Old June 13th, 2012, 12:40 PM   #1
drdriftking007
Drdriftking007
drdriftking007's Avatar
How hard is it to clean the carbs on the ninja? :( NOOB!
wanting to clean my carbs for the first time myself. Is it difficult? I know the ninja250.org site have steps but I feel like I might screw up.
drdriftking007 is offline   Reply With Quote
Old June 13th, 2012, 12:52 PM   #2
Stingray1000
Stingray1000's Avatar
Motorcycle(s): 2003 Kawasaki Ninja 250R
Good question!
http://www.facebook.com/groups/DeMdNjPagrouprides/
I live my life a quarter mile at a time!
Who is affraid of the big bad jiggles???? LOL
Stingray1000 is offline   Reply With Quote
Old June 13th, 2012, 12:56 PM   #3
davenay67
davenay67's Avatar
You say NOOB in your thread title. Is this referring to the Ninja or to mechanical aptitude in general..??
We all start somewhere, and carbs aren't a bad thing to work on (especially as the Ninja only has 2) so long as you are very careful, take your time and work in a clean environment. I like carbs because I can take them off the bike and then work on them inside the house in warmth and comfort. Just leave the carb spray until you get outside though.
Follow the instructions on ninja250.org, treat everything with great respect and you should be OK.
Old June 13th, 2012, 01:50 PM   #4
drdriftking007
Drdriftking007
lol I am talking about my mechanical aptitude haha
Old June 20th, 2012, 02:46 AM   #5
jayman87
Motorcycle(s): 2007 ninja ex250
Hey, these vids helped when I did might cleaning.
Carb Removal
http://www.youtube.com/watch?v=Q7bCEuefvgY
Carb Overhaul
http://www.youtube.com/watch?v=vJVHu8itDls
Well they would have if my carbs actually needed a cleaning. My bike sat for two months with no stabilizer in it. When I started it, it felt like it was struggling a little.
I always let my bike idle a min before I take-off and warm it up on the road, and it would die twice before that minute was up(not just the first start, for the next week). So I yanked the carbs and as I got inside to clean them they were already spotless. Float bowls so clean I could have my morning cereal in them. All those hours wasted, and I still had to put them back in and hope I didn't screw them up. Turns out I needed a valve adjustment. My valves were super tight.
jayman87 is offline   Reply With Quote
Old June 23rd, 2012, 01:18 PM   #6
Solunatic
Solunatic's Avatar
Motorcycle(s): 1990 Ninja 250 "Jolene"
Actually cleaning the carbs isn't the difficult part about cleaning the carbs. It's getting them off and back in the bike that's the problem! if you've never done it before, follow the guide on ninja250.org and be prepared to call your bike all sorts of terrible names. Cleaning the carbs itself is pretty simple, I've never used carb cleaner, just gasoline, my fingers and a shop rag. For cleaning the jets i use a set of gauge pins and push em through, but the right gauge wire from the hardware store would probably work just as well. Be careful with the diaphragms though. They're kinda fragile and i hear expensive to replace. My general rules are don't clean them with metal, and only use gas or carb cleaner. since it's your first time you may want to label parts with tags or something and then compare them to the pics in the guide as you reassemble, and only do one at once so you have a physical reference. It really sucks to get everything back together, look in the bin and think "now where the hell did that come from?"
Solunatic is offline   Reply With Quote
Old June 24th, 2012, 09:17 PM   #7
dirty nasty
Motorcycle(s): 2000 Kwak Ninja 250 and 1998 Yamaha YZ400F
All of this. The carbs on these bikes are simple and straightforward. Getting them on and off SUCKS. That's why I recommend you do this modification.
http://faq.ninja250.org/wiki/Battery...r_carb_removal
It is THE BEST modification to make the bike easily serviceable. It's a lot of work to do, but think of it like this. If you don't do this modification you will have to remove the rear wheel and rear fenders every time you need to remove/install the carbs. If you do this modification it's only a matter of taking out the battery, removing the tray and pulling back the air box for all the clearance you would ever need to get at the carbs. Believe me, you will screw up putting the carbs together correctly your first few times. They will need to come off and go back on multiple times before you get it right.
Also, read up here for info on how to take apart and clean the carbs.
http://faq.ninja250.org/wiki/Intake
Another bit of advice. Be VERY careful when removing the screws on the carbs. They strip VERY easily. They are also not a standard #1 or #2 phillips screwdriver. They're a special size made by some Japanese company. So after removing the phillips head hardware I would take a trip to my local hardware store and replace all the phillips head stuff with stainless allen head hardware. I do this with all my carbs and it makes maintenance a breeze. You'll never have to deal with stripped screws again.
dirty nasty is offline   Reply With Quote
Old June 26th, 2012, 09:30 PM   #8
jayman87
I like your style dirty.
Old June 27th, 2012, 06:04 AM   #9
davenay67
davenay67's Avatar
They are also steel screws in an aluminum body....a bad combination unless you actually like the screws to freeze in there over time. A bit of grease on the threads helps, or even use some lightweight loctite.
Even a flat slot helps in getting them off. Like dirty said, that type of philips head is a bugger.
I think I need to clean my carbs.. Hero Danny 1986 - 2007 Ninja 250R Tech Talk 44 June 9th, 2014 02:06 PM
How to clean carbs with a fuel treatment/seafoam?? Floki 2008 - 2012 Ninja 250R Tech Talk 3 January 19th, 2014 12:24 PM
When to clean carbs and Adjust Valves RandomPhantom 2008 - 2012 Ninja 250R Tech Talk 10 May 10th, 2013 03:58 PM
clean carbs? MLecl0001 2008 - 2012 Ninja 250R Tech Talk 8 December 2nd, 2012 02:12 PM
got 250, need to clean carbs...advice please ryu hayabusa 1986 - 2007 Ninja 250R Tech Talk 50 October 5th, 2010 06:14 PM
