Old June 9th, 2010, 10:39 PM   #1
03slime250
Motorcycle(s): 2003 ninja 250
have to use throttle to start it
i laid my bike over last week in my driveway. it was very hard to start afterwards, and i figured i just flooded it. well, now every time i cold start it i have to use the throttle. used to i could just use my choke and it would fire up, but not now, it just cranks until i use the throttle. what have i done?
03slime250 is offline   Reply With Quote
Old June 9th, 2010, 11:01 PM   #2
check to see if the choke cable is properly adjusted.
Old June 9th, 2010, 11:29 PM   #3
captlombardi
captlombardi's Avatar
Motorcycle(s): '09 EX250J, '01 CBR600F4i
possibly not related, but after i wrecked my bike the first time it took some effort to start (combo of cranking, choke, and throttle) but now it has a jet kit and yoshi exhaust. i always crack the throttle because i think it starts a little faster, maybe taking some stress off the starter.
how much throttle are you using? the way the bike works, if you have to add throttle (air) to start it then it's overly rich on startup. maybe you're using too much choke? if its hot out you won't need to use almost any choke.
captlombardi is offline   Reply With Quote
Old June 10th, 2010, 12:57 AM   #4
03slime250
how do i check to see if the chole cable is adjusted right?
Old June 10th, 2010, 01:03 AM   #5
procedure is in the owner's manual.
Old June 10th, 2010, 09:20 AM   #6
03slime250
dont have one
Old June 10th, 2010, 09:51 AM   #7
dubojr1
dubojr1's Avatar
Originally Posted by 03slime250 View Post
dont have one
PM me with an email and I'll send you a copy.
Old June 15th, 2010, 11:56 AM   #8
tiggen
tiggen's Avatar
Motorcycle(s): 2003 250
Try starting it with no choke and at half throttle.
tiggen is offline   Reply With Quote
Old June 15th, 2010, 12:20 PM   #9
03slime250
thats how i have to start it
i got the owners manual from dubojr1 but havent had the chance to check out the cable
Old June 15th, 2010, 05:18 PM   #10
tiggen
tiggen's Avatar
I could be wrong, but I don't think it's the choke cable. Same thing happened to me. I drained the tank and carbs and put in new gas. Also changed the plugs. Don't know which helped more, but now the bike runs smoother than it ever has.
Old June 15th, 2010, 11:00 PM   #11
03slime250
thats what i was thinkin at first is that i maybe dislodged some junk
Old June 17th, 2010, 05:56 AM   #12
FrugalNinja250
FrugalNinja250's Avatar
Motorcycle(s): Several
A possible sequence of events: When the bike went over fuel sloshed into the pilot jet air bleed holes and other places it wasn't supposed to go. Because those holes are very, very tiny the surface tension of the gasoline was higher than cranking air flow could overcome, meaning that the mixture was way, way rich or lean. This resulted in an incombustible air/fuel mixture that fouled the plugs. Once the fuel evaporated out of all the orifices and the air/fuel mixture was back to normal the engine won't start or run as well because of the carbon deposits on the plugs.
That happened to me on my '06 last year. It took a couple of hundred miles before the carbon got burned off the plugs well enough to restore the performance back to normal.
Old June 19th, 2010, 11:24 PM   #13
03slime250
well, every couple of days or so ive been checking it by just using the choke and i did it the night before last and it fired up without throttle and since then its been like old times
Full throttle kills bike, throttle lag response. Diegone 2008 - 2012 Ninja 250R Tech Talk 10 April 30th, 2014 03:25 AM
Will not start without throttle allanoue 2013 - 2017 Ninja 300 Tech Talk 33 January 23rd, 2014 09:57 AM
[twisted throttle] - Visit the Twisted Throttle Open House & 10th Anniversary Party o Ninjette Newsbot Motorcycling News 0 April 13th, 2012 07:40 AM
[twisted throttle] - Visit the Twisted Throttle Open House & 10th Anniversary Party o Ninjette Newsbot Motorcycling News 0 April 12th, 2012 11:20 AM
Throttle & Throttle Cable Smoothness paterick4o8 2008 - 2012 Ninja 250R Tech Talk 3 December 1st, 2009 01:50 PM
