Old January 11th, 2012, 10:03 AM   #1
reaperw
reaperw's Avatar
Motorcycle(s): ninja 250
quick question i am off for work about lifting front of the bike
I have the rear on the rear stand and i dont have the front stand never thought i would need it.Now i need to lift the front up so i can get the tire off.Is it safe to use a car jack and a piece of wood under where the shock backet is while on rear stand.I mean just long enought to slide front tire out then rest forks on blocks with wood underneath the forks..I dont want to be in the i drop my bike yet.I really dont want to be on here next week asking how to change a damae shock eithere.
Thanks guys
reaperw is offline   Reply With Quote
Old January 11th, 2012, 10:12 AM   #2
while on rear stand, carjack on the oil filter cover on the bottom of the engine. put a piece of wood between so you dont jack up the paint. put some weight on the rear of the bike so it doesn't teeter
Old January 11th, 2012, 10:59 AM   #3
Flying Pig
Resident Lurker
Flying Pig's Avatar
Motorcycle(s): R6, Strom, 250R, CH80 Elite
Car jack + wood under stock headers. If you have aftermarket headers, I might worry, but the stock steel headers are strong enough. Plus, the headers extend out below fairings on pretty much every bike, so no need to remove the fairings to worry about crushing them either
Here's a pic with my old GS500 done in this same fashion. Couldn't use my front fork-lift stand since the forks came out, obviously.
When was the last time you checked your tire pressure?
Flying Pig is offline   Reply With Quote
Old January 12th, 2012, 08:26 AM   #4
dubojr1
dubojr1's Avatar
Please, please, please be careful with these methods. When lifting the front by the engine/headers, the bike is balancing on the engine pretty good. The bike can easily be knocked off the rear stand sideways due to this balancing act. I for one lift the front of the bike with a hoist from the triple tree plate. Lifting from here only plants the rear of the bike on the rear stand even more. Works perfect if you have a hoisting method.
Old January 12th, 2012, 08:50 AM   #5
massacremasses
Avid Kitteh Poster
massacremasses's Avatar
Motorcycle(s): 2006 Yamaha TTR 50 SUCK IT
more pics of methods? I have to do this to... I need to take my wheels off and only have a rear stand...
I powdercoat stuff Help me pay for my addiction
I say funny stuff. http://twitter.com/JustinPWNSyou sometimes...
I write like a 12 year old too, http://justinpwnsyou.wordpress.com/
massacremasses is offline   Reply With Quote
Old January 12th, 2012, 12:36 PM   #6
from faq/ninja250.org
yes be careful when using these methods. Use a tie-down on each side of the triple and attach each of them to the rail for your garage door. Just take the slack out of them, don't actually make them carry weight. Weight is taken up by the car jack under the oil filter. The tie downs just stabilize the bike.
Old January 12th, 2012, 01:25 PM   #7
Felipe the Ant
Motorcycle(s): 2011 Ninja 250R SE GREEN!
You should really hang it from something but when I took my wheel off I wheeled it up on a piece of wood, put the rear on jack stands, put concrete blocks and boards under both forks and then yanked the board out from under the front wheel. Just make sure the steering is straight or it'll lean, I had someone hold it upright while I had the wheel off.
Not perfect but it was easy and it worked, next time I'll probably build something
Trust me, I'm a banana!
Felipe the Ant is offline   Reply With Quote
Old January 12th, 2012, 01:40 PM   #8
reaperw
reaperw's Avatar
Somthing like I did will post pic when I am done installing front tire most like to night
Posted via Mobile Device
Old January 12th, 2012, 02:01 PM   #9
just use a neck tube stand next time. you will eventually take the forks off and will need it anyway
Old January 12th, 2012, 02:08 PM   #10
massacremasses
Avid Kitteh Poster
I could probably make something out of steel tubing. quick someone give me the dimensions of how high I would need it to sit... and how wide ill go make one
Old January 12th, 2012, 07:24 PM   #11
reaperw
reaperw's Avatar
well everthing is done.Did rear tire then front.Its pretty easy not hard at all.Myabe i was just luckly but the rear was np,i was thinking the whole time about trying to line everything up.I held everything up and my dad just slide the axle in with out any problem.The most time it took was trying to figure out how to lift this bike to sit it on something.I just pick the front end up by lifting from the rim while my dad moved the blocks under the forks(thanks guys) I would say all in all maybe 1h15 min.This is removal and install time only.
