Old April 8th, 2010, 08:15 AM   #1
lilninja
lilninja's Avatar
Motorcycle(s): 2009 Kawasaki ninja 250
crack on fairing
I have a small crack on the fairing. it started under the bike and has moved up the fairing. its about 2 to 3 in. long. it happened when the bike was loaded into a truck. i want to stop the crack from spreading. any ideas of what kind of glue to use or other ideas. dont really want to repaint because its not really noticeable right now. thanks for any ideas.
VPS Servers go to Filelan.com
lilninja is offline   Reply With Quote
Old April 8th, 2010, 08:21 AM   #2
Apex
Livin' the Minimoto Life
Apex's Avatar
To stop the crack from spreading, you have to drill out the crack. The current spot where the crack is, you need to drill at that point. The round hole prevents the crack from growing. Yeah, it doesn't look good, but it works.
You have to go with a pretty decent sized drill bit too. I'd rather see that than have a 100% cracked piece.
Don't drill right at the end of the crack, go a bit further ahead of it (not much though). The crack could be already starting directly underneath the paint where you can't see. So going a little ahead of it can prevent it from spreading.
Fixing the damage is another thing. First things first, stop the crack from getting worse...
Old April 8th, 2010, 09:58 AM   #3
dowmace
dowmace's Avatar
Motorcycle(s): 2006 Ninja 250
Yup just like Apex said drill a hole just a tad bit beyond the end of the crack, I usually use 1/8" bit's for this step. Now you need to use fiberglass polyester resin and fiberglass weave mat to repair the crack. If you need detailed help you can pm me.
I just wanna ride........
dowmace is offline   Reply With Quote
Old April 8th, 2010, 08:32 PM   #4
OldGuy
Live Life
OldGuy's Avatar
Motorcycle(s): 2009 Green SE Ninja 250
Lisa - this link will have more than you are looking to do right now but book mark it for future reference. The hole you drill does not have to be that big. Start with a small hole and if it tries to grow you can always drill a larger hole. Have fun.
- ATGATT -
Scorpion EX700 Hi-Vis Helmet, First Gear MeshTek 3.0 Jacket, TourMaster Transition 2 Jacket and Flex Pants, Sidi Doha boots
OldGuy is offline   Reply With Quote
Old April 10th, 2010, 09:31 AM   #5
addy126
Motorcycle(s): '09 Kawasaki N-250 + '09 Vulcan 900 Classic Lt
I'd just go buy a new stock fairing for that side since its a 2009 model.
addy126 is offline   Reply With Quote
Old April 10th, 2010, 11:48 AM   #6
noche_caliente
noche_caliente's Avatar
Motorcycle(s): '08 250
I did not drill mine out - we just used a fiberglass patch on the back of it that we got at advanced auto and overlaid it a few inches on both ends of the crack. It's held great for a year and a half now.
Progrip tank pad, blue rim stripes, blue Pazzos, Roaring Toyz lowering kit, Puig DB in dark smoke, Cortech sport tail, super mini tank, and saddlebags, OES swingarm spools and Intuitive frame sliders
Old April 10th, 2010, 02:29 PM   #7
dowmace
dowmace's Avatar
I know it looks fine right now, but I guarantee over time it's going to crack through the surface again, I've never seen a fairing crack stop until it was drilled out or the section cut out and replaced.
I'm not saying you didn't get lucky and it's the wrong way to do it at all, but I know from my experience it's better safe than sorry.
What kind of fiberglass did you use polyester or epoxy?
Old April 11th, 2010, 01:32 PM   #8
ASecretNinja
ATGATT Squid Killer
ASecretNinja's Avatar
Motorcycle(s): '06 CBR600
Maybe the problem is that you guys are using fiberglass to fix plastic. Any good plastic welder will tell you to not only use plastic to fix plastic, but specifically NOT use fiberglass to fix it.
ASecretNinja is offline   Reply With Quote
Old April 11th, 2010, 08:35 PM   #9
dowmace
dowmace's Avatar
Plastic and fiberglass have near identical expansion and contraction rates when using a polyester resin on the fiberglass. I have been using fiberglass on plastic parts for years and years with zero problems of the fiberglass and plastic separating or otherwise. I don't happen to know any "plastic welders" in my area.
Old April 11th, 2010, 08:42 PM   #10
ckholloway
ckholloway's Avatar
Motorcycle(s): none yet
I have to agree. I wouldn't drill any holes or use fiberglass. If you plastic weld it from the inside not only will it stop the crack but if there is no other damage the current crack will be hard to notice..
Riding is not just something you do, It's a way of life!!
ckholloway is offline   Reply With Quote
DIY: Fairing crack repair adouglas 2008 - 2012 Ninja 250R Tech Talk 59 June 5th, 2017 08:33 PM
You guys on crack? duggram General Motorcycling Discussion 41 May 15th, 2014 01:38 PM
Fairing Crack Re-repair eulark 1986 - 2007 Ninja 250R Farkles 2 October 28th, 2013 06:45 AM
Crack or Roll? Misti Riding Skills 83 December 6th, 2010 02:01 PM
