July 9th, 2012, 05:56 PM | #1 |
ninja 250 float problem?
So i was trying to find out what was wrong and i think its the float.... hrres the problem. Soo basically he started the bike up with the choke on and as soon as he turned it off it shut off, then we tried it again with the choke on an as soon as he gave it some gas it bogged down... so then i hit the float bowl and suddenly it works then he rides a little bit then suddenly turns offni need help :{ p,ease anything will work
July 9th, 2012, 07:53 PM | #2 |
Has the bike been sitting for a long time? You might want to clean the carbs and use fresh gas.
Ç¥ñ頻| ßÿ Ñâ7µ®é. Äñt¡~§º¢Ïä| ßý Çhøî©è. |
July 10th, 2012, 08:26 AM | #3 |
Join Date: Oct 2010 Motorcycle(s): '02 Ninja 250, '98 Triumph Sprint 900, '69 H-D Sportster XLCH 900 Posts: 80
There's another Ninja 250 site, I think it's ninja250.org, that has an excellent "How-to" page. It has really good instructions, with pictures, on how to clean and set up the ninja Kiehin dual carbs.
Until you get hip to these carbs (not really that difficult) you're in the useless quesswork stage. Don't mean to be salty here, but without basic carb knowledge you're at someone else's mercy. With basic carb knowledge you have a sweet running machine.........check out the "How-to" page. j98sprint |
July 10th, 2012, 08:40 AM | #4 |
So it sounds like the bike is starving for fuel. It's time to go thru the fuel system which probably means the carbs will have to be cleaned.
http://faq.ninja250.org/wiki/Cleaning_the_carbs_1
July 10th, 2012, 09:52 AM | #5 |
hitting the carbs made them work? i'm going to have to remember that...
open them up, maybe the float valve is gummed up
July 10th, 2012, 05:23 PM | #6 |
Join Date: Jun 2012 Motorcycle(s): 2010 Metalic Island Blue Ninja 250r Posts: 206
I recently just cleaned my carbs for the first time using these 3 step by step videos..
I had no previous carb work experience but am mechanically inclined so it was fairly simple. Here is a link to the first video! http://www.youtube.com/watch?v=exa467_eoXw |
July 10th, 2012, 06:05 PM | #7 | |
Join Date: Jun 2012 Motorcycle(s): 2000 Kwak Ninja 250 and 1998 Yamaha YZ400F Posts: 534
Sounds like a case of needing a carb clean. Cleaning the carbs is the easy and simple job. Getting them off is another story. |
2010 Kawasaki Ninja 250 problem | Revlimiter | 2008 - 2012 Ninja 250R Tech Talk | 11 | March 29th, 2015 08:23 PM |
2010 Ninja 250 Tach/sputtering problem | wyciwug | 2008 - 2012 Ninja 250R Tech Talk | 3 | May 16th, 2014 09:38 AM |
Carb Float Problem | Trainsk8 | 2008 - 2012 Ninja 250R Tech Talk | 3 | June 4th, 2012 12:31 PM |
ninja 250 problem | sostupid007 | 2008 - 2012 Ninja 250R Tech Talk | 12 | May 23rd, 2012 03:44 PM |