Old January 12th, 2012, 07:25 PM   #12
reaperw
reaperw's Avatar
sorry not the best pics but you get the point
Old January 12th, 2012, 08:30 PM   #13
massacremasses
Avid Kitteh Poster
what tires are those?
Old January 12th, 2012, 08:43 PM   #14
reaperw
reaperw's Avatar
110/70r17 and 130 70r17 michelin pilot activ,they look wider on the bike then the stock irc
Old January 12th, 2012, 08:47 PM   #15
reaperw
reaperw's Avatar
my irc were down to 3/32 in the rear and 4/32 in the front.With just over 20000km on them.
Old January 12th, 2012, 09:29 PM   #16
massacremasses
Avid Kitteh Poster
they look good. how much did they run you?
I am debating what I want to do about mine since I feel dumb putting the stockers back on after I powder coat the rims as im going to pay someone to do it so I dont **** up the powder coating...
Old January 12th, 2012, 09:49 PM   #17
Just get new tires while you've got everything taken apart. The only thing you'll regret is not getting the new tires sooner
Old January 12th, 2012, 09:51 PM   #18
massacremasses
Avid Kitteh Poster
I know but im cheap and these have less than 4k on em!
Old January 12th, 2012, 09:54 PM   #19
Originally Posted by massacremasses View Post
I know but im cheap
Look at it as saving money on labor. Only do it once!
Old January 12th, 2012, 10:45 PM   #20
reaperw
reaperw's Avatar
220 cad tax in from petes superbike but he is in montreal canada
motorcycle super store has them as well i think almost same price and there in usa
Old January 13th, 2012, 07:25 AM   #21
massacremasses
Avid Kitteh Poster
yeah thats why im debating on it....
the closest MSS is 75 miles away... I try to limit my trips down there unless im already going down there to work. So Id need to order them online then find a shop to put them on...
Old January 13th, 2012, 08:00 AM   #22
do it! you won't regret it!! Tires on the ninjette are the one "upgrade" that is actually an upgrade that helps the bike in all aspects. It's like a whole new bike. I can't believe I didn't change mine out the day I got the bike. I've heard the IRC's are better than the pregen Dunrocks, but still.
Old January 13th, 2012, 10:09 AM   #23
massacremasses
Avid Kitteh Poster
lol
we will see, wife just called I need to spend $250 on her teeth apparently :/ and her wisdom teeth need to come out soon too... So I guess I better start saving for that.. lol
Old January 13th, 2012, 10:12 AM   #24
reaperw
reaperw's Avatar
well do what we did when we were younger tie a string to her tooth and the othere end to your axle problem solve
but your need the new tire to make sure it comes out clean
Old January 13th, 2012, 10:16 AM   #25
massacremasses
Avid Kitteh Poster
HAHAHAHAHAHAHAHA
ill let her know.
but yeah I do want new tires... ugh I might just hold off even powder coating them until I can get the new tires
Old January 13th, 2012, 10:20 AM   #26
reaperw
reaperw's Avatar
dont take off the tire to coat them unless new tires are being put on.Just think about labour cost alone.It would then cost as much as your tires
Old January 13th, 2012, 11:47 AM   #27
massacremasses
Avid Kitteh Poster
yeah thats why ive been debating it....
I dont really feel like rocking an all black bike right now though.. lol but yeah I think Ill get some new tires before I powder coat them...
Quick question kennetht 2008 - 2012 Ninja 250R Tech Talk 5 March 26th, 2014 11:40 AM
Quick Question PsHYk 2008 - 2012 Ninja 250R Tech Talk 3 June 10th, 2012 02:58 PM
quick question before I head off to work walty87 2008 - 2012 Ninja 250R Tech Talk 16 May 13th, 2012 12:34 PM
Lifting Front? scotty General Motorcycling Discussion 18 January 12th, 2011 08:48 PM
Quick question...is my bike waterproof? 00v_Lucky General Motorcycling Discussion 9 February 7th, 2010 10:50 AM
