Old May 20th, 2010, 09:51 AM   #1
ecannon1
Motorcycle(s): depends on the day of the week
valve clearance??? what are they supposed...
I have two pdf manuals now. The one manual is missing the page 4-6 which probably has the information I need. The other manual is a 86 model and I am not certain that the valve clearance are the same. So does any one know what the valve clearances are for a 2006 ninja 250. I need exhaust and intake (inlet). Thanks for the info.
ecannon1 is offline   Reply With Quote
Old May 20th, 2010, 09:53 AM   #2
ecannon1
the 86 maual say .08-.13 inlet and .11-.16 exhaust in mm. Just want to make sure they are the same.
Old May 20th, 2010, 10:00 AM   #3
ecannon1
2006 ninja 250
inlet in mm ( .08-.13)
exhaust in mm ( .11-.16)
according to the local dealer so it appears they are the same. Answered my own question but figured this might help someone at a later date.
Old May 20th, 2010, 10:41 AM   #4
SpYd3r05
SpYd3r05's Avatar
Motorcycle(s): 2003 Ninja 250
That's correct per ninja250faq also...
SpYd3r05 is offline   Reply With Quote
valve clearance sharky nrk 2008 - 2012 Ninja 250R Tech Talk 8 July 18th, 2014 06:19 AM
Should I do the valve clearance inspection myself? nickjpass The Ex-Ninjetters Lair 13 June 13th, 2014 12:50 AM
Valve Clearance check tsmith3605 2008 - 2012 Ninja 250R Tech Talk 3 July 26th, 2013 01:10 PM
Valve Clearance Problem ElJokerr 1986 - 2007 Ninja 250R Tech Talk 9 February 22nd, 2013 12:40 PM
valve clearance specs dotsony 1986 - 2007 Ninja 250R Tech Talk 20 March 17th, 2011 02:46 PM
