Old March 3rd, 2018, 07:29 PM   #1
///M
Motorcycle(s): 94 Ninja 250
Junction Box Question
Hi all, quick question. I need to replace my junction box in my 94 (headlight stopped working, most likely culprit). Will any pregen junction box work? Or are there little differences in a few of the years.
-Thanks
///M is offline   Reply With Quote
Old March 6th, 2018, 06:17 PM   #2
///M
Just an update for future reference in case someone comes across this thread:
Different part numbers between the 2. Not sure if they'd be compatible.
26021-1071 is for my 94, and in 95 it changed to 26021-1089 (which the updated # is 26021-0058).
Old March 6th, 2018, 07:03 PM   #3
Is damage that severe? Can you just replace a wire or two?
Old March 6th, 2018, 07:05 PM   #4
///M
Not sure. Been 6 months since I've read anything about it, but IIRC the junction box is where the headlight relay is located and is a sealed unit. I tested all the wiring to my headlight and everything checked out no problem.
My plan of action is to replace the box, and if it works I'll tear the old one apart to see if there's a simple sign for failure.
fuses and junction box james250ninja 1986 - 2007 Ninja 250R Tech Talk 2 September 8th, 2014 05:23 AM
Air Filter Box Question Little Green Machine 2008 - 2012 Ninja 250R Tech Talk 7 July 14th, 2012 06:25 AM
