Old October 17th, 2012, 12:46 PM   #41
If the 110's pulled best and the 112's feel like they're bogging, switch to the 110's.
For your mid-range, where was it bogging? Right around 3-4k right after coming off idle with a moderate throttle opening? Or up around 5-6k with moderate throttle openings? Or does it feel a little flat when you gradually roll down to about 1/4 throttle from around 10k?
Do a test. Get in 2nd gear as low as she'll put around (about 2500 rpm will work fine.) Now snap the throttle open, and feel for hesitation/surging or for bogging through the 4-8k range. If the needle height is right, the bike should be able to go from 2500-8000 smoothly and transition completely to the main jet smoothly without bogging or surging.
another test: do lots of gradual roll-on's and roll-off's starting at 4k, 5k, 6k, 7k, 8k, and 9k to see how it responds. I emphasize gradual, because you're looking to test the needle height, not the main jet.
Listen to how the bike sounds: a shallow scream is lean, a really loud bike is rich. You want a deep-throated yowl.
Old October 17th, 2012, 12:52 PM   #42
02337
Motorcycle(s): 03 ninja 250
The only problem I noticed with the bike When I had the 110s and 2 washers was like 1/8th throttle 6 gear around 5-7k would surge and break up sound... This sound/feeling is now completely gone with the 112s and 2 washers currently so I assume it was lean. But with 3 washers and the 110's I could barely make it down the road.
02337 is offline   Reply With Quote
Old October 17th, 2012, 12:56 PM   #43
How thick are your washers? They should be roughly 1/2 of a mm thick.
When I was jetting, I searched through a whole handful of those little washers with a caliper for the thinnest ones I could find. I also made sure that I was using a pair that was as similar in thickness as I could, so both needles were the same height.
Old October 17th, 2012, 12:59 PM   #44
02337
Also 112's don't feel boggy just not as perky as the 110s bike doesn't move like it did with the 110s.
I have the same washer on both with the thinnest opening I cod find as the thinner ones I have had too big an opening and was getting the needle stuck up.
Old October 17th, 2012, 01:03 PM   #45
That means the 112's are still rich, and the 110's are still the better choice.
The washers I have are about 3mm ID and about 6mm OD.
No matter how many changes I made, there was still a slight bog at about 5k. It wasn't all the time, it was just every once in a while, only if I made really small roll-on's. It was just enough to notice, not enough to worry about. I think it's because the needle didn't always return 100% back down to the bottom of the slide. A quicker throttle opening action would get it back where it needed to be, and it worked smoothly without issue. It only happened every once in a while. Is that sort of similar to what you have?
Old October 17th, 2012, 01:09 PM   #46
02337
No what I have is 6th gear 7k rpms slight throttle to continue cruising at 60mph and the bike bucking and breaking up(can feel it and hear it). Any gear when there's slight load to keep it driving at the same speed it will do this. Like prior to when the needles open and the slides lift.
Old October 17th, 2012, 01:17 PM   #47
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
Get a full exhaust it'll solve all your problems.
High flow intake and low flow exhaust = fail
AFM #676
Supersports are for n00bs
Old October 17th, 2012, 01:31 PM   #48
02337
Well I'm sure there are plenty of people running stock exhaust with pods. I you'd like to donate a full exhaust then by all means I'll give you my address.
Old October 18th, 2012, 10:20 AM   #49
02337
One of my mixture screws fell out today on my way to work..../banghead
I really take pride in doing things myself and learning but I think I may put the airbox back on. Anyone have a spare airbox for sale?
Old October 18th, 2012, 10:46 AM   #50
rabies
time is running out....
rabies's Avatar
Motorcycle(s): pregen ninjari
dont quit. i would take out the mixture screws. put a tad spray paint on your fingers and dab teh threads and put them back in. it makes them tigh enough they will adjust but not wiggle/vibrate loose.
The King
rabies is offline   Reply With Quote
Old October 18th, 2012, 10:53 AM   #51
02337
Well I think the problem is that I lost the mixture screw, I
Hoping it's sitting in a crevice user the carb. Also getting the bike home is going to be fun. I'll do the spray paint trick a you suggested.
After that Im going back to 110's and finding some thinner washers.
Old October 18th, 2012, 11:43 AM   #52
How far out were your mix screws? You really shouldn't back them out more than about 3 turns, just to be safe. If you find your bike needing them out further than that, you can go up a step on the pilot jet.
Old October 18th, 2012, 11:52 AM   #53
02337
Set to exactly 2 and 1/2 turns
Old October 18th, 2012, 12:08 PM   #54
Huh. I've never had them fall out from 2.5 turns. Good idea on the spray paint.
Old October 18th, 2012, 08:04 PM   #55
02337
So after work I decide to look for the mix screws. They were still in the carb but just rattled loose. I put a small amount of hair gel on the theead(ghetto I know but it's all I had in te bag lol)
Bike idles better but now it's bucking/hesitating again at 60 mph 6th gear with just enough throttle to maintain 60. If I don't give it anymore throttle it starts to drown out even more.
This wasn't the case yesterday as bike seemed to run great for over 100 miles besides being a little lacking on power.
Would bucking and hesitating seem rich or lean?
I'm off tomorrow so I'm going to tear into it and put the 110s back in.
Old October 18th, 2012, 09:22 PM   #56
Bogging is rich.
hesitating/surging is lean.
Are all your carb parts in good condition? like the diaphragms and everything?
Old October 18th, 2012, 09:53 PM   #57
02337
Yes I checked everything everytime no tears no rips, now let me go a little in more in depth with what was happening, as I rode home the bike biked and surged so bad but then sometimes it would randomly take off and I did no throttle change. Could this possibly be a electrical coil issue?
Old October 18th, 2012, 09:58 PM   #58
lean in that area.
Jetting help Sipper' 1986 - 2007 Ninja 250R Tech Talk 5 April 18th, 2015 04:10 PM
help with jetting!!! Plasma 2008 - 2012 Ninja 250R Tech Talk 15 October 28th, 2013 09:59 PM
Jetting: the right way alex.s General Motorcycling Discussion 4 July 20th, 2012 05:34 PM
Jetting ?'s triton981 2008 - 2012 Ninja 250R Tech Talk 2 September 5th, 2011 07:38 AM
jetting mxnello 2008 - 2012 Ninja 250R Tech Talk 1 April 18th, 2009 05:25 AM
