is not there...just a few thoughts,hope it helps.
Old February 4th, 2010, 06:54 PM   #12
nate-bama
nate-bama's Avatar
Motorcycle(s): 2006
Wink
todd i live on lookout..wanna race?
QTRltrPWR
Old February 4th, 2010, 10:40 PM   #13
oldbutnewbie
well...don't know about a race,but definitely meet up for a ride as soon as this weather gives a favorable break.I'm in Chattanooga.
Old February 5th, 2010, 06:27 AM   #14
nate-bama
nate-bama's Avatar
Motorcycle(s): 2006
yeah i was kiding about a race, usually goof off on the lookout mountain pkwy
QTRltrPWR
Old February 5th, 2010, 07:17 PM   #15
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
I noticed that dip in power from about 7-9 K. Using the programmable Brt-tis ignition I was able to add timing in that area . From about 7-8500 RPM I added 1-2 more degrees of ignition advance . The Dip still shows up on the Dyno .But I could not feel it at all on the street.
Just cleaned carbs - now stuttering at low RPM, fine at high RPM Ohio 2008 - 2012 Ninja 250R Tech Talk 20 August 5th, 2014 10:30 PM
[crash.net - MotoGP] - Fastest Espargaro hits sweet spot with soft rear Ninjette Newsbot Motorcycling News 0 June 26th, 2014 07:40 AM
Dead spot around 9k RPM walk_n_wind Ninjettes At Speed 4 June 5th, 2013 12:47 PM
Dead spot in rpm's chikenstrips 2008 - 2012 Ninja 250R Tech Talk 25 April 29th, 2012 08:13 PM
R6's RPM Francis General Motorcycling Discussion 16 January 23rd, 2011 04:41 PM
